aidilj;616319 said:Solo, good question, I recommend the one from Cliptec like in my picture earlier. It uses Prolific chip instead of FTDI and all the pins on DB-9 are properly implemented. Totally recommend Cliptec.
aidilj;616319 said:You can't use EDIABAS/INPA interface with PAsoft scanner because PAsoft has microcontroller in it and it speaks a proprietary language.
aidilj;616317 said:Nice! Please update when you are able to fix the mouse problem.
I have the TIS .iso file, installed it as standalone not part of DIS. Yup agreed there's a lot of info in it, wondering how would it integrate into DIS..
VAG-COM is USB which uses the FTDI USB-to-serial chip, the community essentially hacked the circuit for proper ignition detection.
On another note, I'm wondering what kind of industry are you in...?
aidilj;616411 said:Yes noticed that but didn't try to install, I bet it's the same method because it is in .iso format. I also only have 2007 TIS, again just wondering how would it integrate with DIS. Maybe with an error message, there's a TIS shortcut button to go to the page.
aidilj;616763 said:I think you are talking about the diaghead emulator. You can give that a try.. not sure about the sttings though. You need the diaghead emulator when you are supposed to use GT1 with the actual yellow diaghead but only have a serial OBD interface.
aidilj;616324 said:oops picture is not from this thread, its from the carputer thread. Here you go.
Left is EDIABAS/INPA interface, right is ELM327, offset is the USB-to-serial
IanDaddy;617021 said:Yes, the procedure is the same. I installed from CD so no need to use Daemon Tools, I have to change the VM settings for the CD-rom. Install thru the Administration menu.
In DIS the CD is labeled 2007 but when I look at the documents and check the version in DIS it says something else. Need to explore a bit.
Yes, many have problem using the Serial to USB and I think it is caused by the length hence signal strength/integrity. So, knowing the limit of the cable will help as I want to get a serial to USB adapter as well.
IanDaddy;617004 said:Installed TIS into DIS 44 last night from CD from a friend.
aidilj, what is the max length for the serial cable for Ediabas cable ?
M3addict, try ebay or many of the chinese online sites.
