danc;325493 said:I heard that the first few batches of E90 came with them. It's a plastic key u can keep in your wallet so in emergency, stick it into the spare key holder located in the glove box so that u can start the car
beemerlover;327293 said:This morning on the way to gym, the OBC showed outside temperature to be 1.5C... brrrr.... then the 'snow' symbol lighted up in OBC with audio chime warning. Was wondering what it's all about as this is the first time I encountered it. Then it came to me as the car was trying to alert me of potential frost/ice on the road, hence, to drive carefully on potential slippery road. Hmmm ... I'm impressed!
Also, do you guys rely on the tyre gauge in OBC to tell you of underinflated RFT? This morning was the first time I pumped in air to the RFT after owing it for 11 months. Were slightly underinflated around 190psi against recommended 210 psi.
Schwepps;327369 said:You have a tyre guage in your OBC? Unless you have a foreign spec unit, the local CBUs and CKDs only have a RFI and not a TPMS system. An RFI will not detect actual tyre pressures, only relative underinflation in a tyre versus the rest. See this recent thread: http://www.bmwclubmalaysia.com/forums/showthread.php?t=19563&page=3
Also, why are you going 11 months before checking your tyres? Seriously?Maybe that's why your car told you it was snowing in protest?
Schwepps;327559 said:Keep in mind that even with RFI, you have to reinitiate the system each time you pump them up. To learn how to do it, see your manual. It's slighty different for iDrive cars.
In 11 months I would have checked my tyre pressures 44 times and balanced/aligned/swapped my wheels almost 4 times bro...![]()
David Yong;328813 said:Our E90s here are only fitted with the FTM. No TPMS. I have tested mine and I find that the FTM is very accurate.
By the way, I am very surprised to hear that you can get 1.5C in Melbourne!
mummygohan;329101 said:my car mileage was 2600km, managed to hit 180km/h at KLIA highway this morning, suddenly a yellow radiator coolant sign came out. Should i top up the coolant from the spared tank myself OR send it back to AB tmrw, Any advise bro???
