e36 parts & maintenance
On the way to work , temp sky rocketed till the warning light is red .
Off air cond & drive slowly into a petrol station .
Radiator konked - wafer leaked out from somewhere under the cap neck .
Believe this is much too common of a problem as it's plastic & easily
cracked . Lucky that my regular workshop is just 10 min drive .
318I E36
Radiator Assembly - BEHR - RM630
Coolant - 35
Labor - 35
Total RM700
Makan loti looorr .......last month kena the ECU unit oredi !
Lee36328;198975 said:
Megatniza,
To drive our babies, makan loti is worth it!
But not to the point of getting malnourished....:D then it is not worth it.
Work done today at Chu Seng Auto Repairs, Jln P Ramlee, Penang...
Parts:
Left hand side fuel gauge sender unit: RM280
Labour: RM45
Tax: RM2.25
LCP ,
Sorry , may sound like a dumb question .......
How did you know it need to be changed ? Did the car just stop as
no fuel goes into the engine like when fuel pump konked ?
The plastic top was leaking whenever I pumped full, search the forums (I think under General Tech) for "petrol smell in cabin". There is no fuel pump on the LHS unit.
Model: E36 325i year nov '94 VIN#:AA79469 Date : 04 March 2007
LABOUR
1 Replace radiator top hose RM55.00
Replace thermostat RM144.00
3 Bleeding cooling system RM108.00
Sub-total RM307.00
4 Replace rocker cover gasket (leaking) RM270.00
5 Replace oil sump gasket (leaking) RM630.00
6 Replace solenoid valve 'O'-ring (leaking) RM18.00
7 Replace gear selector oil seal (leaking) RM54.00
8 Replace gearbox oil sump gasket (leaking) RM234.00
Sub-total RM1,206.00
10 Replace front control arm bushes RM270.00
11 Balancing and alignment after replacing control arm bushes RM306.00
Sub-total RM576.00
PARTS
Unit Price Qty Amount
1 Front spotlights RM41.44 Qty2 RM82.88
2 Outer door handle rubber RM55.50 Qty4 RM222.00
3 Steering ball joint RM52.82 Qty2 RM105.64
4 Steering tie rod RM381.69 Qty2 RM763.38
5 V-belt RM196.93 Qty1 RM196.93
6 A/C belt RM125.32 Qty1 RM125.32
7 Oil sump gasket RM149.82 Qty2 RM299.64
8 Powersteering return hose RM273.92 Qty1 RM273.92
9 Final drive housing gasket RM6.92 Qty1 RM6.92
10 Driveshaft oil seal (both sides) RM61.77 Qty2 RM123.54
11 Powersteering reservoir cap 'O'-ring RM7.68 Qty2 RM15.36
12 Gas strut for bootlid RM169.58 Qty2 RM339.16
13 Fuel pump hose w/ clip RM158.83 Qty2 RM317.66
14 Front wheel bearing (both sides) RM1,206.89 Qty2 RM2,413.78
Total PARTS RM5,286.13
Lubricants and miscellaneous
RM150.00
Bolts and nuts
TOTAL RM5,436.13
Total Labour RM2,089.00
Service Tax 5 % RM104.45
RM2,193.45
Spare part cost-refer attachement for detail RM5,286.13
Lubricants and miscellaneous RM150.00
GRAND TOTAL RM7,479.58
oooucch ...i feel your pain bro - but then again no pain no gain .btw , i did change the outer door handle rubber last year . This is the rectangle rubberry thingy that goes around the handle , right ? It's about RM50 for the whole set - 4 pcs . Maybe you want to double check with the workshop on that .but your spot light is cheap - i got mine for RM100 - just for 1 side only - somemore from chopshop - looks like i am the one who kena chop !
Is spotlights = fog lamps? RM41.44 - That's cheap alright.
Interesting price difference on the door handle rubber, been meaning to change mine soon...
ICEMAN 13;200637 said:
wahhh sounds good.... front wheel bearing rm1206 for a side ??? are you sure ???
hahah... prob can get 4 or so pairs for that kinda price :D
Maintenance cost for my E36 325i registered Aug 1995. Done in Leon Auto Services, PJ.
1. Oil filter 28RM
2. Spark plugs 64RM
3. Top set gasket 620RM
4. Fan belt 78RM
5. Timing change holder 2 pcs 400RM
6. Water pump 1 set 145RM
7. Thermostat hosuing 98RM
8. Thermostep 58RM
9. Cylinder shut oil seal (cannot be sure as handwriting was horrific) 78RM
10. Timing housing gasket 2 pcs 80RM
11. Petrol hose 26RM
12. Vsexxx (?) hose 26RM
13. Fan clutch 348RM
14. Thermostep switch 90RM
15. Front brake pad 180RM
16. Rear brake pad 145RM
17. Front brake hose 170RM
18. Rear brake hose 110RM
19. Eng knock sensor 2pcs 300RM
20. Cylinder head 3600RM
21. Exhaust valve 150RM
22. Brake oil 24RM
23. Polish valve 350RM
24. Valve cover gasket oil seal 75RM
25. Pressure test cylinder head 2 times 250RM
26. A/c gas topup 30RM
Workmanship 580RM
This is just part 1...
Well if there is anything to shout about -
1. Drove to/fro Singapore twice without any problem
2. Next service castrol fully synthetic, oil filter, labor, flush radiator plus coolant free
dear koryong,
can u tell me the shop in KL to do refurbishment on my e36 interior plus some engine work?
repair on 28.03.07
syarikat kingswell auto sdn bhd
taman overseas union, jalan kelang lama
1 pc - breather hose assy - 11151743386
plus workmanship - RM198.50
problem: while stop, car idling not stable, up and down. can hear hissing sound from engine bay.
culprit - hose bocor.
repair on 30.03.07
1 pc - vent valve - 11157501567 (breather valve)
repair cost - RM258.00
problem: samething happen again. afer changing valve host 2 days ago, the main valve leak. rough idling up and down. funny weird whistling sound from engine bay.
repaired today at New Age , Ipoh .
for past few days , the car a bit sluggish at traffic light . Engine like want to die ( but did not die ) .
changed the ground cable at alternator ( RM35 )
clean idling throttle ( RM10 )
drove around town for 1 hr . so far so good .
change my steering coupling. new bavaria quoted at RM912.00
bought from chop shop at RM50.00 + install RM40.00 total damaged RM90.00
