e36 parts & maintenance
Just did this repair after the brake and steering judder when brake is applied.
Parts cost
1. control arm bush - 2 nos. - RM194
2. Front brake disc - 2 nos - RM360
3. Front brake pad - 1 set - RM210
4. Disc Bolt - 2 nos - RM RM14
5. Brake Sensor - 1 no - RM40.
Labour
1. Replace L/H & R/H Control Arm Bush - RM45
2. Replace Front Brake Disc & Pad - RM40
Others
1. Fuel Filter - RM60
2. Hose clip - 2 nos - RM8
3. Labour for replacing filter RM25.
ouch RM1000+
have to makan roti for a month.. :cry: :cry:
Result:
Steering no longer judder when brake is applied.
No more sound when brake is applied.
Alignment slight off. Need to send for alighment
For your info, I have changed the control arm two time at others farked up tires shop. Last about 6 months each time. Hope this time, the repair work will last longer. (Seem to be based on the procedure that my regular workshop did the work. Proper extraction tool instead of using hammer)
I know how it feels Jarance. After going through my maintenance list, I found out that RM3k+ is for the repair of my aircon....damn. :(
And I hope my next E34 would not be that bad because I am taking my time getting one good specimen.
Parts cost
Labour
Others
ouch RM1000+
Result:
Jarance i thought you already bah liao paying for your maintainance bill.
Just did 30/4/05 my repair at Hyper Rev Pandan Indah
1) Gearbox Box Oil Sam Gasket-Rm58
2) Gear rever Oil Seal- Rm45
3) Labour for this 1-2 Rm65
4) Fan Belt very noisy replace Rm 75
5) Labour Charge for this Rm15
total Rm 258
Routine 5,000 km service;
1. Oil Filter RM29
2. Castrol Magnatec (semi-Synth) RM80 x 2 4Litre bottles
3. Labour RM25
Replace front Brake disc and pads
Ori BMW Disc RM310 x 2
Ate Pads = RM170
Sensor = RM30
Labour = FOC (coz already included in the mark up of the parts)
ATE initial bite not good, so beware
a bill that i was charged after almost 1 year for something that was not done ... wTF
Spark plug ---- RM 60
Engine flusg --- RM 22 ( never had used this B4 but being charged )
Engine oil ---- 4.5L RM 157.50
Oil filter ----- RM 30
Air filter ----- RM 58
Oil treatment ---- RM 25 ( not sure what is this )
Others
boonet damper --- RM 68 X2 = RM 136
Timing belt --- RM 95
Fan belt --- RM 15
Rear Axle oil --- RM 20
G/Box gasket --- RM 38 X 2 = RM 76
G/Box Filter --- RM 55
G/BOx oil 7 ltrs --- RM 140
Labour RM 80
My bill for today :-
Knock Sensor - RM220 x 2
Fuel Filter - RM75
Manifold Gasket - RM100
Vacuum Hose - RM20
(Glasurit) Painting front bumper, front bonet, front grille pannel, 4 pcs rim and polishing whole car - RM1000
Last month did the steering rack overhaul as it had a little roughness when you begin to turn the steering wheel at very low speed. Also did the suspension maintenance front & rear.
Overhaul power steering rack- RM650
1pc power steering filter- RM92
Front Suspension:
2pcs lower arm ball joint- RM196
2pcs lower arm bush- RM194
2pcs absorber mounting- 194
2pcs upper spring pad- RM76
2pcs lower spring pad- RM56
Rear Suspension:
2pcs absorber mounting- RM116
2pcs absorber damper- RM84
2pcs absorber cover- RM48
Labour for all above - RM190
Total Bill - RM1944...........very big pain, wallet still burning.
Fuel Filter - RM75
Vacuum Hose - RM20
those knock sensor are cheap, where did you get them from.....
here's my journey to alaska in E36.
Cooling coil (copper) - RM390
Receiver/dryer - RM190
Expansion valve - RM139
Blower sponge/dashboard sponge - RM160
R134a gas - RM40
O-ring - RM15
Labor (aiyo.. gotta bring down dashboard) - RM350
Total = RM1,275. Did it at Naidu. Total fixing time: approx 5 hours.
No more squeaks from the dash. Aircond is so coooooold. Brrrrr.
Alright, finally...here's my bank account damage:
- Repair gearbox - $2000.00
- Engine flush - $54.00
- Engine oil - $259.00
- Spark Plug - $132.00
- Fan Belt - $118.00
- Rear brake pad - $205.00
- Front brake pad - $240.00
- Oil filter - $45.00
- Coolant - $30.00
- Coolant sensor - $125.00
- Rear foot brake shoe - $176.00
- Oil treatment - $50.00
- A/C micro filter - $110.00
- Gearbox gasket - $104.00
- Gearbox filter - $78.00
- ATC oil - $59.00
- ATF oil - $300.00
- Rear axle oil - $ 35.00
- Brake fluid - $130.00
- Front brake hose - $180.00
- Rear brake hose - $170.00
- Accelerator bush - $46.00
- Bonnet Damper - $144.00
- Carbon Container Filter - $280.00
- Cover cap - $20.00
- Door trim clips - $12.00
- Instrument cluster bulb - $30.00
- Petol additive - $80.00
- Fuse - $45.00
- Long centre joint bush - $120.00
- Exhaust O ring - $76.00
Bro..few items needs ur clarification..just curious and some info for ur comparo....
1. Oil treatment - what's this for?
2. microfilter 110.. This is a bit expensive..I got it for RM50 onli from BA parts..
3. ATC oil - what's this?
4. front and rear brake hose.. standard or those performance hose? ie. pro-rs
5. brake fluid.. Just refill or complete flush? How many ltr? .5L cost about RM60 from BA parts..
6. Carbon Container Filter - what's this?
- Coolant - $30.00
- ATC oil - $59.00
- ATF oil - $300.00
- Fuse - $45.00
Wahhh!!! :eek: Damn expensive your bill......
I just took over the car from previous owner which explains the hefty bills.
The carbon container filter is for the fuel and engine breather.
muschle...seems like u hv been billed for many items that you don't even know what it is? hmmm...:)
On item 2. Microfilter, ya...OEM, came with a box too..
Ok..now it's time to enjoy the ride...vroomm vroomm...:D
- Coolant - $30.00
- ATC oil - $59.00
- ATF oil - $300.00
- Fuse - $45.00
Rm 5453 for ur bill ? Wat about labour charge if i were u i will sell the car hahahah
