ALBundy;679503 said:Looks like I finally have the dreaded SMG problem.
Unlike with the 325 SSG or SMG1, on the M3 the problem is more likely to be (fault code 056) the SMG pump or the pressure accumulator and sometimes the SMG relay.
Initially only the transprogram/smg light will appear on the cluster when some hard driving is done, and it will be appear in more regular fashion till occassionally it will pop into N, before going back to the proper gear. It is an indication that the pressure cannot be maintained either due to the pump or the accumulator which is actually a pressure tank like those you see in a hotel water pump room, where the usual cause is the diaphgram failure.
I am going to swap an accumulator (21532229716) and see if the problem goes away and I hope it does, or else it will be SMG pump unit (21532229716).
sachseelan;682438 said:hello smg's ...
car shakes a little(ass feel) at cold starts for about 45sec to a minute, warm engine no problem...
diagnostic - no fault codes.
anyone wt this experience?
jc@;682606 said:hi,
anyone having the same problem like mine?
whenever we unlock our car there must be a long long buzz right?
and when we stop in traffic or when idle the buzz will keep coming.
my current problem that im facing is, instead of a long buzz, it goes really really short and buzz like 3-4 times when its idle every minute.
got any idea what cause that?
run a check at Ab JB and also another workshop show no error.
pls help.
thanks
B33mEr;684521 said:Bro which workshop do you bring your car to for your SMG problems ?
It can be a lot of things really one of the possibility is the O2 sensor, check out the the link it seems this one describes the problem same as yours :- http://forum.e46fanatics.com/showthread.php?t=740426
SMG pumps will turn on to pressurise the hydraulic system in which the accumulator job is to hold that pressure. If it leaking then you will hear the pump turn on more often. Seems that you have the same problem as Albundy. I'd suggest whenever you're in KL give gearbox specialist M-Scope a visit or Ah Wai at BM World desa tun razak (he's done plenty of smg but it's not cheap i warn you)
Item no. 1
Gravity101;685514 said:Checking in. Hi B33mer![]()
I need to stop worrying about my 325Ci SMG 'characteristics'. It is running fine, getting a transmission oil change on Friday. The only thing I have to say is when the engine is cold, every now and then it shudders between 1st and 2nd as if the clutch disengaged before the revs were high enough. Once the engine/gearbox oil is at operating temperature it doesn't do it. I believe this to be normal.
It's a bit like when you have a headache so you research on the internet and suddenly it's a brain tumor!
ALBundy;685551 said:I have been sending both my rides to this shop called Autobahn in Sunway. This chap used to work at Heritage. His rates are very reasonable compared to BM World, and a friendly chap.
As for the SMG issues, there is nothing much one can do. Just hope the culprit is the pressure accumulator. The problem is intermittent as of now.
