NCS-Expert - Brief walkthrough and available parameters 2002 E46 318i CKD
xcrave;757840 said:
Nice one... Thx be installing the NCS back and running my Codes... Will update maybe when im free :)
Bro, please share your success story.. :eek:
Any idea how to program so clock on the gauge is replaced with ltr/100km without upgrading the signal stalk?
Yes please have a look at available options in akmb module in first page. Cheers.
anaksarawak;762588 said:
I cant download from the links provided as it require premium account registration. So sorry to trouble you.
Premium account is not required for download, you just need to create a normal account, I just tried this. Without premium account you still need to wait a few seconds before download starts.
Thanks for your replies and also links provided .. I will give it a try later.
I have a 2008 Mini Cooper S and am trying to program the module to be able to use my retrofitted rear fog lights. As I understand, I would need to activate NEBEL_SCHLUSSLEUCHTE and “code $5AA to the VO by adding code in the CAS and FRM module”. I have played before with NCSExpert and have activated comfort closing, Digital Speed always on and some others, but exactly how do you add these values in the modules?
hello sir and welcome to the board. you can edit the vo using ncsexpert. i suggest signing up in bmwcoding.com and look for the pdf guide therr. cheers.
I understand editing the values, just not sure how to add a new value.
Thanks.
Thank you very much, aidilj.
I'm trying to find that PDF. If you could post it, I'd greatly appreciate it.
wingzee;794473 said:
Just recoded mine to default recirculation mode for aircond on my E46 with NCS Expert thanks to bro anaksarawak. Found a tutorial online on how to code various functions via NCS. Require some time to understand though.
Thanks for the posts wingzee. Heard you're turning blue soon?
By the way, the steps look complicated. For me I just coded IHKA to this
0538 UMLUFT_MEMORY REMEMBER RECIRCULATING AIR SETTING AFTER SHUTDOWN
0002 nicht_aktiv not active
* 0001 aktiv active
* 0001 aktiv active
Bro, we tried to code for the aircon not to auto switch on afrer we switch off the engine without offing the aircon. Can that be done? We tried to code that last night
Did some read-up on my follow-me-home lights and found this. Very useful for translation:
NCSEXPERT TRANSLATIONS hope these help Rondo
**** FSW-PSW :action caused by aktiv/nicht aktiv selection ****
ABFRAGEZEIT_AHM :Trailer module checking interval.
ABKLAPPSTELLUNG : wiper arm parked position changes from horizontal to verticle when active
ABKLAPPWERT :Tilt value
ABSCHALTDREHZAHL_ANLASSER :Starter cut-off RPM
ABSCHALT_GESCHWINDIGKEIT :Turn off speed
ABSCHALT_KL50 : turn off starter switch when active
ABSCHALTKRITERIUM : enable safety pinch switch for power windows when active
ABSCHALTMELDUNG :Turn off confirmation
ABSCHALTSPANNUNG_KL_30 :Turn off value.
ABSCHALTUNG_UNTERSPG :Turn off when voltage too low.
ABSCHALTUNG_VERBRAUCHER : Turn off user.
ABSCHALTWEG :Turn off distance.
ABSENKUNG_10_KM/H : Lowering at 10 km/h.
ABS_MIN_STELLUNG_2 :antilock brake system minimum position.
ABSTAND_HOLD_NORMAL_MODE :Hold distance normal mode.
ABSTAND_KALTPULSE :
ABSTELLPOS_CUSTOM : shut down?
ABSTELLPOS_SMC :
ABTASTRATE_DYN : SAMPLING FREQUENCY DYNAMIC
ABTASTRATE_TREND :SAMPLING FREQUENCY TREND
ACC_FLAG : active cruise control indicator
ADRESSE_AUSWERTEN :adress analyse, evaluate
AIRBAG_BEIFAHRER_1 : passenger airbag
AIRBAG_FAHRER_1 : driver airbag
AIRBAG_TRIGGERED_E-CALL : deployed airbag sends cellular emergency call when active
AKUSTIK_ABBLENDLICHT :low beam alarm sound
AKUSTIK_BREMSLICHT : brake light alarm sound
AKUSTIK_DSC_ASC : dsc or asc alarm sound
AKUSTIK_GURT_WARN :Acoustic belt warning
AKUSTIK_HECKKLAPPE : trunk open alarm sound
AKUSTIK_KONZEPT : alarm concept ?
AKUSTIK_PARKBREMSE : parking brake on alarm sound
AKUSTIK_RDKS : low tire pressure alarm sound
AKUSTIK_RUECKLICHT : tail light alarm sound
AKUSTIK_TUEREN : door open alarm sound
AKUSTIK_WASCHWASSER : low window washing fluid level alarm sound
AL_ALS_DRL : low beam as daytime driving light
ALARM_AKUSTISCH : alarm sound Intervallton-[beep beep] DAUERTONE[continuous]
ALARM_AKUSTISCH_LANG : long alarm sound
ALARMSCHALTER_SI_FZG : alarm switch ?
ALARMSCHALTER_TAXI :
ALARM_OPT_ABBLENDLICHT : alarm pulses low beam when tripped
ALARM_OPT_WARNBLINKER : alarm pulses emergency flashers when tripped
ALARM_OPT_FERNLICHT :alarm pulses high beam when tripped
ALC : automatic level control
ALC_ABSENKUNG_10_KM/H : Automatic level Control 10 km/h?
ALC_AUSWERT_GRADIENT :
ALC_AUSWERT_PROP_ABWEICH :
ALC_FAILSAFE_FCT_EIN :
ALC_FAILSAFE_NSW_AUS_OPT1 :
ALC_FAILSAFE_NSW_AUS_OPT2 :
ALC_FAILSAFE_NSW_EIN :
ALC_FAILSAVE_NSW_LOCK :
ALC_FAILSAVE_NSW_NEU :
ALC_GRADIENT_SCHLECHTWEG :
ALC_KLS_ENABLE :
ALC_KLS_DISABLE :
ALC_LED_DEF :
ALC_LWR_VORZEICHEN :
ALC_SAETT_TIMER_SCHLECHTW :
ALC_SCHWENK_LATCH :
ALC_VERBAUT
AL_KL_50 : Low beams on ignition on. (DRL)
ANHAENGERKUPPLUNG : when trailer wire attached rear pdc turned off
ANHAENGERMODUL_PWM_WERT :Trailer module power value.
ANHEBUNG_175_KM/H :Increase at 108mph???
ANKUNFTSZEIT_VON_NAVI : time of arrival using navigation
ANLAUFSTROMBEGRENZ_MEMO :electrical warning
ANPRESSDRUCKVERSTELLUNG :Windscreen wiper pressure adjustment
ANTI_DROEHN_STELLUNG :
ANZAHL_QUICK_RUNDEN :Amount of quick rounds.
ANZAHL_RAEDER_VERBAUT : Number of wheels mounted. 4
ANZAHL_SPRITZIMPULSE :Number of spray impulses.
ANZAHL_STUFEN :Number of stages.
ANZEIGE_EML : display electronic motor load ?
ANZEIGE_ANKUNFTSZEIT : display e.t.a.
ANZEIGE_EML : Display motor load.
ANZEIGE_HOCHLADEN : Display M-Track symbol
ANZEIGE_OELSTAND_PREDRIVE :Display oil level before driving.
ANZEIGE_POSITION_AUS :Display position.
ANZEIGE_SITZLEHNE_VER :Display seat lean
ANZEIGE_UHR_IM_DISPLAY :Display clock.
ASC : automatic stability control
ASC3_AUSWERTUNG : automatic stability control evaluation?
ASC_PREDRIVE_UEBER_SG :
ASL :
ASL_DSC_5_7 :
ATEMP_WARNUNG_KALTLAND :cold temperature outside warning
AUFHEIZAUTOMATIK : automatic heater control?
AUSSENGEFUEHRTE_SHDUSSENTEMP_ABH_GEBL_ANH_1 :
AUSSENTEMPERATUR_KORR :
AUSSENTEMP_BEWERT :
AUSSENTEMP_SENSOR :eek:utside Ambient temperature sensor.
AUSSENTEMP_SPERRZEIT_2 :Outside temperature lock time 2
AUSSENTEMP_SPERRZEIT_3 :Outside temperature lock time 3
AUSSENTEMP_WARN_AKUSTIK :Outside Temperature Sound Warning.
AUSSENTEMP_WARNUNG_GONG : External Low Temp Warning Gong
AUSSTATTUNG_RPA :
AUSSTELLFENSTER :vent window?
AUSTAUSCHPUNKT :replaceable part?
AUSWERT_GRADIENT :Trailer gradient.
AUSWERT_PROP_ABWEICHUNG :
AUT_SPIEGELVERSTELLUNG : automatic mirror adjustment key specific
AUT_SITZVERSTELLUNG : choose between automatic seat adjustment [nach_fb_entriegeln] when remote signals door open or[nach_entr_u_tuer_oeffnen] when door opened
AUTO_B_ZUEND_EIN_1;fan speed memory with ignition on [key1]
AUTO_LED_GEBL_MANUELL :
AUTO_LED/SCHRIFTZUG :
AUTO_LWR_ENABLE :automatic headlight leveling control.
AUTOMATISCHER_NOTRUF :Automatic emergency call.
AUTOM_FAHRL_STEUERG :automatic head light control unit [ALS on/off]
AUTO_ZV_DISABLE : disable automatic central locking
BACKUP_ANTENNA :
BACKUP_BATTERY :
BACKUP_BATTERY_ENABLED :
BAUREIHE_A : series
BC_ANFORD_WEGFAHRSICH :immobiliser demand with alarm?
BC_CODE_AKTIV : if active car alarm is enabled ?
BC_DIGITAL_V = if activ digital speed display is on dash
BC_KL_R : In R position, the BC shows the last function chosen.
BC_V_KORREKTUR : aktive allows a correction to true speed [higher]
BEDIENSTELLE_BFT :control section passenger side door ?
BEGRENZUNGSLICHT_IN_PARK ;Sidemarkers in park position.
BEIFAHRERBAG_STUFE2_1 :passenger airbag ?
BEIKLAPPEN_B_KOMFORTSCHL : hold close/open button on remote to fold mirrors & close/open windows
BELUEFTUNGSKLAPPE_OEFF_1 : Ventilation Flap open in warmup phase
BETRMODI_DEAKT_KL15_EIN :
BETR_STD_AUTO_LOESCH :B_SATELLIT_1
BETR_STD_NICHT_LOESCHEN :No deleting of usage hours
BEWERTUNG_FEHLER :defect evaluation
BEWERTUNG_FEHLER_30 :Defect evaluation +12v line.
BEWERTUNG_FEHLER_31 :Defect evaluation chassis ground
BFD_ABS_STUFE3 :
BFD_ASC_REG :ASC controls Brake force display / brake lights blink.
BFD_AX_REF :
BFD_ON :brake force display on
BFD_OPTION :
BFD_SCHWELLE :
BFD_ST3_ON :
BFD_SW1_STUFE :
BFD3_ASC_AKTIV :
BF_UEBERWACHUNG :passenger control
BI_XENON : bixenons .
BIXENON_EIN_BEI_LICHTHUPE : flash to pass is bixexon & halogen together
BL_ALS_SL_DIMMEN : brake light as parking lights dimmed?
BL_DIMMEN : brake light variable?
BL_DIMMUNGS_OPT_1 :
BL_ERSETZ_DEFEKT_SL :Brake lights as replacement for burned park lights.
BL_ERSETZT_DEFEKT_BLK :Brake lights as replacement for burned blinkers.
BLEND_CHECK_IST_WINKEL :
BLEND_CHECK_SOLL_WINKEL :
BL_GEDIMMT_ALS_ERSATZ :brake light &
BL_GED_ALS_ERSATZ_MIT_AH :brake light &
BLINKIMPULS_CRASHBLK ;Crash warning blinker impulses.[01&02normal03very fast 04 double fast]
BLINKIMPULS_WARNBLK :Hazard lights impulses.[01off&02normal03very fast 04 double fast]
BLK_DIMMEN :Dimmed turn signals.
BLK_DIMMUNGS_OPT_1 :turn signal
BLK_H_L_PICT :left rear turn signal in dashboard
BLK-H-R-PICT :right " " " " "
BLK_V_GED_ALS_PARKLICHT : front turn lights & together as parklight
BLK_V_GED_ALS_SIDEMARK :Tail Lamps On, Front Halos On, Side Markers On
BLK_V_GEDIMMT_ALS_ERSATZ :front turn light & together as
BLK_V_L_PICT :left front turn signal in dashboard
BLK_V_R_PICT :right " " " " "
BLS_PRUEFEN :brake light switch check
BLST1_BLST3 :
BL_UND_BLK_H_GEM_BLK : brake light & blinking rear turn light together when braking
BL_UND_BLK_H_GEMEINSAM : brake & rear turn light together
BL_UND_BLK_H_GEM_WBL :brake & rear turn light together as hazards
BORDMONITOR :Vehicle monitor
BORDNETZ :Wiring for navigation?
BPLUS_TRENNUNG1_1 : safety battery terminal
BRAKE_FORCE :
BREMSFLUESSIGK_INV : brake fluid ?
BREMSLICHT_ALS_STANDLICHT : Brake Lights as parking lights
BREMSLICHTSCHALTER : brake light switch
BREMSWARNLEUCHTE : brake warning light
B_SATELLIT_1 :
CAN_11H :
CAN_AUSFALL_BEWERTUNG :
CAN_EBV : brake power distribution
CAN_INSTR2_SENDEN :
CAN_OELDRUCK : oil pressure on can bus
CAN_OELDRUCKSCHALTER : Oil pressure switch on CAN bus.
CAN_S_GSU : light sensor on can bus
CC_ABBLENDLICHT : check control low beam
CC_AUSSENTEMPERATUR : check control cold Outside Temperature.
CC_BREMSLICHT: Check control brake light.
CC_BREMSLICHT_MITTE :Check control middle stop light
CC_BLINKER_HINTEN ;Check control rear turn signals.
CC_BLINKER_VORN :Check control front turn signal
CC_FERNLICHT :Check control high beam
CC_HECKKLAPPE :Check control tail gate
CC_KENNZEICHENLEUCHTE_LI:Check control number plate light
CC_LAMPEN :Check control lights
CC_MELDUNG_AL_L :Check control message low beam
CC_NSL_LINKS :Check control rear left fog light
CC_RUECKLICHT :Check control reverse light
CC_RUECKLICHT_2_RECHTS ;Check control right reverse light. aktiv / nicht_aktiv
CC_RUECKLICHT_3_LINKS :Check control left reverse light. aktiv / nicht_aktiv
CC_RUECKLICHT_3_RECHTS :Check control right reverse light. aktiv / nicht_aktiv
CC_RUECKLICHT_LINKS :Check control left reverse light. aktiv / nicht_aktiv
CC_RUECKLICHT_RECHTS :Check control right reverse light.
CC_STANDLICHT_LINKS :Check control left parking light. aktiv / nicht_aktiv
CC_STANDLICHT_RECHTS :Check control right parking light.
CC_TUEREN :Check control door
CC_WASCHWASSER :Check control windscreen washing fluid
CC_ZUSATZBLINKER :Check control external turn signals.
CENT_LOCK_MGL_VO_TUER_AUF :
CHECK_FGN_SMC_ALC_OFF :
CHECK_IGNITIONA :
CHECK_IGNITIONC :
CHECK_IGNITIONK :
CHECK_SMC_ERROR :adaptive headlight error
CLT_AKTIV_IM_CRASH_MODE :
CODIERUNG_ERFOLGT :Coding done.
CODIERWERT : Code value
COD_IFL :
COD_IFL_AN_PIN48 :
COD_IFL_ASYNC :
CORNERING_BREAK_CONTROL :Cornering Brake Control
CRASH_DISABLE_BEWERTUNG_10S :
CRASH_DISABLE_HECKKL_10S :
CRASH_KLEMME_58G_EIN :Activate interior lights in crash.
CRASH_WARNBLINKEN : turn on hazard lights when car crashed
CUSTOMER_CALLS_OVER_GMIN
CYCL_TI_BLK;1-touch on turn signal blinks.einmal-1.zweimal-2.dreimal-3.
DATENSATZ_1
DAUER_DYN_NACHFUEHRUNG :
DAUERFAHRLICHT_EU : Light control sensor Europe.
DAUERFAHRLICHT_US : Light control sensor US.
DBC_DBS : dynamic brake control-dynamic brake support
DBC_MSB :
DEB_TIME_CS_0 :
DEBUG_SIGNAL :
DEF_LWR_SENSOR_HI :Defective rear headlight leveling sensor.
DEF_PIN_20_DEFEKTBLINKEN :
DEF_PIN_20_VOR :
DEF_PIN_37_DEFEKTBLINKEN :
DEF_PIN_37_VOR :
DELTA_LIMIT_GESETZ :Delta limit law
DIAGNOSE_DELAY_ZEIT :
DIAGNOSE_SCHRITTMOTOR : step motor
DIAGNOSE_ZWP :
DIFFERENZ_ANLAUF_BLOCK :
DISPLAYANZEIGE_HIGH :temp. display on ihka shows HI if aktive.91*F if not aktive
DISPLAYANZEIGE_LOW :temp. display on ihka shows LO if aktive.59*F if not aktive
DISPLAY_GEBLAESRAHMEN :
DOPPELKLICK_AUF :
DOPPELKLICK_HEBEN :
DOPPELKLICK_ZU :
DREHZAHL_KENNLINIE :RPM Characteristic curve
DRIFT_DEKR :Drift decrease
DRIFT_INKR :Drift increase
DRIFT_SCHWELLE :Drift limit
DRL_BLK_VORN_GEDIMMT :Dimmed front blinkers as daytime running lights.
DRL_DIMMUNG :choose brightness level for US day lights.[wert1-off,wert2-22%,wert3- %,wert4- %]
DROSSEL :throttle
DRUCK_OFFSET :pressure offset.
DRUCKMODELL_HINTERACHSE :pressure model rear axel.
DRUCKMODELL_VORDERACHSE :pressure model front axel
DRUCKMODELLPARAMETER :pressure model parameter.
DRUCKPUMPE_DREHRICHTUNG :pressure pump direction.
DSC_DEF_GONG : warning gong when dsc activated
DSP_ACOUSTIC_PROFILE :Digital Sound Processing profile.
DSP_CDC_DIGITALLTG :Digital sound processor Ö
DTC_LAMPE :
DWAH_PIN_C17 : alarm system horn
DWA_BLK_ABSCHALTEN : power to blinkers shutdown with alarm
DWA : anti-theft alarm system
DWA_HANDSCHUHFACHKONTAKT :Alarm glove compartment switch.
DWA_HECKKLAPPENKONTAKT :Alarm trunk switch.
DWA_HECKSCHEIBENKONTAKT :Alarm rear window switch
DWA_NOTENTSCHAERFEN :alarm will not de-activate
DWA-QUITTIERUNG : anti theft system acknowledgement
DYNAM_LWR_ENABLE : active verticle headlight aim control
DYN_BREMS_UNTERSTUETZUNG : active brake assistance
E52_FUNKTIONEN :BMW Z8 Functions
E83_FUNKTIONEN :BMW X3 Functions
E85_FUNKTIONEN :BMW Z4 Functions
E52_LINKS_LENKER :
E52_RECHTS_LENKER :
E53_FAHRZEUG :
E9X_HIMMEL :
EBV_LAMPE : electronic brake force light
E_CALL_COUNTD_DEL_TMR :Emergency call countdown delay timer?
E-CALL_HARDKEY_FITTED : emergency call button installed
ECHOSCHWELLWERTE_ECKE_HI :Echo sensor corner rear
ECHOSCHWELLWERTE_ECKE_VO :Echo sensor corner front
ECHOSCHWELLWERTE_MITTE_HI :Echo sensor middle rear.
ECHOSCHWELLWERTE_MITTE_VO :Echo sensor middle front.
EC_LUEFTER : fan
EEPROM_SHD :
EHC : electronic height control
EINGANG_2 :Input 2.
EINGANG_2_KONTAKT_GESCHL :Entrance 2 contact closed.
EINKLEMMSCH_HINTEN : rear window pinch sensor
EINKLEMMSCH_REVERSIEREN :how long pinch sensor reverses window
EINKLEMMSCH_VORNE : front window pinch sensor
EINSCHALTMELDUNG_BEI_1MA :start?
EINSCHALTMELDUNG_IMMER :Turn on warning always.
EINSCHALTVERZOEGERUNG : Gradual turn-on.
EINSPRITZANLAGE_CAN : fuel injection information to can bus
EINSTIEGSHILFE : comfort entry pushing remote open twice lowers drivers window
EINSTIEGSHILFE_HOEHE : automatic steering wheel up & down [height]
EINSTIEGSHILFE_LAENGE : " steering wheel in & out [length]
EIS_AUSBLENDEN :Defroster gradual turnoff?
EL_DURCHLAUFERHITZER :Electric heater.
E_LUEFTER :
ENABLE_EURO_NCAP :
ENABLE_US_SBR :
ENTFALL_ZV_BEDIENST_HECK :
ENTFROSTKLAPPE_SCHLIES_1 :Defroster close.
ENTFROSTKLAPPE_SCHLIES_2 :Defroster close.
ENTFROSTKLAPPE_SCHLIES_3 :Defroster close.
ENTFROSTKLAPPE_SCHLIES_4 :Defroster close
ENTSICHERN_CENTERLOCK :Central locking button works with no key
ENTPRELLZAHL_FEHLERERK :Error recognition opening number.
ENTRIEGELN_HKL : Open trunk
ENTR_HKL_MGL_WENN_VER :
ENTR_HS_MGL_WENN_VER :
ENTR_KL.R_30S_NACH_SICH :
ENTSICHERN_CENTERLOCK :central locking button works when doors locked & key not in ignition when active
EPSILON_DELTA_A :
ERKENNUNG_BREMSLICHT : recognise brake light?
ERKENNUNG_SITZBELEGUNG_1 : Recognise seat allocation (don't switch this off otherwise the airbag system gets up-set)
ER_KEYOUT_AUTOVR : opens doorlocks when car stops [in CAS module]
ERR_LWR_L_IGNORIEREN :
ERR_LWR_R_IGNORIEREN :
ERR_SCHWENK_L_IGNORIEREN :
ERR_SCHWENK_R_IGNORIEREN :
EWS_3_SCHNITTSTELLE : electronic immobiliser interface
FAHRERBAG_STUFE2_1 : driver ?
FAHRZEUG_HERSTELLER :Vehicle manufacturer
FAHRZEUG_TYP :Vehicle type
FE_SCHEIBENWISCHER :Windshield wiper error?
FEHLER_ABBLENDLICHT :Low beam error.
FEHLER_ABTAKTEN : fault scanned?
FEHLER_ANHAENGER :Trailer error.
FEHLER_BL_BLINKEN :Report brake light error.
FEHLER_BREMSLICHT :Brake light error
FEHLER_NSL_RECHTS :Report rear foglight failure. melden / nicht_melden
FEHLER_SCHALTER_BREMSL :Report brake switch failure.
FEHLER_1_CODE :Error 1 code
FEHLER_1_HAEUFIGKEIT :Error 1 frequency
FEHLER_5_HAEUFIGKEIT :Error 5 frequency
FEHLER_HECKSCHEIBE :rear window error
FEHLERZAEHLER :Error counter
FERNBEDIENUNG : remote control services
FERNLICHT_DRL :High beam DRL.
FERNWIRKEN_GENERELL : telecontrol general
FERNWIRKEN_NAVZIELE :Telecontrol Nav objectives
FERNWIRKEN_POSITION :Telecontrol position
FERNWIRKEN_STANDHEIZUNG :Telecontrol heating
FERNWIRKEN_TELEFONLISTEN :Telecontrol phone list
FENSTERHEBER_HINTEN : rear power window
FENSTERHEBER_VORNE : front power window
FH_ABSCHALTKRITERIUM : US after you switch off the car the power windows are deactivated.
ECE after you switch off car the power windows are active for 1 minute
FH_ABSENKEN_VERDECK_OEFF :Lower power windows when opening vert top.
FH_ABSENKUNG_SPERREN :Disable power window lowering
FH_AUF_STUFE2_KLR_AUS :
FH_BEIFAHRERTUER_TIPP_AUF : Passenger Window power down one touch
FH_BEIFAHRERTUER_TIPP_ZU : Passenger Window power up one touch
FH_FAHRERTUER_TIPP_AUF : Driver Window power down one touch
FH_FAHRERTUER_TIPP_ZU : Driver Window power up one touch
FH_INIT_TRANSPORTMODE :power windows in transport mode
FH_NACH_TUERE_AUF :power windows when door is open
FH_TIMEOUT :maximum run time for window motor
FH_TIPP_DISABLE_TUER_AUF :
FH_TUEREN_HINTEN_TIPP_AUF :rear window power down one touch
FH_TUEREN_HINTEN_TIPP_ZU : rear window power up one touch
FH_ZTR_SCHALTER_TIPP_AUF :4 window button one-touch open.
FH_ZTR_SCHALTER_TIPP_ZU :4 window button one-touch close.
FILTER_DETEKTION_WEIT :
FL_AL_AUS : high beam as low beam
FLC_DIMMER_OPTION :
FLC_LED_EIN ;
FLC_SCHWELLWERT_SATZ;Autom. driv. lghts ctrl (sensative /normal)
FL_DIMMUNG_ALS_DRL :wert_01 = 0 % wert_02 = 18,82 % wert_03 = 20,39 % wert_04 = 43,92 %wert_05 = 18,82 % setting intensity of high beams for daytime running lights
FL_KL_50 :High beams on ignition on.
FL_UND_NSW_NICHT_GLEICHZ :high beam & fog lights not on together when aktiv
FONDGEBLAESE : air conditioning fan to rear seats
FOND_MODUL_1 : rear fan module
FS_UNLOCK_300MS_P_BUS : crash sensor unlock
FUHRPARK_FLOTTENMODUS :Drive park fleet mode.
FUNK_INNENRAUMSCHUTZ :Interior space monitoring
FUNKINNENRAUMSCHUTZ_HI :Interior space monitoring rear.
FUNKTION_CABRIO :Convertible function
FUNKTION_DSC :
FUNKTION_DTC :
FUNKTION_RPA :
FUNKTIONEN_TOURING :Wagon functions.
FUNKTIONTUERSCHLOSS : Door Lock function
FUNKUHR :remote clock?
FUSSRAUMKLAPPE SCHLIES : footwell air flaps closed
FZG_RADSTAND :Vehicle wheelbase.
FZG_VERZOEGERUNG :Vehicle slow down.
GEARMOMENTREGLER_MAX_HA ;Gear torque control max rear axel.
GEARMOMENTREGLER_MIN_HA :Gear torque control min rear axel
GEBL_OFF_MODE :
GEBLAESE_BALKEN : fan bar automatic mode
GEBL AUT B ZUEND EIN : fan automatic at ignition on
GEBLAESEKORREKTUR : fan speed correction choice of absenken,anheben or nicht_aktiv
GEBLAESEBALKEN_AUT_MOD_1 :Automatic air bars
GED_FL_ALS_DRL : dimmed high beam as daytime running light (USA style)
GEDIMMT_BL__BEGRENZ_LICHT :Dimmed brake light as side marker.
GEDIMMT_BLK_BEGRENZ_LICHT : dimmed turn signal as side marker.
GENERATOR_UEBER_CAN :Generator over CAN bus
GERAETENAME :Name of machine.
GEREGELTER_KOMPRESSOR ;Regulated compressor
GESCHW_PRUEFUNG :speed check.
GESCHW_VERDECK_AKTIV :Convertible top speed control.
GESCHWINDIGKEIT :Velocity/speed.
GESCHWINDIGKEIT_FEHLER :Velocity error.
GETRIEBE :Gearbox.
GETRIEBE_ANZEIGE_GANG :Gear display indicator.
GETRIEBEART :Gearbox type.
GLASDACH : glass sliding sunroof
GPS_UHR :get time from gps for radio clock to function you need the LW-receiver in Germany and UK,
GRADIENT_MM_ZUGABE :Gradual millimeter increase...
GURTKONTAKT_MELDUNG_UEBER :Seatbelt warning over k-bus
GURTSCHLOSS_BEIFAHRER_1 :Seat belt passenger.
GURTSCHLOSS_FAHRER_1 :driver seat belt buckle?
GURTSCHLOSS_HINTEN_LI_1 :Belt buckle rear left
GURTSCHLOSS_HINTEN_LI_2 :Belt buckle rear left.
GURTSCHLOSS_HINTEN_RE_1 :Belt buckle rear right
GURTSCHLOSS_HINTEN_RE_2 :Belt buckle rear right
GURTSCHLOSS_HI_MITTE_1 :Belt buckle rear middle.
GURTSCHLOSS_SPANNUNGSS_1 :Belt buckle voltage.
GURTSCHLOSS_STROMSS_1 :Belt buckle electricity.
GURTSTRAFFER_BEIFAHRER_1 :passenger seat belt tensioner
GURTSTRAFFER_FAHRER_1 :driver seat belt tensioner
GURTSTRAFFER_HINTEN_LI_1:Rear seat belt tensioner Left
GURTSTRAFFER_HINTEN_LI_2:Rear seat belt tensioner Left
GURTSTRAFFER_HINTEN_MI_1:Rear seat belt tensioner Middle
GURTSTRAFFER_HINTEN_MI_2;Rear seat belt tensioner Middle
GURTSTRAFFER_HINTEN_RE_1:Rear seat belt tensioner Middle
GURTSTRAFFER_HINTEN_RE_2:Rear seat belt tensioner Middle
GURTWARNUNG_EURO_NCAP :seat belt warning
GURTWARNUNG :Seat belt warning
GURTWARNUNG_GONG :seat belt warning gong with/without buckle contact.
GURTWARNUNG_TEXT :seat belt warning visual
HALB/VOLLSCHRITT :Halfstep/Fullstep?
HALLSENSOR_VSW72 :
HALLSENSOR_VSW8 :
HALTEZEIT :Holding time.
HALTEZEIT_VENTILE :Holding time valves.
HANDY_TYP :Cellphone type.
HARDTOP_ERKENNUNG : hardtop detection
HBA_DSC_5_7 :hydraulic brake assist
HEBEN_AUS_GEOEFFNET :
HECKKLAPPE :Trunk lid.
HECKKLAPPE_ENTSICHERN : open trunk lid with remote control
HECKKLAPPEN_LOGIK :Trunk lid position?
HECKSCHEIBE_ENTRI_INNEN :heated rear window?
HECKSCHEIBE_HEIZZEIT :Rear defroster heating time
HEIMLEUCHTEN : wert_01 is off wert_02 enables home lights (flash high beams with key off to activate)
HEIMLEUCHTEN_ABBRUCH : home light stop
HEIMLEUCHTEN_AL :home lights are low beam
HEIMLEUCHTEN_BL : " " " brake light
HEIMLEUCHTEN_BLK : " " " Blinkers.
HEIMLEUCHTEN_FL : " " " high beam
HEIMLEUCHTEN_FUNKSCHL :home lights on after locking car with remote
HEIMLEUCHTEN_KL58G : home lights are interior backlighting, cluster, ashtray etc.
HEIMLEUCHTEN_KZL : " " " license plate
HEIMLEUCHTEN_NSL : " " " rear foglight
HEIMLEUCHTEN_NSW : " " " front foglight
HEIMLEUCHTEN_RFS : " " " reverse light
HEIMLEUCHTEN_SL_H :" " " rear parking lights
HEIMLEUCHTEN_SL_V :" " " forward parking lights
HEULTON : Howl sound
HHS_AUTOMATIK : automatic rear window defogger
HILLDESC_DSC_5_7 :
HILLDESC_DXC_8 :
HIMMEL_AUTO_AUF :
HIMMEL_AUTO_ZU :
HKL_SPERREN_BEI_ZS :Disable trunk by central locking
HUB_VERZOEGERUNG_FH_VORN :
HWL_1 :
HYDRAUL_HECKKLAPPE : hydraulic trunk opener
HYDR_BREMSKRAFTVERTEILUNG :Hydraulic brake distribution.
HYD_HECKKLAPPE_OHNE_PDC :
IB_AUS_NACH_X_SEKUNDEN :Interior lights off after X seconds
IB_BEI_KL.R_AUS :interior light turns on when ignition(R) turned off after driving with headlights on
IB_CRASH_ON_0_KMH : interior light on after crash
IB_EIN_16MIN_WENN_STANDLI :interior light on for 16 minutes with parking lights
IB_EIN_BEI_HKK/HSK :interior lights on when the door is opened with key
IB_EIN_HK_AUF :interior lights on when trunk opened
IB_EIN_SCHLOSS_ENTRIEGELN :interior lights on when the door is opened
IB_POWER_CONF_0 :
IBUS_R_GANG :Reverse gear on I-Bus.
IB_SPERRE_BEI_FEHLER :Block interior lights on error.
IK_BUS_TEILNEMER :
ITS_FRONTCRASH_1 :inflatable tubular support
ITS_LINKS_1 :
ITS_RECHTS_1 :
INNENLICHT_AN_MEHRFACH_ZV : pressing remote lock button twice turns on Interior Lights
INTERM_FL :Intermittent high beams.
INTERVALLZEIT_GESCHWABH : time interval speed
IR_FERNBEDIENUNG :infrared remote control
IR_FERNBEDIENUNG_BF :infrared remote control passenger ?
KALIBRIERFAKTOR_VERBRAUCH :Consumption calibration factor
KALTUEBERWACH_ZUSATZ_BLK :Cold testing external turn signals.
KALTUEBERWACHUNG_AL : cold testing bulbs in low beam
KALTUEBERWACHUNG_BL : " " " " brake light
KALTUEBERWACHUNG_BLK_HI :" " " " turn signal rear
KALTUEBERWACHUNG_BLK_VO :" " " " turn signal front
KALTUEBERWACHUNG_BL_MI : " " " " brake light
KALTUEBERWACHUNG_FL : " " " " high beam
KALTUEBERWACHUNG_KZL : " " " " number plate
KALTUEBERWACHUNG_KZL_LI :" " " "
KALTUEBERWACHUNG_NSW : " " " " foglights
KALTUEBERWACHUNG_NSL : " " " " foglights
KALTUEBERWACHUNG_RL : " " " " reversing light
KALTUEBERWACHUNG_SL_LHI :" " " " parking light(left)
KALTUEBERWACHUNG_SL_RHI :" " " " parking light(right)
K_BUS_FB_SPERREN :
KBUS_FUNKTION :K-Bus function.
K_BUS_FREI_OHNE :
K_BUS_FS_UNLOCK_300MS :
KEINE_L_R_SYNCHRONISATION :
KEINE_PARKLICHT_FUNKT :
KENNFELDKUEHLUNG :Test field.
KENNLINIE_AUTO_GEBLAESE_1 :Automatic air test line.
KENNLINIE_AUTO_GEBLAESE_2 :Automatic air test line.
KENNLINIE_AUTO_GEBLAESE_3 :Automatic air test line.
KENNLINIE_AUTO_GEBLAESE_4 :Automatic air test line.
KENNLINIE_GESCHWINDIGKEIT :Test line speed.
KENNLINIE_LWR_SENSOR_HI :Auto-leveling lights rear sensor regulation line.
KENNLINIE_LWR_SENSOR_VO :Auto-leveling lights front sensor regulation line.
KENNLINIENFELD2_AKTIV :
KENNLINIE_WAERMETAUSCHER :
KEY_MEMORY :
KEY_MEMORY_IHK : temperature set point stored from last time car used (key specific)
KEY_MEMORY_RADIO : stereo/cd/ipod-channel & volume stored from last time car used(key specific)
KINDER_SBE_1 :Kid seat?
KINDER_SBE_2 :Kid seat?
KISI_N_DEAKT_IM_CRASH :
KL50_ABSCHALT_AL : when key in start position stop low beams
KL50_ABSCHALT_FL : " " " " " " high beams
KL50_ABSCHALT_NSW : " " " " " " fog lights
KL_50_CAN : key in start position signal on can bus
KL_50_FUNK_AKT : pressing remote lock twice turns on interior lights
KL58_HELLIGKEITSSTUFE Interior lights brightness.
KL58_HELLIGKEITSSTUFE_FLC Interior light brightness automatic light control.
KLAPPEN OEFFNEN : Valves in after ignition
KLASSIF_DRIFT_ENA :
KLASSIF_LENKM_ENA :
KLASSIF_UEBERST_ENA :
KLEMME_15_LIEGT_AM_SG_AN : when ignition switch turned on
KLEMME_15_NOTWENDIG :
KLEMMENSTATUS :
KLEMME_50_UEBER_CAN :
KL_ENABLE ;Air coditioner
KLIMABETR BEI ZUEND EIN : airconditioning on when ignition on(key select)
KLIMATASTE_SPERREN :
KLS_BEI_AL_AKTIV
KM_SERVICE_INTERVALL :eek:il service interval distance 30.000_km
25.000_km
22.000_km
15.000_km
11.000_km
6.000_km
KOPFBAG_FOND_LINKS_1 :
KOPFBAG_FOND_RECHTS_1 :
KOMFOEFFNEN_SPERRE_KEY_IN :eek:pen/close convertible soft-top[or windows in coupe or sedan] by holding key open/closed position in door lock
KOMFORTFUNK_BEREICH_HEB :
KOMFORTOEFFNEN_FB_O_FH_HI :holding open button on remote opens front windows only
KOMFORTOEFFNEN_FB_O_SHD : holding open button on remote opens all windows without sun roof
KOMFOEFFNEN_SPERRE_KEY_IN :eek:pen/close convertible soft-top [or windows and sunroof in coupe or sedan] by holding key in open/close position in door lock
KOMFORTOEFFNUNG : remote opens doorlocks
KOMFORTOEFFNUNG_FB : convertible top opens by holding the open button on remote.[or windows & sun roof in coupe or sedan]
KOMFORTOEFFNUNG_BEREICH :
KOMFORTOEFFNUNG_VERDECK :Comfort opening convertible top
KOMFORT_POS_AUF :
KOMFORT_POS_ZU :
KOMFORTSCHLIE_FB_O_FH_HI : holding close button on remote closes front windows only
KOMFORTSCHLIE_FB_OHNE_SHD : holding close button on remote closes windows without sun roof
KOMFORTSCHLIESSEN_VERDECK :close convertible top by holding key in closed position in drivers door lock
KOMFORTSCHLIESSUNG : remote locks doorlocks
KOMFORTSCHLIESSUNG_FB : close convertible top by holding the close button on remote..Or [closes all windows & sunroof in sedan/coupe]
KOMPRESSOR_GEREGELT :
KOMPRESSOR_TRANSPORT_SICH :
KUEHLMITTELUEBERTEMP_CAN :coolant temp on can bus
KUEHLMITTEL_G_GRENZE ;Coolant G level
KUEHLMITTELNIV_FILTERZEIT :Coolant level filter time
KUEHLMITTELTEMP_ANZEIGEWI :Coolant temperature.
K_ZAHL_TACHO :speedometer calibration factor value
K_ZAHL_TACHO_KOMPL :speedometer calibration factor value
K_ZAHL_WEG : odometer calibration factor value
K_ZAHL_WEG_KOMPL: odometer calibration factor value
LAENDERVARIANTE_GT : ece will remove the "accept" screen on nav start up.
LAENDERVARIANTE_LSZ :Country version LSZ
LAENDERVARIANTE_RADIO :country setting for radio
LAMPENCHECK_GESICHERT :Light check verified.
LATENTWAERMESPEICHER :Latent-heat storer
LAUTSTAERKE_HINTEN : Volume in the Back
LAUTSTAERKE_TONGEBER :Amp volume e46/2
LAUTSTAERKE_VORN :Front volume.
LDA_BEI_UNTERSPANNUNG : increase idle rpm
LDA_BEI_VERBRAUCHER :Decrease idle rpm.
LED_ANSCHLUSS ;LED Connection
LED_HARDWARE :LED Hardware
LED_RUECKLICHT_OPTION :
LENKSAEULENMEMORY : steering column position memory
LENKSEITE_1 :Steering rack side
LENKSEITE_2 :Steering rack side
LENKSEITE_LSZ :Light switch side.
LENKSTOCKSCHALTER_ANALOG
LENKSTOCKSCHALTER_KLR :Steering switch?
LENK_UEBERSETZUNG :Steering rack ratio
LENK_UEBERSETZUNG_LO :Steering rack ratio low.
LENKWINKELKENNLINIE:Steering angle voltages
LEUCHTDICHTE_EXPO :Light concentration.
LEUCHTWEITENREG_AUTOM :Automatic light length
LEUCHTWEITENREG_DYNAM :Dynamic light length
LEUCHTWEITENREGELUNG :Light length regulation
LH_UND_NSW_NICHT_GLEICHZ :high beam and fog together when you flash
LICHTBEDIENEINHEIT :
LICHTWARNUNG : warning light
LINKSVERKEHR :Left turning adaptive headlights at stop if nicht aktiv
LL/RL : Left/right hand drive
LOAD_DUMP :
LOGIK_HA_SPERRE :
LOGIK_SCHALTER_RESERV :
LOGIK_SWBUNT :
LR_BEI_AL_DRL :DRL BS.?
LUFTFEDERUNG :
LUFTVER_AUT_B_ZUEND_EIN_1 :Air at fuse box?
LWR_AUT_EXTERN :automatic verticle headlight aim control
LWR_NEIGUNG_KONSTANTE :Headlight leveling constant tilt.
LWR_TREIBER_BEW :
LWR_TREIBER_ERR :
LWR_VORZEICHEN :Headlight leveling control.
MANUELLE_LWR :turns on manual lowbeam controller in lcm
MAX_BREMS_UNTERSTUETZUNG :
MAUT_N_ABBRECH_N_TUER_AUF :allows windows to be operated when door open if not aktive
MAUT_NUR_BEI_KL15EIN : allows windows to be operated when key is in on position.
MAUT_ZU_STOP_N_TUER_AUF :allows windows to be operated when door open if not aktive
MELDUNG_AENDERUNG_DIMMER :Sound by changing in dimmer.
MELDUNG_KATALYSATOR : signal catyltic convertor
MELDUNG_TASTER : pressing PDC button makes a sound
MEMORY_POS_ANFAHREN :Memory position by driving.
MEMORY_POS_SPEICHERN :Memory position safe.
MEMORY_SP_ABKLAPPEN_GM :tilting mirror position to curb or key memory setting
MEMORY_SPIEGELABKLAPPEN :tilting mirror position to curb or key memory setting
MEMORY_TIPP_BETRIEB :Memory one touch operation.
MILANSTEUERUNG :Watch out for this guy.
MIND_ANZ_ZYKL_TIPP_BLK;1-touch turn signal (1/3 blinks)
MIN_WT_SOLLWERT :
MIT_LIN_SCHALTER :
MIT_SRA_EIN_LENKSTOCK :
MIT_WISCHER_SERVICEPOS : wiper in service position -verticle
MOTOR_ABKUEHLZEIT :Engine cooldown time
MOTOR_ART :engine type
MOTORDIAGNOSE :
MOTOR_NOTPROGRAMM_CAN :
MOTOR_OELSTAND_PREDRIVE :Engine oil level at start up
M_TELEGRAM :
NACHLAUF_ZEIT_H : Wake up hours
NACHLAUF_ZEIT_MIN : Wake up minutes
NACHREG_DYN_SLOW :
NAVI_DIST_TO_JUNCTION :Show distance to junction.
NEIGUGSGEBER : tilt sensor for alarm
NG_MOTORVARIANTEN : NG Engine variation
NIVEAU_1 :Level 1
NLR_AKTIV :
NON-TELEMATIC_E-CALL :
NOTENTRIEGELN_HKL :Emergency open trunk.
NOTFUNKTION :emergency function in pdc
NOTLAUF :Emergency running.
NOTLAUF_IMMER :
NOTSTROMSIRENE : Emergency Power Siren
NSL_AH_US_OPTION : rear fog light
NSL_ALS_STANDLICHT :Foglights as parking light
NSL_ERSETZT_DEFEKT_BL :Foglights instead of defective brake lights.
NSL_R_NICHT_ANSTEUERN : rear fog light
NSW_KEIN_TASTER : front fog light
NSW_KL_50 : front fog light when starting
NUR_EIN_TONGEBER :
NUR_KL15_BETRIEB : pdc operation on when key in on position
N_VER_B_ERN_GESCHW_SCHWEL :
OEFFNEN_AUS_GEHOBEN :
OEH_POWER_CONF_0 :
OELNIVEAU_M3 :Oil level M3
OELST_SENS_DEF_WARNUNG :
OELSTAND_MOTOR_CAN :
OFFENE_FENSTER :Windows are open.
OHNE_CENTERLOCK_0 :Without center-lock
OHNE_FERNBEDIENUNG_1
OHNE_FERTIGUNGSMODE :
OHNE_FH_BF_HINTEN_0 :
OHNE_FH_BF_VORNE_0 :
OHNE_FH_FA_HINTEN_0 :
OHNE_GIERRATE :
OHNE_IB_0 :
OHNE_INTERVALLBETRIEB :
OHNE_POWERDOWNMODE :
OHNE_SERVICEMODE :
OHNE_SRA_0 :
OHNE_TRANSPORTMODE :
OHNE_VA_ZEITEN_0 :
OHNE_WISCH_BEI_WASCH
OPT_ENTRY_HELP :
OPTIMIERTE_SCHLIESSFKT
PANIC_CLOSE :holding the close on remote activates alarm
PANIC_FREIGABE_CAS :
PANIC_FREIGABE_KL15 :
PANIK_MODUS :panic mode
PARK/NEUTRAL_EINGANG :clutch safety switch bypass & start allowed by ews in park or nuetral
PASSIVES_DWA_HORN :
PAUSE_ZW_SPRITZIMPULSE :pause between spray impulses.
PDC_AKTIV/DEAKTIV :rueckwaertsgang-pdc on/off with reverse weg_geschw -PDC turns off at specific speed
PDC_EIN_BEI_KL15 :pDC on with ignition
PDC_SCHALTER :pdc switch
PHASE_AUS_GEDIM_LICHT_AUS :
PHYSIOLOGIEANPASSUNG_1 :
PIKTOGRAMM_ERWEITERT : grafic for signalling the status of lights doors blinkers etc.(bulbs)
PIN_5_10_AHM_ERS_FU_GESP :
PIN5_10_BFD :
PIN_20_ALS_FRA_LI_VO_2
PIN_29_30_AHM_ERS_FU_GESP :
PIN29_30_BL_NSL :
PIN_37_ALS_FRA_RE_VO_2 :
PM_SCHALTERBLOCK_FOND :
PM_SCHIEBEHEBEDACH :
PM_SITZMEMORY : driver seat memory
PM_SITZMEMORY_BEIFAHRER : passenger seat memory
POWERDOWN_ZEIT :powerdown time
PORTABLE_BT :
POTI_DIMMER_INVERS :
POTI_LWR_INVERS :
PREFIT_SIM_ENABLED :
PREDRIVE_RPA :
PRE_MSR :
PRE_VLABS :
PROGRAMMPARAMETER_LSZ_1 to 13:ece (european)or us (usa)
PULS_TIME_OPTION
PWM_ANSTEUERUNG_AL :Low beam plug.
PWM_ANSTEUERUNG_BIXENON :Bi-xenon plug.
PWM_ANSTEUERUNG_BL :Brake light plug.
PWM_ANSTEUERUNG_BL_MITTE Third brake light plug.
PWM_ANSTEUERUNG_BLK_HI :
PWM_ANSTEUERUNG_BLK_VORNN :
PWM_ANSTEUERUNG_FERNLICHT :
PWM_ANSTEUERUNG_KZL :
PWM_ANSTEUERUNG_NSL_LI :
PWM_ANSTEUERUNG_SL_LI_HI:
PWM_ANSTEUERUNG_SL_RE_HI :
PWM_ANSTEUERUNG_SL_VO_LI :
PWM_ANSTEUERUNG_SL_VO_RE ;
PWM_ANSTEUERUNG_SL2_RE_HI :
PWM_ANSTEUERUNG_SL3_LI_HI :
PWM_ANSTEUERUNG_SL3_RE_HI :
PWM_ANSTEUERUNG_ZUSTZBLK :
PWM_WERT2_ALS_BL_AUSGANG Brake light output.
PWM_WERT2_ALS_SL_AUSGANG Parking light output.
PWM_WERT2_BLK_ZUSATZFKT Blinker additional effect
PWM_WERT2_FL_BIXENON : wert_02=default
wert_01=bixenons&halogen as high beams together
PWM_WERT2_NSL_ZUSATZFKT :Fog light additional effect
PWM_WERT2_SL3_ZUSATZFKT :parking light 3 additional effect.
QUIT_AKUST_DAUER_10/20/40_MS: How long the alarm beeps
QUIT_AKUST_ENTSCH : alarm beep on unlock (two beeps)
QUIT_AKUST_SCHAERF : alarm beep on lock (one beep)
QUIT_AKUST_SCHAERF_KLAPPE :acoustic arming doors closed
QUITT_A_TEMP_WARNUNG_LSS;temporary ice warning
QUITT_BLK_SICHERN;Vis.lock.,without anti-theft alarm syst.
QUITT_BLK_ENTSICHERN;Vis.unlock.,without anti-theft alarm syst.
QUITIMP_SICHERN/ENTSICHER;Vis.lock.,without anti-theft alarm syst.
QUIT_OPT_ENTSCH : visualy acknowledge remote un-locking (two flashes)
QUIT_OPT_SCHAERF : visualy acknowledge remote locking (one flash)
QUIT_OPT_SCHAERF_KLAPPE :visual arming doors closed
RCC_UHR :
RCC_WECKZEIT : waking time?
RDC_ALARM_VIA_HFK : tire pressure control alarm
RDC_ALARM_VIA_KBUS :
RDKS : tire pressure monitor system
RECHTS_LINKS ;Right-left.
RECHTSVERKEHR :right turning adaptive headlights at stop if nicht aktiv
REFERENZLAUF_LWR_KL15 :
REGENSCHLIESSEN : rain sensor closes sunroof only with key on kl15/kl30
REGENSCHLIESSENTILT :" " " " " "
REIFENCONTR_INAKTIV : melden -> nicht_melden turns off 'tirecontrol inactive' message
REIFEN_DEFEKT :
REIFENDRUCKWARNSYSTEM : tire pressure warning
REIFENTOL_ABGLEICH_ASC :ACS Balance tolerance
REIFENTOLERANZABGLEICH :Balance Tolerance?
RFS_AH_OPTION : reversing light
RL_INNEN_BLINKT : tail light
RR_SCHALTER :
RUECKFAHRGONG : reverse alarm sound
RUECKLICHT_INNEN_FEHLT :
RUECKWAERTSGANG_WARN_MED :Reverse warning type. piezo / gong
RUECKWAERTSGANG_WARNUNG :Reverse warning.
SAETT_TIMER_SCHLECHTWEG :
SB_ANHEBEN :
SBE1_STATUS_VERZ_1 :
SBR_US : seat belt reminder
SCA_HECKKLAPPE : soft close tail gate
SCHAERFEN/ENTSCHAERFEN : [schloss_und_fernbedienung] key and remote arm/disarm the alarm system
SCHALTER2_BL : switch #2 brake light second switch
SCHALTER_BREMSL_SCHWELLW :Brake light switch increase value.
SCHALTER_BREMSL_WARTEZEIT :Brake light switch wait time.
SCHALTER_R_GANG :
SCHALT_KRITERIUM_EWS_3 :Immobilizer switch criteria.
SCHEIBE_ABSENKZEIT : Window lowering time.
SCHEIBENABSENK_OHNE_EKS : Window opening without EKS
SCHEIBENINTENSIVREINIGUNG :
SCHIEBEHEBEDACH_TIPP_AUF : One touch sun-roof open
SCHIEBEHEBEDACH_TIPP_HEB : " " " " raise
SCHIEBEHEBEDACH_TIPP_SENK : " " " " lower
SCHIEBEHEBEDACH_TIPP_ZU : " " " " close
SCHEINWERFERREINIGUNG : wash headlights every 5th time the windscreen gets washed when active
SCHRITTMOTOR_UEBERLAUF : step motor overflow?
SECOND_HARDKEY :
SEL_ZV_SENDER_1 :
SENSOR_REGEN :rain sensor
SENSOR_VALEO :Wiper sensor.
SEQ_M_GETRIEBE :smg
SERVOTRONIK :
SHD_ACTU_ALLOWED : sunroof module
SHD_CFL_ALLOWED :
SHD_CLOUD_ALLOWED :
SHD_RESTARTALLOWED :
SHD_RRD_ALLOWED :
SHD_SKB_OHNE_KL_OE :
SHD_SKB_OHNE_KL_SCH :
SHD_TMON_ALLOWED :
SIA_RESET_KI_TASTE : Coding maintenance interval
SICHERHEITSFAHRZEUG : security vehicle
SICHERHEITS_FZG :
SIDEBAG_FOND_LINKS_1 :
SIDEBAG_FOND_RECHTS_1 :
SIDEMARKER_US :us mode parking lights
SIM_IN_TELEMATIK_READER :
SITZMEMORY_VERBAUT : seat memory obstructed
SL_3_ERSETZT_DEFEKT_BLK :parking light 3 in case of blinker failure.
SL_ERSETZT_DEFEKT_BL ;Parking lights in case of brake light falure.
SL_ERSETZT_DEFEKT_BLK :parking light in case of blinker failure.
SL_INNEN_ALS_TWL : parking light
SL_VO_ANSTEUERUNG : front parking lights activated
SL_VORNE_ALS_ZUSATZ_BLK : front parking light as aditional turn light
SMG_S_ANZEIGE :
SOFT ON/OFF : gradual fade on/off of the interior lights
SOFTWARE_VERDECK :Convertible software
SOLLWERT_KORREKTUR_1 :flaps setpoint value correction
SONDERFHZG_MIT_WSA :
SOS_ACTU_ALLOWED :
SOS_CFL_ALLOWED :
SOS_CLOUD_ALLOWED :
SOS_RESTARTALLOWED :
SOS_RRD_ALLOWED :
SOS_SKB_OHNE_KL_OE :
SOS_SKB_OHNE_KL_SCH :
SOS_TMON_ALLOWED :
SP_BEWERT_OD_ALC_NSW_AUS :
SPERRDIFFERENZREGELUNG :
SPERR_VENT_TEST :
SPERR_WLM_TEST :
SPERRZEIT_KL_R_AUS_0.2_S :
SPIEGELEINKLAPPEN : folding mirrors
SPIEGELABKLAPPEN : folding mirrors
SPIEGELHEIZUNG : heated mirror
SPIEGELHEIZUNG_VERBAUT : heated mirror obstructed
SPIEGEL_KOMFORT_EINKLAPP :folding mirrors by key remote
SPIEGELMEMORY :adjustible mirror position memory.
SPIEGELMEMORY_GM :adjustable mirror position memory.
SP_MOTOR_BEWERTEN :
SP_MOTOR_F_EINTRAG :Schematic motor error input
SP_MOTOR_STOP :
SPG_NACHREGELUNG :
SPG_NACHREGELUNG_LANGSAM :
SPG_NACHREGELUNG_ZUSATZ :
SPRACHE : Language selection
SPZ_PROG :
SRA_L322_RELAY :
SRA_MIT_WASCH_WISCH_SW
STANDHEIZUNG : stationary heating[webasto deisel]
STANDHEIZUNG_KONZEPT
STANDLICHT_ALS_BREMSLICHT :parking lights as brake lights. nicht_aktiv
STANDLICHT_ALS_NSL_LINKS :parking lights as fog lights left. nicht_aktiv
STANDLICHT_ALS_NSL_RECHTS :parking lights as fog lights right.
STANDLICHT_VORNE : angel eyes
STANDLUEFTUNG : park heating
STANDRUECKSCHALTUNG :auto wipers stop when car stopped
STATUS_LESEN :
STEIG_KL58_T_PER_D :
ST3_SCHWEL:
TACHO_SKALA_ENDWERT :Speedometer scale end value
TAGFAHRLICHT : daytime running lights[dimmed high beam]
TAGFAHRLICHT_ECE : Daytime running lights[low beams]
TAGFAHRLICHT_DAN : " " " (danish?)
TAKTUNG_HHS :
TAKTEN HIGH LOW ANZEIGE : Clocks High Low Announcement
TAKTUNG_IB :
TAKTUNG_VERBRAUCHERABSCHA :
TANK_KENNLINIE ;Tank capacity calibration 60_l_literskala
TANK_MITTLUNGSZEIT :Fuel gauge measuring frequency 5_sec
TANK_SCHWELLE_AUF/AB :Reserve light 6_l
TANK_SCHWELLE_RESERVE :Reserve threshold 8_l
TANK_SICHERHEITSFAKTOR :Tank security factor 1.3
TANK_VORHALT_REICHW :Tank range
TASTE_UEBER_CAN :
TASTER_NSL : rear foglight sensor
TASTER_NSW : front " "
TASTER_NSW_NSL : front & rear foglights sensor
TAXI_ENABLE :Taxi mode.
TELEMATIK :
TELEGRAMM_ZEIT_ZYKLUS :Telegram time cycle.
TEMPCFLUSEOUTER :
TEMPCFLUSESENSOR :
TEMP_DRUCKPUMPE :temperature of convertible Pump
TEMPERATUR_EINHEIT : Temperature Unit (C/F) choice of grad_c or grad_f
TEMPERATUR_GRENZE :Temperature border.
TEMP_FOND :
TEMPTMONUSEOUTER :
TEMPTMONUSESENSOR :
TESTBETRIEB :
TEST_OD_ST2_OHNE_NSW
TNK_DECKEL_WARNUNG : fuel tank cover open warning
TP_FUNKTION : radio ?
TRAKTIONDIFFERENZREGELUNG :
TREIBER_BEWERTEN :Driver evaluation.
TREIBER_F_EINTRAG :
TREIBER_STOP_OD_ALC_RE_OK :
TRIGGERSCHALTER_1 : trigger switch
UEBERLAUFSCHRITTE_BEI_0 :
UEBERLAUFSTEPS_BEI_100% :
UEBER_ROLLSENSOR_1 :
UEBERSPANNUNGSSCHUTZ :eek:ver voltage protection
UEBERSPG_ABSCHALT_58G ;
UEBERSPG_ABSCHALT_BL :
UEBERSPG_ABSCHALT_NSL :
UEBERSPG_ABSCHALT_RFS :
UEBERSPG_ABSCHALT_SL :
UEBERSPG_ABSCHALT_SL_H :
UEBERSPG_ABSCHALT_SL_HI :
UEBERWACH_FENSTER_BF_HI :
UEBERWACH_FENSTER_F_VO :
UEBERWACH_HECKSCHEIBE :
ULF_EIN_AUS :eek:ver voltage protection
UMLUFT MEMORY : Circulating Air Flap Memory (remembers if re-circ is on after shutdown)
UNTERSTEUERUNGSALGORYTHM :
US_CALL_SERVICE_CENTER :
USE_SOS :
VA1_SPERRE_BEI_FEHLER :
VA_2 :
V_ABHAENGIG :
VARIANTE_LSZ : LSZ Version.
VENTIL_HALTESTELLUNG :Valve holding position
VERBRAUCH D1 : Consumption units(L/100Km,mpg-Eng,mpg-USA,Km/L)
VERDECKKLAPPE_VORHANDEN :
VERL_ALARMZEI_WAEHR_ALARM :
VERRIEGELN_AUT_AB_X_KMH : automatic central locking at above X KMH
VERRIEGELN_AUT_NACH_2_MIN : automatic central locking is re -locked after 2 MIN if you dont open a door
VERRIEGELN_SITZLEHNE_FA_1 :auto locking seat back[coupe & cabrio]
VERRIEGELUNGSSCHWELLE :Automatic central locking speed [select X value]
VERZUG_ENTR_HECKKLAPPE :
VERZUG_PANIK_MODUS_0.2_S :Delay panic mode 0.2 seconds.
VOLUMENDURCHFLUSSPARA_2 :
VORGLUEHEN/KAT_HEIZEN_CAN : pre heat?
VKBODEN_ERKENNUNG :
VMAX_BESCHLEUNIGUNG :Accelleration limit
VMAX_BREMSEN :Brake limit
VOLUMENDURCHFLUSSPARA :Volume by flow parameter
V_VAR_SPERRE_BEIKLAPPEN :Variable lock at work?
WARMUEBERWACH_ZUSATZ_BLK: warm testing bulbs in turn signals
WARMUEBERWACHUNG_AL : " " " " low beams
WARMUEBERWACHUNG_AL_L : " " " " low beams
WARMUEBERWACHUNG_BL_MI : " " " " brakes
WARMUEBERWACHUNG_BLK_HI : " " " " rear turn signals
WARMUEBERWACHUNG_BLK_VO : " " " " front " "
WARMUEBERWACHUNG_FL : " " " " high beams
WARMUEBERWACHUNG_KZL_LI : " " " " number plate
WARMUEBERWACHUNG_NSL_LI : " " " " fog light.
WARMUEBEWARMUEBERWACHUNG_RL_LI :" " " Warm testing reverse Left?
WARMUEBERWACHUNG_RL_RE: " " " " Warm testing reverse Right?
WARMUEBERWACHUNG_SL_LHI : " " " " tail light
WARMUEBERWACHUNG_SL_RHI : " " " " " "
WARNBLINKER :einfachimpuls -single flash or doppelimpuls -double flash
WARN_MEDIUM_AUSSENTEMP :Outside temperature warning piezo
WARN_MEDIUM_GURT :Belt warning piezo
WARN_MEDIUM_PARKBREMSE :parking brake warning piezo
WARN_MEDIUM_RDKS :park distance control warning piezo
WARN_MEDIUM_ZUENDSCHL :Ignition warning
WARNUNG_GESCHW_LIMIT :Speed limit warning
WARNUNG_MOTOR_OELSTAND :eek:il level warning
WARTEN_SCHEIBEN_ABGESENK :Wait to lower windows before opening convertible top
WAKEUP_GENERELL ;
WAKEUP_TAGE :Wake up day
WAKEUP_ZEIT :Wake up time
WASSERPUMPE :water pump?
WASSERSTOFF_FZG :
WEG_DURCHSCHNITT :Road average units
WEG_EINHEIT : Distance unit ( mls or km)
WEGFAHRSICHERUNG_AUTOM :vehicle immobilise
WEGSIGNAL_SERVO_ABS :
WE_MODE :
WISCHER_RUECK_GESCHW :Rear wiper speed.
WISCHERINTERVALL: wiper interval choice
WISCHERMOTOR_RSK :wert_01 cars with the wiper park signal pulled to GND when the wiper arms are not parked [E53]
wert_02 cars with the wiper park signal pulled to GND when the wiper arms are parked.[E46]
WISCHERPOTI : wiper timing
WISCHER_VOLLEND_KLR_AUS ;
WINDSCHOTT :
WINDSCHOTT_OPT :
XDT :
XENONLICHT_ZUEND_OPTION :xenon light ignite
XENON_TEST :Xenon test.
XENON_TIME :Xenon time.
XENON_TIMEOUT :Xenon timeout.
ZEIT_BIS_AUTOM_SPERREN ;Time before auto-block.
ZEITDAUER_BIS_ABSCHALTUNG :Time until turn-off.
ZEIT_EINHEIT : Time unit (12H /24H)
ZEIT_KALT_PULSE :Time cold pulse.
ZEIT_KALT_PULSE_QUICK :Time quick cold pulse.
ZEIT_KALT_RUNDEN :Time cold rounds.
ZEIT_TUER/SCHLIESSZEIT :Door lock time
ZKE : central body electronics
ZUHEIZUNG : heating for diesel engine
ZUENDSCHL_GONG_R_EIN :
ZUENDSCHLUESSEL_KBUS :
ZUENDSCHLUESSEL_WARNUNG : beep & display when door opened to warn key left in Ignition
ZUSATZWASSERPUMPE :
ZUWACHS_TASTVERH_KL_58G :
ZV_AGGREGATE_TYP : central locking system
ZV_BEDIENST_BT_DISABLE :
ZV_ENTR_SCHL_BEI_DWA_AKT :
ZV_SELEKTIV : unlock drivers door only if [aktive] or all doors if [nicht aktive] key selectable
ZV_VR_BEDIENSTELLE_HECK :
ZYKLUS_KALT_RUNDEN_QUICK :Cycles cold rounds quickly.​
hye guys, anyone know where can i download a latest daten file for ncsexpert?
