Bailey
- Jul 31, 2006
- 5,844
jarance;572707 said:I am available on the 23rd or 24th Oct. Time: 1:00pm till 5:00pm.
Pls call before cumming.. :listen:
good la bro mayb 24th i'll book u yeah
Alex5522;572840 said:ouch.. become GRO sudah. What is the booking rate /hr ?:love:
rsctan;579712 said:anyone with the problem of flickering eyes? mine is like "fast and furious" now if u know what i mean
jarance;579717 said:Did the flickering happen when you JUST turn ON the light?
rsctan;581973 said:it flickers when i turn the ignition on to number 1. it flickers.
jarance;587878 said:alex, how many of the four got dead led?
maybe, i can help to repair them if you pass the ring to me.
btw, the warranty already expired.
Russie;587884 said:Jarance, we can actually buy those SMD LED and modify any existing lighting system right? Any website where a rookie like me can refer to on how to DIY SMD LED stuff? What would be the required tools? I am interested to fix some for my kereta kebal
bkslee;591895 said:Hi guys,
I have a little problem here perhaps you guys might be able to help. I manage to install the angel eye but I'm not using the always "ON" setting, so i connect to the small light for the power source. However, I do no wan to small light to switch on together with the angel eye, so i disconnected it but then the error code shows on my dashboard. How do I disable the small light without the error code?
Thanks in advance.
bkslee;592017 said:Thanks guys.
@Alex, ya i did, in fact, i connected the ring directly into the socket head which i unpluged.
@Aidilj, I'm thinking of putting a resistor as well but not sure what omhs to get. I saw some1 posted in 46fanatics to put 200omhs of resistor for the signal light. will try try later, nid to run to pasar road again.
Btw, 1 more silly question. Does your LED lightup (very dim) whenever u swith on your car? (for those who not setting up the always ON setting)
bkslee;592095 said:Case solve.. thks guys.
Solution : 220ohms resistor
Cost : 5cents each at pasar road, pudu.
Connect it like a bulb
