bmw7833;492057 said:I always impress when i see this photo.
This is another one from an e39.
I am curious why my headlight shoot so downward?
tkk;492027 said:how about my E34 headlight
http://www.bmwclubmalaysia.com/forums/attachment.php?attachmentid=12156&d=1262355547
jarance;492106 said:Is this picture on low beam or high beam. from the picture the car on the right number plate is brightly light up. IMHO, this is glaring to the oncoming traffic.
bmw7833;492130 said:Low beam, bro.
jarance;492158 said:It this the light profile of your car?
How about shining on the wall? say 2 to 3 cars away.
bmw7833;492057 said:I am curious why my headlight shoot so downward?
funfer_fahrer;492166 said:It could be due to broken headlight adjuster mechanism.
bmw7833;492159 said:No no, that's not my car. I am satisfy if my car shoot like that.
bmw7833;492170 said:I know my right side adjuster is broken and i am trying to replace it.
Left side adjuster is ok but still shoot downward.![]()
jaleeks23;492207 said:My adjusters have all been fixed. Using Korean HID with their original 4K bulb. Because my original is H7, I had to sacrifice the bulb holder by cutting a hole nicely so that the HID bulb's wire can come out and connect to the ballast. My HID bulb sits on the bulb holder nicely and the bulb markers must follow the bulb holder's marker as well. Keep in mind bulb holder has an indicator that your bulb must follow. My installer used some type of glue, super hard, once dry become like plastic to make sure the marker is aligned, facing up. This usually is the problem where the beam is too low, bulb not sitting nicely (assume everything else is fine)
funfer_fahrer;492237 said:Sorry to interrupt. Uncle Jarance, where can I buy H7 bulb holder? susah mau cari oo..
jaleeks23;492252 said:H7 bulb holder is easy to find for E39. However, if we use after market HID, no bulb holder at all. I tried looking for the original HID bulb holder, can't find it so far, so modify the existing H7 holder.
champion;492210 said:Hi Jaleeks, my process is exactly the same as yours. cutting, gluing ,markers, etc. By the way, can you advise which part is facing up ? A or B ? (If it does makes any difference)
