e36 parts & maintenance
Just done a complete engine and gearbox rebuild. Milage at 400k on the dot. Cost me RM 15k. Changed every single hose, engine now like new. When I have time will post the details,
Wow 15k for engine and gearbox rebuild. Must've changed a lot of stuff.
Yes please do share the items and cost. Thank you!
Yep coming soon..... So many parts to key in, at the moment busy with other things
1. Fuel filter - SGD 22
2. Cabin air filter - SGD 16
3. Front disc brakes - RM 210 a pair
4. Front disc brake pads - RM 105 a pair
5. Goodyear RevSpec RS 02, 225/45/17 2 pcs - RM 900
6. Used starter motor - RM 450
7. Power steering o ring - RM 8
8. Reverse switch - RM 36
9. Air con service (dryer, fan belt, air con belt, o ring, gas, compressor oil) - RM 494
10. Rim refurbish plus alignment and steel valve change - RM 600
11. Vanos seal (Beisan) - RM 90
12. Valve cover gasket + rubber seal - RM 120
13. Belt tensioner - RM 120
14. Vent pipe - RM 110
15. Used air con compressor - RM 540
16. Goodyear RevSpec RS 02, 225/45/17 2 pcs - RM 1030
17. Clutch Sleeve Pump - RM 145
18. O2 sensors, Hella - SGD 160 (for 1 piece)
19. Radiator - RM 595
20. Return pipe (11531433059) - RM 134
21. Hose (13541703945) - RM 38
22. Hose (13541703865) - RM 55
23. Fan clutch motor - RM 280
24. Vacuum hose - RM 5
25. Aux fan (aka condenser fan) PN# 64508364093 - RM 560 (Vemo, not Behr. Was quoted Behr - RM 1k. Vemo part #V20-01-1065) http://www.vierol24.de/upload/kataloge/99-9753.pdf[/QUOTE]
27/03/2011
26. Rear door lock actuator - RM 155
27. Beru Spark plugs x 6 - SGD 6/ea
bmw7833;620915 said:
Never know Vemo produce the aux fan..I just replaced mine (m52) for RM1400 last month, should save the half if change to this Vemo brand.
I think E36 & E39 fan is not the same
Yes, i know.
He bought Vemo RM560 (Was quoted Behr RM1K) whereas i bought ori Behr RM1400 (Vemo should be around RM700). So i save half if i go for Vemo, right?
I didn't know there was existence of such brand until I started to look around. BA doesn't have stock for Behr, so I went to another stockist at Seapark. And in the process I saved RM440.
PM me if anyone wants the contact of the stockist at Seapark.
New items
28. Fan shroud - RM 165
29. Bypass hose - RM 40
30. PCV - RM 278 (P/N: 11151703484)
31. Door rubber RR - RM 220
pardypeople;610876 said:
Yes it is new.
Hey vijay, where'd you get the fender liners new? Mine's showing cracks and also the attached weather strip has fallen...
any bimmer dealer should have them. BA or IP definitely got.
Ultimate self satisfaction - DIY driver side power window motor & regulator
2nd hand chop shop motor & regulator = RM300
labour = RM 0
vinss bmw;641999 said:
bro~ can told me bmw E36 power steering using what oil & the prices too ?
It's chronicled in the pages in this thread. If you're not lazy you would definitely find it.
Usually Dexron III ATF..but check your power steering reservoir cap to confirm. Should say ATF or something to that effect.
ok! thx bro~ i did ask so many garage's forman, they say donno what oil should using. I get stun~ my power steering oil turn grey colour ady~
u all using ori rims or any nice rims ? mine is ori but wan to change it, hav any suggestion ? nice & in good prices~
