anxious
- Dec 9, 2004
- 1,363
- 48
Model Year 91 and Older
Model Year 92 - 98(including 99 E36)
Model Year99 & newer (except 99 E36)
Description ofService Intervals
All mileages are approximate. 7,500 miles 10,000 miles 15,000 miles Oil Service15,000 miles20,000 miles30,000 milesInspection I22,500 miles30,000 miles45,000 milesOil Service30,000 miles40,000 miles60,000 milesInspection II37,500 miles50,000 miles75,000 milesOil Service45,000 miles60,000 miles90,000 milesInspection I52,500 miles70,000 miles105,000 milesOil Service60,000 miles80,000 miles120,000 milesInspection II67,500 miles90,000 miles135,000 milesOil Service75,000 miles100,000 miles150,000 milesInspection I82,500 miles110,000 miles165,000 milesOil Service90,000 miles120,000 miles180,000 milesInspection II97,500 miles130,000 miles195,000 milesOil Service105,000 miles140,000 miles210,000 milesInspection I112,500 miles150,000 miles225,000 milesOil Service120,000 miles160,000 miles240,000 milesInspection II127,500 miles170,000 miles255,000 milesOil Service135,000 miles180,000 miles270,000 milesInspection I142,500 miles190,000 miles285,000 milesOil Service150,000 miles200,000 miles300,000 milesInspection IIBMW Inspection I Undercarriage
- Change engine oil and filter while engine is at normal operation temperature.
- Check transmission for leaks.
- Check rear axle for leaks.
- Visually check fuel tank, lines, and connections for leaks.
- Check condition, position, and mounting of exhaust system. Examine for leaks.
- Check power steering system for leaks.
- Check overall thickness of front and rear disc brake pads.
- Examine brake disc surfaces.
- Clean brake pad contact points in calipers.
- Grease wheel center hubs.
- Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
- Check front control arm bushing for wear.
- Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
- Check for free movement of the parking brake cables. Adjust parking brake if necessary.
- Check all tire pressures (including spare). Correct if necessary.
- Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
- Read out diagnostic system
- Check engine cooling system/heater hose connections for leaks.
- Check coolant level and antifreeze protection level; add coolant if necessary.
- Check level of brake and clutch fluid in reservoir; add fluid if required.
- Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
- Check air conditioner for operation.
- Reset Service Indicator.
- Check battery electrolyte level and add distilled water if required.
- Perform batter load test.
- Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
- Check instrument panel and dashboard illumination.
- Check all warning/indicator lights, check control.
- Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
- Check wiper and washer system(s); wiper blades, washer jet positions.
- Check condition and function of safety belts.
- Oil hood, trunk/tailgate, and door hinges.
- Grease hood, trunk/tailgate and door latches. Check operation of all latches.
- Check central locking/double lock.
- Replace microfilter or Acc. Cabin Filter.
- Check heater/air conditioner blower, rear window defogger.
- Check rear view mirrors
- Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
- Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
- Check thickness of parking brake linings.
- Half-shafts; check for leaks at flexible boots.
- Inspect entire body according to terms of rust prevention limited warranty.
- Replace spark plugs.
- Replace intake air cleaner element.
- Replace microfilter or Acc Cabin Filter.
