EasyDIS 44 and INPA working
you could try the ADS interface from Mig. See link below.
http://www.miglenium.de/workshop_obd-ads.html
i bought one after getting vm of DIS57/SSS32 onto my laptop. obviously didn't work... knew jack about diagnostic stuff when i got it. only realised later vm setup also requires dk yellow head. case of do first, read/research later... ahkaka.
Used INPA to reset lambda and Throttle adaptation, did not feel much of a difference.
Run the Vanos Test but program ran into errors (some API related errors, could be the cable, I was using a 30 feet extension RS232 cable) . Will try again
30 feet is loong, couldve cause the signal deterioration.
I am also wondering whered you get your INPA/EDIABAS cable, you sound like a happy customer.
aidilj, i was just experimenting. I was able to reset some adaptation to the extension but Vanos Leak Test did not complete , the errors look like is related to the communication (signal deterioration like you said). I will try again with shorter cable and also serial-usb adapter. I will try with different COM port settings, i understand that FIFO must be enabled and the I/O buffer must be set to 8.
I got mine from a Chinese online store, bought other items as well. It would have been great to home-make but too lazy, don't know where I have chucked those soldering tools.
aidilj;616068 said:
To get EasyDIS working download the files in these folders
- EasyDIS and GT1 v44
- EDIABAS 6.4.7 and INPA 5.0.2
- VMware workstation 6.5.2
In addition to that you'll also need Daemon tools installed to mount images for installation. Google for it.
Understanding what you're doing is good as well, I suggest reading through this thread http://forums.bimmerforums.com/forum/showthread.php?t=1297683
done d/loading EasyDIS, VMware, Carsooft 6.5,
EDIABAS 6.4.3 and INPA 4.47 coz mine wasn't 64-bit OS.
currently using winxp sp3 and other pc were win7 32-bit.
so did i d/load the right EDIABAS?
coz read ur 1st post mention u r using win7 64-bit...
thx a lot for ur guide...
Hi M3 it seems like you're almost in a different timezone..!
Anyhoo, I think it is okay to get the later version of INPA/EDIABAS for your machine. It will still work on your XP just that it has drivers that supports x64 too. Give it a try.
I tried the INPA 5.02 yesterday. Could not get it to work yet. M3, you will need the GT1 V44 as well.
aidilj;617700 said:
IanDaddy, INPA 5.02 can't work on 32bit windows?
I have a problem with the installation. I tried the upgrade path but could not select either during installation. Fresh install after old version uninstalled also could not select INPA and Ediabas during install, I think there are still some other files which I need to remove.
Also, there is a setup.exe in 'program installation' folder and there is one instprog.exe in 'Referenz/install' folder . Tried both.
The .iso image I have is 333,304 KB.
Okay, is this downloaded from the same location in first post of the thread? It comes with install instructions, delete c:\INPA and c:\EDIABAS and if you have it c:\ECC-APP
Yes, followed the instructions. I have delete all those folders too, i will check if there is any registry entries.
i only use old pc la bro that's y only support winxp :)
still trying to install GT1....a bit hard coz never use that daemon tools....
aidil,
ive managed to installed easydis and inpa on my winxp ntebook last nite. im using carsof cable + usb serial convertor. but its giving me error 200.159
i guess the carsof cable is not usable wit easydis.
some pic View attachment 18720
Skinhead,
Perhaps you can try this. Start up your PC, connect the carsoft cable, start carsoft first then close it. Now start DIS.
IanDaddy;618008 said:
Skinhead,
yup yup,
i just realised i made some setup mistake jus now. i need to config the ip add for the virtual netwrk. will do tht and update...
aidilj;618113 said:
skinhead, yes try exactly as IanDaddy described. More info here http://forums.bimmerforums.com/forum/showthread.php?t=1312104
managed to setup the ip properly. IFHS is connected to 192.168.68.30. run the diagnose, now giving me terminal 15 voltage error...:stupid: after 2days of trying im :banghead:
aidil, do u mind passing me the BOM&schematic for the inpa/ediabas interface cable. ?
skinhead, if your interface works with INPA then it should work with EasyDIS too. In INPA, do both indicators, battery and ignition turned on? They both should turn on when the connector is connected to the OBD port. Try the interface with INPA first then EasyDIS.
Schematic for INPA/EDIABAS is as posted in the first page. I'm posting it here again.. Other than the components in the schematic you would need
OBDII connector
RS232 DB-9 female connector
A multicore cable
Veroboard/stripboard
Cheers
OBDII connector
A multicore cable
Cheers
hi aidil,
only selected module works with INPA. in INPA, both indicators, battery and ignition turned off
i think my carsof cable f0ckup. even in carsof now it will intermittently lost connection. either i follow ur footstep in building the odb interface or i buy the chinese one.
how cheap is odbii connector and mc33290 ic??
tq
skinhead;618397 said:
hi aidil,
tq
skinhead, the components to build the connector is cheap but other charges made it expensive, more expensive than ready made one even. Here's the breakdown
2 x OBD-2 Connector right angle = 9.66 EUR
1 x MC33290 = 1.55 EUR
subtotal = 11.21 EUR
shipping = 15.50 EUR
paypal charge = 3.36 EUR
total = 30.07 EUR
today, this would convert to RM129 while you can get one off eBay with RM100 with round connector converter and no soldering. Okay you can knock 5 EUR/RM 21 because I bought two connectors, but still..
I posted a link to an eBay seller in an earlier post
