bkslee;592191 said:Thanks aidilj for explaining this. Now i know why the shop ask me how many watt, but i ask back "resistor not measure by ohms meh?" then he ask me how many ohms, so i say i wan 200ohm but out of stock so i take 220ohms. OK i will wrap it later and try the heat tonite, but then i think hard to tell whether hot or not coz the engine bay already very hot after run. Anyway, like you said, worst case is either open circuit (warning light) or kill a fuse (change it).
Btw, how come u guys so power one ar.. all E&E engineer ar..?
bkslee;592364 said:haha.. i only know 1.7m, 2.2m, 2.7m .... sales numbers..
bkslee;592316 said:Took my car for 30mins ride with head lights ON. now the resistor is wrapped in tape, it's feel quite hot.. now you make me worried n confused. haha.. should i get a higher watts resistor? Btw, the resistor I bought was labeled as 220E, what does that mean?
jarance;592363 said:1.7, 2.2 2.7, 3.7, 4.7, 5.7. - anybody understand these number is an electronic freak
jarance;567988 said:here is the 1 way of doing the wiring.
1. The angel eye will light up slowly when the door is open via remote and dimmed down when the door is locked.
2. It will also light up when the door is open.
3. It will stay ON when the engine is started.
B33mEr;642655 said:My CCFL angel eyes inverter always rosak ... Anyone knows where i can get the inverter (aka angel eyes ballast) which is robust and can withstand the engine heat?
Daiichi;642681 said:Bro B33mEr, try placing your ballast inside the headlamp housing, there is some space on the side where it meets the bonnet kidney grilles. I have mine fitted there for almost 3yrs without any problem. It's also insulated from the hot engine bay.
