affan66 said:she took pics.
Car ? tempat biasa la flash...
she's going to hospi today. Slight strain on her back (whiplash). and bluish on her toes
khisham said:...sorry to hear of the accident BUT very happy to know that the engineers at BMW did their job & allowed the car to perform to the max, which allowed your sister a preferrably unwanted but a very valuable & testing experience & thus to recuperate...
...hydroplaning should NOT happen if a vehicle is fitted with ABS, if the tyres are regularly inspected & the necessary maintenance disciplines are adhered to...the after collision expenses will be hefty BUT the insurance coverage should take care of most of it..(forfeit the NCB for untimely occassions such as these !)
...so a lesson for all of us is, BELT UP, maintain your car well & we can continue to, preferrably enjoy, MOST, of the "Ultimate Driving Experience"...unscathed & untested...
535i said:hydro should NOT happen if a vehicle is fitted with ABS ? Sorry .. but frankly I am a bit lost here ..
I hv ABS - did not hit the brakes but the car hydroplan jugak .. Tires are new .. KLIA expressway ..
khisham said:...at your earliest convenience, on a dry stretch of road (even in a carpark) at between 60-100 km/h, suddenly brake hard...if you hear the loud & hard clicks & the car slows down & does not skid...your ABS is working...
...anything else points to a trip to the workshop for a much needed repair as the ABS was never in proper working condition...
...however continued acceleration on a stretch of road WILL cause hydroplaning & one should ease off the accelerator immediately to actually manage the hydroplaning...
Jules said:erhhh...HYDROPLANE occurs when ur tyres are not channeling enough water away and hence the tyre loses contact with the road.....happens when you are NOT braking normally so how can ABS be of use here?
If u talk abt POST hydroplane phase, then that's a recovery maneuver.......
do I make sense?
khisham said:...hydoplaning is physics & the elements combined during projectile motion...
...ABS will assist but only if other measures are in effect...ultimately, the amount of water or ice, as the case was for me, & the available traction capability (the tyre wear & tear) will allow ABS to assist in managing the movement of your car....
...you must release the gas pedal & you must keep a level head & manouver your steering wheel when you feel that your car is hydroplaning...
...your tyres & your vehicle weight load while travelling, will also influence the effects of hydroplaning as well as the effectiveness of the ABS, if used...
..unfortunately, many in & from Asia practice blaring the horn and/or flooring the gas pedal to try & accelerate out of trouble instead of releasing the gas pedal, pedaling the brakes & trying to avoid the potential trouble...
...using the turn indicator lights is incredibly useful too...
affan66 said:The private tow trucks and vultures were swarming that place so I think they were responsible in some way. The PLUS people said it is likely. The stretch is near a workshop/tow truck syndicate located in Tg Malim/Bernam.
K.M. said:If u guys drive within area from Sg. Buloh and Tg. Malim better be careful. That area is the hot spot for plan accident..
