e36 parts & maintenance
Gotta change my front breaking system, call for price comparison to few parts suppliers. here is the finding, hope useful for referrence
kar092000.... while u @ it... taruk stainless steel.... braking hoses for front and back.. kau kau one.... hahaha
Inner power stuttgart BA ss2 OEM ss3 bomin 1st div css
pad 125 110 95 95 120 120 135
Brake disc 190 145 168 220 200 220 220
sensor 35 30 25 35 30 28 30
damage 350 285 288 350 350 368 385
solution:
Buy pad 1 set from BA ss2 RM95.00
Buy Brake Discs left & right from stuttgart RM145
Buy sensor from stuttgart RM25
Total cheapest damage = RM265/- spare for labour RM50/- expected damage RM315/-
My time with sweet & tears....Done at MSpeed Subang:
1. Engine Oil Fully Synthetic & Oil Filter - RM300
2. Spark plug - RM90
3. Relay - RM200
4. O2 Sensor - RM400
5. Timing Sensor -RM280
6. Cam Sensor - RM280
7. Fuel Pump - RM550
8. Fuel Filter - RM70
9. Oil Sump gasket & Labour - RM250
10. Oil Filter Housing Kit & Labour - RM85
11. Gear Lever Oil Seal - RM25
12. A/C Fan Bealt & Bearing - RM600
13. Inner Ball, Ball Joint + bush, Pump bush and ball joint - Rm580
14. Kickdown Switch - Rm130
15. Labour - RM350
16. Fixing problem extractor - RM180
TOTAl DAMAGE - RM 4,370.00
Time to get biskut and maggie....hehehe...
solution:
Can try also check a parts price at bavarian auto, just to compare. so far from my survey, bavarian auto a little bit cheaperst than stuttgurt. becoz sometime i have buy a part at spare part shop and DIY.
Replaced my passanger front side window today. Go to 3 series thread to find out why.
1. Window - RM 120.00 (New)
2. Labor - RM 40.00
Location of shop - Along Sungei Besi high way near a school called tai thong or something.
yo... the airflow meter can be repaired and it cost only very little. It depend on how u drive it. I'd suggest u to change a new one becoz u can get peace of mind. i changed a new one in 06/2004 till now, soon-soon tip-top condition... it's a BOSCH, made in germany, rm1500.
By the way, i need some advise here..
can anyone let tell me what's the different of the engine between e36 coupe & e36 IS? timing belt or timing chain?
thanks...
juz replace second hand Check Control RM150.. i replace my lining bumper pair RM120. Today cost RM 270.00..All done at chop shop :D
E36 325i
EVAPORATOR 798.00 BEL TENSIONER 122.00 EXPANSION VALVE 135.00 SHOCK ABSOEBER F 345.00 AUX DAMPER 30.00 PROTECTION TUBE 8.00 SHOCK ABSOEBER R 176.00 AUX DAMPER 35.00 FRONT GRILLE 152.00 CRANKSHAFT SENSOR 205.00 CAMSHARF SENSOR 294.00 MICRO FILTER 41.00 FAN BELT 42.00 A/C BELT 29.00 OUTER DOOR RUBBER SEAL 55.00 POWER STEERING PUMP HOSE IN 66.00 POWER STEERING PUMP HOSE OUT 598.00 STEERING WHEEL BADGE 35.00
Hello Guy's!
What's the price fr e36 rear trunk spoiler?? And where to get it??
Pm me if available.
Many thanks..
jayfactor, what happen to ur airflow...?? ur car humming right..?? i faced same problem last week but it got worse, initially the car humming, rpm goes up and down then the engine just dead. the engine failed to start after that. i just diy my air flow then my babe alive and kickin' again. what u do just take the airflow out then u can see the butterfly valve inside. at this point most probably ur butterfly valve is in it max open position which by right it should fully closed. so, what u do, just take a spray can of chain lubricant then spray to the clips which hold the valve then u just open and close the valve manually, using ur screw driver also can. keep on lubricate the valve until it smoothly close when u push it open. remember it should be at the full close position at all time when ur engine is not running. happy trying.
cheers....
engine oil change ...rm 75
oil treatment -- rm 16
labour FOC
still running good ...
Putting in brand new radiator... E36 318i
Radiator (new) rm500
Hoses 2nos rm 90
Coolant hose(throttle body to engine block) rm 50
Connector (for engine block) + o-ring rm 55
Original BMW Coolant rm 25
Labour rm180
All parts from First Div...
service on 18.11.06
syarikat kingswell auto sdn bhd
taman overseas union, jalan kelang lama
parts -
drain plug - 6.00
oil filter - 40.00
synthetic engine oil (NASA) - 178.00
engive v-belt - 86.00
belt tensioner assy - 195.00
front shock absorber mounting x 2 - 250.00
brake fluid - 48.00
workmanship -
lubrication service, replace engine oil, oil filter, check and top-up all the rest and reset service indicator - 60.00
remove broken oil drain plug and repair screw thread - 15.00
check all wheel brakes, renew brake fluid, flush and bleed complete brake system - 60.00
renew front shock absorber mounting - 100.00
renew engine v-belt, tensioner assembly, refix and tighten - 45.00
total - RM1083.00
Work done at Chu Seng Auto Repairs Jln P Ramlee Penang yesterday 22 Dec 2006...
Parts:
Caltex Havoline Fully Synthetic engine oil, 4lit x 2, RM372
Oil Filter, RM30
Coolant (BMW OE), RM28
Bosch spark plugs (twin ground electrode), 6pcs, RM90
Labour:
Oil service, RM38
To change radiator side plastic cover, RM80
To dismantle and replace radiator, RM260 (hmmm!)
To reconnect wiring (rat attack!) and change spark plugs, RM60
Tax: RM21.90
Total: RM979.90
more to come... rat damage not fully repaired yet, and valve cover gasket needs changing
Just for my knowledge, why would a old car like e36 required fully sythetic oil, i tot it's only for new car?
