champion;492278 said:Even if the base not the same, does it affect the brightness ?
funfer_fahrer;492237 said:Sorry to interrupt. Uncle Jarance, where can I buy H7 bulb holder? susah mau cari oo..
jaleeks23;492252 said:H7 bulb holder is easy to find for E39. However, if we use after market HID, no bulb holder at all. I tried looking for the original HID bulb holder, can't find it so far, so modify the existing H7 holder.
tkk;492384 said:Hi Jarace / bmw7833 / king82,
i shall take another photo and show it here.. i think my current setup even more brighter than previous setup.
jarance;492284 said:brightness of the HID is the same. It depend on the colour output. eg 4300K, 7000K. So it will look from yellowish to whitish to bluish.
If the base is different, then you might have alignment problem. eg filament not facing up or the focal point is not suppose to be. when you on the light, you will see very bright from the front but the throw of the light on the road is disperse rendering it useless for driving safely. Worse still, you cause a glaring for the oncoming traffic.
champion;492484 said:I have checked, my filamen is facing down. Does it makes any difference if i rotate to face up ?
As mentioned, my current base have been modified, thus it is difficult to rotate(but possible).
jaleeks23;492565 said:I could not find the base, anyway, yes I think my HID bulb is generic but the box said it was meant for H7. The bulb has the wiring connected to it which cannot be detached, therefore to connect the HID bulb to the ballast, I still need to cut a hole on the holder.
jarance;492467 said:bmw7833, there is something wrong with your low beam.
1. your left and right low beam is not focus properly. There seem to be something splitting the beam into 2 spots. Observe the "X" shadow in the centre of the beam
Right side:
Left side:
2. your low beam is too low.
when the beam is focus and align properly, you should get something like this.
\____ \____
jarance;492552 said:see below.. light is projected from top to bottom.
For HID, if your HID arc chamber is facing down, some of your light is blocked by the ceramic rod.
So yes, the ceramic rod should be facing down.
ps.. HID bulb dont have filament lar.. only arc chamber
bmw7833;492841 said:The yellow circle one is ceramic rod?
So it must facing down?
bmw7833;492839 said:Too low, right?
Any solution?
jarance;492889 said:First, find out why you have a shadow in your beam pattern.
