rattlesnake1982;797662 said:Be careful bro, after the GTI fellers come n cucuk
Your CRZ...!
I only simply agree with Splee. They must go after him
Your CRZ...!
splee;797640 said:VW should have gone to 8 speed straight instead of 7 speed. DSG 7 speed not balance..... One clutch control 1,3,5,7 and another clutch control 2,4,6. Not balance...
tIANcI;797675 said:I only simply agree with Splee. They must go after him
splee;797714 said:Like that la you. When got problem redi push it to others.
Tianci is bar council member ok.tIANcI;797796 said:No la ... You simple taroh, so I simply agree mah. You better check with t2 about unbalanced odd numbered dual clutch gearboxes.![]()
rx8;798019 said:Tianci is bar council member ok.
splee;798030 said:Aiyah... Don't care how many gear box DSG...... Even or odd no....balance or not balance....no matter..... what matter is all got problems now.... VW pening already.
Also wrong, the DSG 6 speed wet clutch gearbox is still one of the better ones. Yes it had problems but mostly rectified. Available on the Golf GTI Mk6, Golf R Mk6, Passat CC 2.0, VW CC 2.0, VW GTD Mk6, VW Jetta GLI. Just stating the models in case you get confused. Also the 7-speed gearbox in the Tiguan and the 7-speed DSG gearbox for the 1.4 models are different. Both have different torque tolerances at 500Nm and 240Nm respectively.splee;798030 said:Aiyah... Don't care how many gear box DSG...... Even or odd no....balance or not balance....no matter..... what matter is all got problems now.... VW pening already.
tIANcI;798041 said:So BMW not pening that the F30 got crappy seats, lousy steering column problem ... not headache right?
nitedevil;798048 said:How can you match BMW problems with VW problems.
Different class you know!!!
Mavik;798045 said:Also wrong, the DSG 6 speed wet clutch gearbox is still one of the better ones. Yes it had problems but mostly rectified. Available on the Golf GTI Mk6, Golf R Mk6, Passat CC 2.0, VW CC 2.0, VW GTD Mk6, VW Jetta GLI. Just stating the models in case you get confused. Also the 7-speed gearbox in the Tiguan and the 7-speed DSG gearbox for the 1.4 models are different. Both have different torque tolerances at 500Nm and 240Nm respectively.
tIANcI;798052 said:But you loved the ride in the Laughing Stock of the Automotive World Lotus did you not? Hahahaha ... Z4 feels like what now? Kekekekekeke
Not even considered a guru, there are other real gurus here. Just join the TT's and you will notice them. I just understand what the abbreviation of what JFGI actually stands for. :rock: :rock: :rock:splee;798054 said:Wow... We have a guru here with all the correct facts.. Thank you for sharing.... Sorry if I confuse everyone... I am still a rookie when it comes to car tech....
nitedevil;798056 said:You're riteee.... Z4 feels like pondan's car as what Daniel said.
tIANcI;798059 said:Maybe someone we know can use their 328 against a mere 1.6 litre Laughing Stock of the Automotive World Lotus Elise on Sepang. Let's say do 15 laps la ... fair or not? I mean 1.6 litre nia mah ... roadtax so so cheap ... car also no carpet ...
