Part II
Fly wheel oil seal --75
Auto filter--80
auto oil sump gasket (small)--25
auto oil sump gasket (big)--32
power steering hose--88
single oil hose and pressure hose--15
oil sump gasket--65
door handle rubber seal (12set)--75
coupling--180
gear shaft oil seal--30
oil filter housing o-ring--35
workmanship--430
Total cost - 1406
Part III
Head lamp replacement to angle eye--750
Lower arm ball joint 2 pcs--210
Air intake cover (small and big)--100...re: missing
Aircon bearing--75
Fuel pump--580
Brake light circuit wire system rework--230...re: Alarm keep coming up
workmanship - 80
Total cost - 2025
One case of lesson learnt - the hose clip from the radiator relieve broke, and hose wrapped around the radiator fan, causing the fan blades to broke off. High temp in radiator resulted. This happened to me on my way to Singapore, just pass Senai toll. Night time 10:30pm. Managed to stop the car immediately by the road side. Decided to repair car in Singapore since home ground, hence activated toll-truck (Malaysia) to tow car to Woodlands causeway - RM200 levy to pass + RM250 toll service. Singapore tow S$100. Reached Singapore 4 am, not something you wish to end up. No damage to cylinder this time - very lucky. Went back family radiator repair shop at Yew Tee to get radiator flushed and checked for leak. And metal clipped very hoses in the engine compartment. No issue driving back to KL.
Hopefully the replacement stops here...as I am preparing to buy another BMW but E46 325 this time for wife as she join me in Malaysia soon.
