Halogen to Xenon upgrade, Quad projector, FX-R retrofit
No bro, it make different!
Park your car as near as u can to the wall and switch on the light, u can see "+" shadow in your light.
If the electrode is facing down, then the "+" is gone.
ya, i think i see a bit of that. but we also noneed to cut the bracket. i rather cut my bulb to make it both side (up and down the same size).
bro BMW7833,
if we did not turn the electro down is there anything different other than when our car go near will have a + ?
It is easier to cut the stopper than cut the bulb base for me.
We need to stick the bulb base to the socket, if we cut the bulb base, then the surface is reduce so it might not secure when there is pothole. I have the experience which the bulb fall down before. We need to use the super duper glue to get them stick together otherwise u will see the light is shaking (in case your headlight adjuster is not broken).
sewell;713343 said:
bro BMW7833,
If we did not turn the electro down is there anything different other than when our car go near will have a + ?
You will still see the shadow even your car is not near to any object. The "+" mark become bigger so the shadow still there.
Sewell, do u have any picture at nitetime how the light pattern throw out from your car?
bro, sorry to tumpang your threat.
below is how my car fitted with the Cheap Taiwanese HID.
this is the final look while fitted with HID bulb
the left ballast and right ballast
the HID, which bro,BMW7833 ask me to turn ( this is what i did)
light from outside (6000k)
from the cabin this is how it look like.
feel free to comment
Bro sewell, no problem. You have two HID ballasts, the other for fogs?
yaya, the thicker 1 is for fogs. fogs come with HID when i bought my car.
waiting bro BMW7833 to comment
Nothing to comment la bro..they are nicely fitted..:4:
I will upload my pic later with the new 5000K bulb.
Finally bought some proper D2S bulbs to replace the old one. The old one produces different color and tilted so the beam is not as composed. These are Philips 85122+
beam before
beam after
different color before
now
another picture on the road by Bro BaddBoyz3 before changing bulb
Nice mod... Would love to have those rings & the quad projectors!
aidilj;737802 said:
Bro BlackCat, rings/angel eyes is a must!
I have always had this phobia of doing any mods involving the electronics of the ride... Sigh!
I know its safe somewhat... but, ish... just afraid it might screw something up :(
You can do it Bro!
BlackCat;737905 said:
Bro, discussion aka racun session item noted for the 4/5th May :)
Noted bro, just some pictures to help you sleep at night
Bro... Ni lagi buat TAK BOLEH TIDO!!! Hehehehe
Thanks for the pics... :)
Edwardpua;739219 said:
Bro Aidil, Wat type of capacitor u used for angel eye for flirking problem? Thanks.
Bro, it's still electrolytic. Not sure about the value, but to choose one make sure it is higher than 12v. The bigger capacitance the better >470uF. And place it as close as possible to the LED
