aidilj
Official Member
- Jul 3, 2010
- 2,291
Hi Guys, I would like to share my findings and results to my diagnostic foray started a few weeks ago (after the carputer is considered done).I've succesfully installed and run EasyDIS v44 and INPA-EDIABAS on my Windows 7 64bit computer using a homemade OBD interface. In essence, you'll need an INPA-EDIABAS compatible cable to get EasyDIS to work which easily available on eBay and such. The cable I've made and USB-to-serial converter pair is able to autodetect my car.Installation of INPA-EDIABAS is a breeze but needed for EasyDIS to work since it will use EDIABAS to talk to the vehicle. Installation of EasyDIS is more complicated, but the steps are very well documented and should take around an hour or two to finish depending on how good you are around computer.Files for the installation and documentation can be found here.http://forums.bimmerforums.com/forum/showthread.php?t=1541368If anybody used links that I've put before in other threads, scratch all of that, this is the correct and working download. INPA is English here unlike the others. Everything should be ok if you follow the documentations to the letter.One thing that I did wrong is that setting the protocol as Softing and not Fister. And note that, EasyDIS is modified from the original application to work with INPA-EDIABAS interface. So the bar showing connection health to the yellow diaghead will not work (as my screenshot below). Remember to turn off firewall, including the application in firewall exception is not enough.Hope this helps anybody.Some useful linkshttp://forums.bimmerforums.com/forum/showthread.php?t=1385070&page=3http://forums.bimmerforums.com/forum/showthread.php?t=1608785EasyDIS screenshotMain page
Autodetect works
So many errors
Need a course to use DIS, the car can detect noise and play!
One Of the Coding submenu
INPA screensMain page
IKE settings
Monitor CAN bus to the IKE
Little info on the homemade interfaceSchematic is like so
Got OBD supplies from http://www.obd2-shop.euConstruction pictures
http://i791.photobucket.com/albums/yy197/aidilj/diagnostic/IMG_2935.jpghttp://i791.photobucket.com/albums/yy197/aidilj/diagnostic/IMG_2945.jpghttp://i791.photobucket.com/albums/yy197/aidilj/diagnostic/IMG_2953.jpgInterface can easily be acquired on eBay..! Don't have to make your own.CheersAidil
