My adventure begin (E36 325i (A) 94,
last week, jalan2 around kedai potong... just to try my luck for cheap e36 parts... at the end 1 got one still good looking e36 3 spoke steering wheel non airbag for rm70 jer....
that's one chop shop at puchong (on left side if drive from putrajaya toll) quote me same stering model for rm650... what lah potong leher betul! kat mudah pun baru range rm250 to rm350 jer...
The ChopShop at Puchong perdana is a cut throat. You'll be lucky to get anything reasonably priced. Besides, the boss/manager seems like got period and not interested in selling.
Geng,
this week have sound crang-crang.... from my engine bay.... sound like belting and bearing... but only intermittent... if switch on aircond... the sound will be continuous...
Need advise how to diagnose... before just accept what ever pomen said at least have some understanding...
hi geng,
need your guys advice and opinion for below
1. how much estimate price for belting complete set?
2. how much estimate price for tensioner complete set?
3. how much estimate price for aircond full service?
4. how much estimate price for rear suspension complete bushing set?
tq
update.
just come back from m speed usj.
1. change fan belt
2. change aircon belt
3. change all pulley n bearing set
4. change fan belt tensioner
5. change aircond belt tensioner
6. upah
total cost RM580. I will monitor the crank2 noise when engine cold in morning time. now engine quite n smooth
hi frend
Im looking for ori 325 standard spring in good condition. Pomen told me my spring already soft. I dont want sport spring due to many poth hole at my area
susa mau cari bro...unlest kwn2 kita ada yg tknk pakai lg...btw sport spring tk rendah sgt bro...dont wory...
update on today 28 apr works
1st half at m speed usj
1. change all stering hose
2. change stering coil
3. change stering fluid resevoir
4. new stering fluid
5. change lower arm small ball joint. the one at midle arm. 2pcs rm130
6. upah
sub total rm680
2nd half at JK Auto kg subang near big plate restoran
1. eibach front spring set only
2. arm rest
3. gear box oil sum + gasket +top up oil -trade in old with hacut unit due oil drain plug screw loose n leak oil. no time to wait for new threade machining
4. gloove box
5. driver side door rubber
6. rear right side door rubber
all above used hacut condition
sub total rm1550
today total spent rm2230
today at mspeed usj.
change hose fuel. 1m for all hose fuel at engine bay. rm50 only + labor.
then bought m3 air vent at velocity sunway rm100 for a pair
hi geng, if i want to top up water for my expansition tank, should i use tap water or top up with coolant. currently i saw only clear water without any coolant mixture in my expansition tank. what kind of coolant to buy if i cant find bmw coolant in my area (bandar baru salak tinggi / nilai)?
I use tap water with 2 bottles of toyota coolant..some never use coolant,up to u la..
Bro how would you rate Blue Green with MSpeed?
Currently I goto MSPeed but sometimes I feel the boss ask me to change things which may not be broken. Thats why planning to try out Blue Green.
Advantage MSpeed fast service compare to BG n hv good shop enviroment (waiting area just renovated). Summore can use creditcard if not enough cash. Then if bring wife n kid boleh pinjam kete Ah Meng gi Mydin if they boring waiting there
Advantage BG plak, they hv runner for barang2 chop shop.
For me both MSpeed & BG are good with E36 but most my visit only to MSpeed.
