e36 parts & maintenance
wah muscle bro; you can really spend money la cool ....
anyway i just change my absorber to black bilstein all round
total
parts ; 1010
labour plus alighment ; 100
total bill; 1110
Hey guys,
Just changed the power steering pump of my baby, at BM World near bandar tun razak. Here's the damaged:
1. Power Steering Pump (2nd hand) - RM550
2. Power Steering Fluid - RM44
3. Labour Charges - RM80
Going to change the lower arm bushes and related stuffs later today.
The list keeps on growing....
1. Aircon tensioner bearing - RM50
2. Aircon belt (ori) - RM90
3. Centre chrome grill - RM120 (a low down person wanted to snitch it but broke it)
:beaten: :beaten:
Rebuild fore/aft motor for electric seat (driver's) E36= RM180/-
BM Tech, USJ19
1st time spending on repairing and is not cheap for my 1st time..
1) Fuel Pump (new set) Rm 480
2) Fuel Pressure regulator New Set Rm 350 damn it just a small little thing cost that much
3) O2 sensor new set Rm 420
Labour charge Rm150
BM World Motor Works
Labour charge Rm150
There's always a first time, and more to come also. :D I have already spend so much on repairing since I got my baby 2 months ago. I went to BM World too..
Yeah BM world they r fast and confident but i m not sure in terms of price is it the highest also ??
I only know of BM World a few weeks back. My best friend introduce to to me. He has been going there for years, and he mentioned they don't over charge. Anyway, the mechanic (Ah Wai) is indeed confident, and honest.
I need to change the rear shock absorber and disc pads soon..damn.. I just spent over RM800 on the lower arm bush, rod, ball, the related stuffs...
Oris318
By when u know that u need to change lower arm bush,rod ball join ect ect i mean the chassis thing... How u know u need to change and also how u know is going to tear off ?? Wat kind of signal that i need to look into ....
Originally posted by ZeNeGeR@May 29 2005, 02:21 PM
Oris318
Jack the car up, move the joints(which are movable)..excessive movements or visible cracks are bushes that are worn.
Oris318
Zenegar,
I only discovered after they jacked up the car.. :D Anyway, I believe Musclehedz had already answer your query.
When you send your car for repair (at BM World) they would have tell you what are the parts have worn off and need to change. They throughly checked my car the last time I went there. Hence, I discovered the disc pad and absorber need replacement.
i got this pic that I took when I replaced my kaput-ed airconditioner cooling coil, expansion valve.
For your reference only. This is for the E36. Some fabric on the top right corner is the worn out dashboard sponge.
Just in
24 Tappets - RM2037
Tappet holders - RM854
Gear change sensor - RM150
Condenser fan (used) - RM550
Total : RM3591
:cry:
Need help from you sifus, is this expensive?
Originally posted by ZeNeGeR@Jun 5 2005, 01:33 PM
hey bro donkz36 wat is tappet ?? why so expensive ?
What he meant was the Hydraulic Lifters. One unit cost in the region of rm80-rm100 depending on where you get it from.
Originally posted by donkz36@Jun 3 2005, 05:56 PM
Just in
24 Tappets - RM2037
Total : RM3591
:cry:
Why did you change the lifters? making noise?
Those are the hydraulic lifters and yes they are expensive . 24pcs work out to somewhat close to 2k plus .
Some are lucky that change of oil grade may be able to cure the sound . In some cases it doest work, The pressure in these lifter will deteriorate .
Mine started giving noise sbt year and a half ago. Changed oil grade it went off.
Recently it started coming back again . Once in a while during cold-start. But i am due for oil change . Lets see what happens after that .
cheers :D
cheers :D
friend...mind telling me what oil rating u use? mine is starting to make noise....I will only change the lifters as the last resort. Thanks.
