piea;739910 said:hey bro...where u buy that all the parts?
xcrave;740634 said:After so long leaving the forum i see bro AidilJ still spreading the racun... wait till they see the effect on the road![]()
Edwardpua;740809 said:
aidilj;740817 said:Bro, need to check tomorrow to be sure. But something like 1000uF 16V would work for that application..
gtgh;748583 said:Hi bro , i have install the 10000uF 16v capacitor in my angle eyes but my angel eyes is still flickering . Where did i go wrong ? Pls advice . Thanks
aidilj;748588 said:Your angel eyes, is it LED or CCFL? How is it powered? through relay or replacing other bulb?
gtgh;748838 said:Mine is E39 and i change the bulb to LED type .
aidilj;749042 said:Bro, does the flickering stops when the engine stop or only when engine is running? The signal sent to the bulb may already pulsed (PWM) causing the LED to flicker. Is the capacitor placed close to the LED? How about bigger capacitor value - could be expensive though? You could also try fixing through coding the LCM if all else fail
gtgh;749072 said:The flickering only happen when i turn my key to the on position just before i start the car . After the engine has been started the flickering will stop if i on my headlamp . If the headlamp is off then it will flicker intermittenly once every 3 to 5 minutes . I have placed the capacitor close to the LED . Anyway i may try bigger capacitor as suggested by you and see what happen . Thanks .
aidilj;749321 said:It's time of the year again to revisit this project. Plans
1. Fix that outstanding alignment so that the angel eyes fully visible
2. Put another set of HID on the outer projector for show only
Since my parking lamp is removed, it is going to activate low beam HID. Position 2 switch will activate the for-show outer projectors. Need to sort out the capability to flash though...
JFT63;749507 said:Haha, finally another project coming your way....
B33mEr;758755 said:Bro ... any updates? :4:
Would like to ask you ... when doing the quad xenons do we need to do software adjustments or resetting via GT1? Will there be any cel error?
aidilj;758760 said:Yes there is update, here's a preview
Yes since we will be removing and replacing bulbs so the bulb check may not be valid anymore. Without this there could be bulb error on the dash.
