UnoS
Official member
- Dec 11, 2011
- 508
ICEMAN 68;790757 said:bro ...get the m3 rear bumper ...will surely transform your looks there
in my wish list bro
UnoS;790492 said:some pic's of my e36 325i 94
slyder;792500 said:How much you got the b pillar bro. second hand or new?
UnoS;792391 said:today i DIY to change the B pillar. to do this I need to take out the front seat. Tools you need are
1. box socket size 16 - price I bought at hardware shop RM10
2. box socket torx / (some hardware shop called it star) size T50 - price RM13
3. long nose
4. minus small screw driver
working step
2 time i run to hardware shop to by first and second tools. first becoz it need box socket size 16 to open seat back bolt and front nut. second time i run to hardware shop becoz it need T50 torx box socket to open the seat belt screw from seat side.
after remove the car seat, open bolt size 16 for seat belt from b pillar. remove the seat belt height adjustable square knob. once seat belt is free, old B pillar can be remove after you take out front and back rubber door lining.
use long nose and small screw driver to remove and take out broken b pillar leg from slot.
then can install new B pillar. start from top clip then middle clip, then bottom clip. reverse the opening step to assemble back seat belt and car seat.
if cannot understand my write up just kasi hantam saja.... as long you have the tools i mentioned above...
azmi318;799523 said:bro.. which shop u go for the B pillar ?. i searching for C pillar, both pillar broken aldy..
JFT63;806208 said:Unos, did the mech do a pressure test to detect the leak?
UnoS;806224 said:nope.... they just installed the radiator.....but how to do this pressure test? is it dificult?
JFT63;806281 said:ask them to do the test so that u can rectify the leak at once. it is a hassle to come again for the repeating cause tho..
http://www.team-bhp.com/forum/iipcache/94030.jpg
JFT63;806714 said:Hope yr leak issue has been rctified...
B33mEr;807226 said:It was a pleasure meeting you the other day bro :top: :4:
