e36 parts & maintenance
Changed my rear brake pads
1. Rear brake pads (tekstar) rm180
2. Brake sensor rm 35
3. Labour rm 25
salam satu malaysia...nak tanye???
haiii
nak tanye harga untuk rear spring coil standrt berapa yea??baru atau secondhand????
dimana boleh saya dapat atau saya pasang...any suggestion bengkel yang murah dan baik layanannye...hehe tq
untuk service minyak hitam,minyak gearbox,or any part yang biasa biasa...apa jenis and jenama minyak yang baik dan sesuai untuk menjaga kereta e36 328...saya baru pakai kereta....soo just nk kongsi bagaimana cara maintenence sahaja...tq yahh....
mirage_cycborg;549478 said:
haiii
Please use the search function. This has all been discussed extensively in the forum.
Having problem with E36 airflow meter sensor???? All of us have been through and probably bought a few from potong kereta at RM550-650 a pop! Only to last 2-6 months! Brand new Bosch selling at RM2,000 wunderbur! I had just installed an aftermarket airflow meter for RM1,000.00! Yes RM1K only BRAND NEW, screw all the monies on 2nd parts, what a ripped off. Right now my E36 is running beautifully. So if you are looking for this item let me know and all MAF models.
Call or leave message at 012 3832383 for these items. I also know where to get steering racks and other item new at almost half price! There are certain parts you can get potong kereta but some parts must be NEW! For 15 years, I had been coughing blood paying for BMW parts so a very expensive learning curve! LOL Good Luck!
Have been using the car (E36 328) for about a year now, thought of listing down all the parts changed.
1. Fuel filter - SGD 22
2. Cabin air filter - SGD 16
3. Front disc brakes - RM 210 a pair
4. Front disc brake pads - RM 105 a pair
5. Goodyear RevSpec RS 02, 225/45/17 2 pcs - RM 900
6. Used starter motor - RM 450
7. Power steering o ring - RM 8
8. Reserve switch - RM 36
9. Air con service (dryer, fan belt, air con belt, o ring, gas, compressor oil) - RM 494
10. Rim refurbish plus alignment and steel valve change - RM 600
11. Vanos seal (Beisan) - RM 90
12. Valve cover gasket + rubber seal - RM 120
13. Belt tensioner - RM 120
14. Vent pipe - RM 110
15. Used air con compressor - RM 540
16. Goodyear RevSpec RS 02, 225/45/17 2 pcs - RM 1030
ICEMAN 13;521021 said:
my list of engine makeover
2009
1) weicher front strut bar
2) Racing dynamics F&R Anti roll bar
3) Bosch blower motor
4) AC expanion valve
5) AC drier
6) AC micro filter
7) Gear lever bush
8) Gear lever shifter bush
9) Gear lever shifter cover
10 ) engine mounting
11) Original Flywheel oilseal
12) Top exhaust manifold gasket
13) Bottom exhaust manifold gasket
14) Vanos gasket
15) used vanos repair kit
16) inlet gasket
17) Thermostat + O-ring
18) Oil filter Housing gasket + O-ring
19) Semy SYN engine oil 10W 40 Silver
20) Oil filter
21) Spark plug
22) Oil sum gasket
23) Water pump
24) Engine belt
25) AC belt
26) Power steering container
27) Used M52 valve cover
28) Rear pipe flange
29 ) Rear pipe gasket
30) Gear lever welding work
31) dashboard bulbs
32) Fuel hose
33) Manual 85W90 Trans fluid
34) Long shaft center bearing
35) Valve cover gasket
36) Clutch master pump
37) Clutch piping
38) used glove box
39) Brake fluid DOT 4
40) Auto dex III transmission fluid
41) R134a full re-fill
42) Pedal bush
43) Flywheel bearing
44) AC tensioner
Wow, this is a lot...superb...but do u mind sharing the price for each of those? together with the one in 2010?tq bro
ELnino;516038 said:
Last week maintenance for my 328 :
item bought at Bavarian Auto
1. Fan Blade RM192
2. Plate Base (center) RM72
3.Oil Filter RM36
4.Spark Plug RM20x6
5. Air filter RM55
6. Brake Pad front RM240
7. BMW emblem logo RM50
8. Tool Box Screw Plug RM10
9. ATF oil RM36 x 6
10. Castrol engine oil 4 litre x 2 = RM38x2
11. Jetco Gearbox RM 1.5k including installation
ELnino,
I am a newbie.i read many comments from many sifus here, with cost of their maintenance...i saw yours are quite cheap....where did u get it? You mention Bavaria Auto? is that the name of workshop? or you mean Bavaria Auto that sell car, also sell all those items above? thanks :)
p/s: i noticed you use non-sintetic oil for ur BMW...is that ok ke?
bro..i have been searching for some info regarding e36 clutch replacement..
can anyone guide me and also share with me what should i change and how much it will cost..?
BTW its an 325 manual..
try to get those SACHs ... for the clutch plate ....which may cost you somewhere around rm 300~500 ...depending if you know the shop owner larrr ....
sorry ...the list is just too long ... you may print it out and source it at any shop around klang valley ...etc B.A , innerpower ...etc etc
thanx for the fast reply bro..
but what else do i need 2 changed?if im not mistaken itz a set with some bearing and etc..
soory im really new too this..mind to explain bro?what parts need to replace?clutch?bearing and..??
Just to add in to database. The largest $$ paid so far ...
For E36 : M50B25
1. New BMW (AB) 11-blade fan - RM210
2. New Behr Fan's Clutch - RM250
3. 2nd Aluminum Radiator(great condiition) - RM300
4. New OEM Engine Mount - RM150 each ( need to replace both side)
5. New Bremi Spark Coil - RM145 each
6. New Depo Fog light - RM78 each
7. New BMW ori , Wheel Dust Cover (aka Banana Leaf) for Front - RM170
8. New Behr Aluminum Radiotor - RM600
For E36 : M50B25
I paid for item 7. Fender Inner Liner(LH) - RM225 + RM80 Labour :eek:
The clutch actually comes with the pressure plate. Not sure if the bearing is included but I've never changed mine yet since I did the manual conversion.
You can check with Bavarian Auto for price and what is in the kit.
parts for small service i did at the weekend on my '95 E36 318i
serpentine belt 40rm
other belt 22rm
oil filter 17rm
airfilter 30rm
4 plugs 40rm
all the above from bavarian auto parts on jalan segambut
bardhal semi synth oil 3x 4liters 180rm from my toyota parts shop on jalan ipoh
labour free
parts are so cheap...cheaper than for my landcruiser !
today i fixed the rear bumper cover properly on the e36....two plastic brackets, part numbers 51121960697 and 51121960698 from bavarian auto parts @ 30rm each.
an easy fix for a drooping bumper cover.you will need 10mm socket, 8mm socket, pliers for carefully removing the plastic rivets on the wheel arch splash guard, a decent jack, and an axle stand.
total cost 60RM.
