e36 parts & maintenance
Bro, oil filter, air fileter, sparkplugs so cheap? May I know, where is the place? and phone no of the place?
THey are all ori from auto bavaria ke?
thanks..
monarza, the place is bavarian auto parts sdn bhd, 28,jalan segambut, and yes these are the exact prices from the invoice's in have, dont forget a workshop has to charge more for these parts, this is over the counter prices.and are all german made, belts continental, oil filter marhle etc etc..
oh, the serpantine belt is the ribbed one that 'snakes' like a serpant around all of the pullys/fan at the front of your engine ;-)
580088 said:
parts for small service i did at the weekend on my '95 E36 318i
serpentine belt 40rm
other belt 22rm
oil filter 17rm
airfilter 30rm
4 plugs 40rm
all the above from bavarian auto parts on jalan segambut
bardhal semi synth oil 3x 4liters 180rm from my toyota parts shop on jalan ipoh
labour free
parts are so cheap...cheaper than for my landcruiser !
bro,
another question, where exactly the shop that you bought this toyota oil? Cheap lar :D ....got the no? thanks...
ah, i dnt, errmm, its the parts shop at the end of jalan ipoh, just around the corner from the bav auto shop, its bardhal, not toyota, but they have that too...i use this lace for parts on my landcruiser
other belt 22rm
oil filter 17rm
airfilter 30rm
4 plugs 40rm
labour free
Damn...
I thought oil filter costs 70 bucks!
no?
hi all,
anyone knows how much to fix the shaft inside the gearbox (center shaft that holds the clutch plate)? mine is a manual 325i E36.
really need some input here...
thanks
well, marhle and continental supply BMW, these parts are made in germany, the oil filter comes complete with all seals and washers, marhle are the oem for bmw.
these are not generic 'no name' parts.
where do you buy your 70RM filters from by the way? are they in a bmw box or a marhle one? just interested.
http://www.pelicanparts.com/bmw/catalog/shopcart/BE36/POR_BE36_BASflt_pg1.htm#item0
the above link shows the real world prices of bmw oil filters, read it carefully, you will see mann/bosche and marhle all supply BMW as OEM contractors.
OEM means Original Equipment Manufacturer, ie, sub contractors who supply the factory, BMW use mann, bosche and marhle amongst others..... so, as long as the correct part number is used, you can purchase direct from the oil filter company at normal prices, or you can go to bmw 'stealership' and help them make more profit. simple.
the 3 companys mentioned are big names, id probably use mann if i had the choice, but made in germany marhle for 17rm local, is not bad.
1. Fuel filter - SGD 22
2. Cabin air filter - SGD 16
3. Front disc brakes - RM 210 a pair
4. Front disc brake pads - RM 105 a pair
5. Goodyear RevSpec RS 02, 225/45/17 2 pcs - RM 900
6. Used starter motor - RM 450
7. Power steering o ring - RM 8
8. Reserve switch - RM 36
9. Air con service (dryer, fan belt, air con belt, o ring, gas, compressor oil) - RM 494
10. Rim refurbish plus alignment and steel valve change - RM 600
11. Vanos seal (Beisan) - RM 90
12. Valve cover gasket + rubber seal - RM 120
13. Belt tensioner - RM 120
14. Vent pipe - RM 110
15. Used air con compressor - RM 540
16. Goodyear RevSpec RS 02, 225/45/17 2 pcs - RM 1030
New items:
17. Clutch Sleeve Pump - RM 145
New items:
RM450 for the starter? Where did you get it from? I got mine for RM250 only.
Was quoted for brand new:
bavarian: RM587
inner power: RM600
Mine about to kaput. Change new better right? I'm worried 2nd hand ones may not last long.
bavarian: RM587
inner power: RM600
It all depends on how particular you are. It's all luck one la when you're using 2nd hand items bro. Mine is a E46 starter so it's definitely newer la and should last a bit longer but make sure the chopshop guy connects the starter to the battery. If the starter is in good condition you will see it spool up very fast and constant.
