FAQ - SMD LED for E36 & E46
jarance;570045 said:
Ahhh.. so need some sort of a tool to do it. :sleep: That one I know long long time ago lah.
Is there ANY way to do it without the tool for cheapskate like me.. :listen:
pss..sstt Project I-Bus and K-bus.. and not bus mini wilaya
Sorry bro, but you need the GT1 software to change it. This RM75 should be well worth the $$$ to spend for. Not too much to spend, about 1 full tank of petrol or 2 days drive to PD and back.
bimmerholic;569944 said:
Some of the optional lists can be found here> http://www.bmwclubmalaysia.com/forums/showpost.php?p=560558&postcount=70
1) Wiper modes: You can select if you wanna enable/disable "drop speed" when idle. Meaning if you're in 2nd speed wiper mode, it'll automatically drop it down to 1st speed (intermittent) when you come to idle. When you start to move next, it'll automatically start the speed at 2nd as you initially set it at that speed. Same goes with 3rd speed...it'll drop to 2nd speed when idle.
It's helps a lot imho, cuz when comes to traffic lights, you don't want the wiper to wipe fast. I would normally turn it off at the t.lights in my other car, but when drive the UDM, it does it by itself.
2) Ambient light: You can select soft/fast ON. Meaning, you want your interior lights to dim on/out when opening/closing door or fast on/off when operating the door.
3) Seatbelt warning: You can have it turned on to remind you of buckling your seatbelt as well as chiming.
4) Home lights: How many seconds you want to have your homelights (low beam) lights on when you switch on? It's 10: 20: 40: 60 secs of choices.
5) Units: Metric or Imperial readouts.
6) Windows: One touch UP/DOWN or press & hold operation (standard on every other practical cars).
7) Side Mirrors: To enable/disable tilting downwards while in reverse.
8) Auto lock: to enable/disable auto-lock when car reach the speed around 5kmh.
9) Selection Unlocking: To unlock driver's side door when pressed unlocked button 1st time. 2nd time press, then only all the other doors and trunk unlock. Or to disable selection unlocking, meaning everything unlocks when 1st time pressed.
10) Comfort unlocking/locking: To enable/disable windows/sunroof slide open with key.
I think there are others i may have left out but this is as much as i can remember seeing the features i have on my car using the DISPLUS once before.
I like the feature no 8 :top: to be set on my car but don't know where to make this setting in Seremban. Hope some one can recommend me. Previously my 4WD will lock all the doors once i press my brake.
any bmw mech with displus has got the solution for you :)
Alex, make a list of functions that you want to activate then send your car to the nearest mech to have it done. otherwise go to the nearest authorized BMW service center should be able to help you get it done. I did mine for RM75. :top:
mmmmmmmmmmmmm......
Bro where did u done for yours ?
Daiichi;570493 said:
Is the yellow thingy at bottom...is that the GT1 module?
Forget about this equipment. Only Authorised BMW can afford this equipment. :sleep::sleep:
My mechanic has this...expensive piece of equipment
Where is your mechanic? is it ZF auto? i know ZF auto have the equipment
hi guys, i'm a new owner of 92 e36... :) i'm interested in installing angel eye to my ride, any place to do it with reasonable price? or is there a second batch buying the led?
also is there any reliable workshop to recommend to me around pandan jaya and cheras area?
regards, rhmt3
regards, rhmt3
bro, there are many place doing angel eye around the area.
sorry there would NO 2nd batch of group buy. I arrange for this group for my e36 and actually end up with an e46 angel because somebody ordered e46 but took the e36.. :motz:
gone thru all the trouble and did not get what I want. now have to go to supplier to exchange for my e36. so you think i want to go thru all the trouble again.. :stupid:
btw, please introduce yourself in the newbie section and if you are free, do come and join us at the Borneo Rainforest at sunway tonight. (starting from 9:30 pm till very late)
maybe you could pm the the workshop doing angel eye, probably area pandan jaya... or maybe u got extra angel eye from previous batch to sell to me... :)
introduce yourself first lah. after that we talk.. :listen:
rhmt3;570796 said:
hei, thank you for yr introduction. as forum rule, we are not encourage to commercial posting.
I will PM you the contact person for the SMD LED. Just contact him and nego with direct. :OK:
btw, nowadays, there are many shop selling angel eye using CCFL. They are about rm160 to rm180. some people said it last 1 year but I have friend who say that it last 5 years.
SMD LED are more easier to install cos they have any inverter.
