[SIZE=10.5pt]Good day team.[/SIZE]
[SIZE=10.5pt] [/SIZE]
[SIZE=10.5pt]Below are the updates from my Service Log.[/SIZE]
[SIZE=10.5pt]Engine Model : N42[/SIZE]
[SIZE=10.5pt]Place Done : WP Auto. Albert’s Garage.[/SIZE]
Valve Seal Job (done on 12th November 2014)
[SIZE=10.5pt]Parts Changed:[/SIZE]
[SIZE=10.5pt]Valve Cover Gasket (Valvetronic) RM195[/SIZE]
[SIZE=10.5pt]Valve Seal RM148[/SIZE]
[SIZE=10.5pt]Timing Chain Tensioner RM178[/SIZE]
[SIZE=10.5pt]Timing Rail (small) RM98[/SIZE]
[SIZE=10.5pt]Timing Chain RM210[/SIZE]
[SIZE=10.5pt]Vacuum Pump RM580[/SIZE]
[SIZE=10.5pt]Sensor Oil Ring 6pcs RM48[/SIZE]
[SIZE=10.5pt]Plug Oil Ring RM8[/SIZE]
[SIZE=10.5pt]Top Connector Hose RM98[/SIZE]
[SIZE=10.5pt]BMW Coolant (1 bottle) RM40[/SIZE]
[SIZE=10.5pt]ATF Oil GM (8 liters, 1 liter RM48) RM384[/SIZE]
[SIZE=10.5pt]AT Oil Filter GM RM78[/SIZE]
[SIZE=10.5pt]AT Gasket GM RM168[/SIZE]
[SIZE=10.5pt]Workmanship RM680[/SIZE]
[SIZE=10.5pt]Total Cost RM2900[/SIZE]
[SIZE=10.5pt][/SIZE]
[SIZE=10.5pt]I also had to remove the Catalytic Converter as it got stuck from all the engine oil that was leaking. [/SIZE]
[SIZE=10.5pt]Removing Cat Converter [/SIZE] RM330
Massive improvement was felt after the valve seal change was completed. Response felt solid immediate. Truly a joy to drive after the service was done.
