My 1st Bill after owning 328i for 2 months. Total 72 items changed..
Parts & Services:
1 Aircon Belt Absorber - $130
2 Aircon Belt Tensioner Pulley - $65
3 Aircon Filter - $45
4 Aircon Gas (top up) - $30
5 Alternator Screw - $5
6 Auto Gear Filter - $30
7 Auto Gear Gasket (Big) - $15
8 Auto Gear Gasket (Small) - $13
9 Auto Gear Oil (Vaico) x9L - $252
10 Auto Gear Torque Converter Oil Seal - $65
11 BMW Coolant x2 - $60
12 Booster Air Valve + Pipe - $65
13 Brake Fluid - $17
14 Clips x2 - $4
15 Engine Mounting x2 - $290
16 Engine Oil (Castrol Magnetec) x2 + Oil Filter - $200
17 Exhaust Pipe Hanger - $28
18 Fan Belt Pulley - $65
19 Fan Belt Tensioner Kit (Absorber + Bearing) - $240
20 Flywheel Oil Seal - $32
21 Fog Lamp Bulb - $18
22 Front Wheel Bearing - $190
23 G/Shaft Oil Seal - $12
24 Gearbox Mounting x2 - $52
25 Bulb - $5
26 Long Shaft Coupling - $130
27 Long Shaft Coupling (To Grind) - $150
28 Long Shaft Mounting - $85
29 Lower Arm Absorber Link x2 - $116
30 Lower Arm Ball Joint (outer) x2 - $130
31 Lower Arm Bush x2 - $210
32 Manifold Gasket x2 - $50
33 Meter Bulb x10 - $25
34 No Plate Bulb - $4
35 No Plate Holder x2 - $40
36 O2 Sensor NTK Hella - $450
37 OBC 18 Buttons (used) -$450
38 Oil Pan Gasket - $90
39 Petrol Hose x1.5ft - $23
40 Petrol Oil Cap - $30
41 Power Steering Fluid - $20
42 Power Steering Rack Seal Kit - $190
43 Pressure Control Valve - $230
44 Radiator Cap - $45
45 Rear Gear Oil x1.5L - $143
46 Rear Long Shaft (used) - $500
47 Rear Wheel Bearing x2 - $170
48 Side Skirt Clip x6 - $21
49 Spark Plug x6 - $78
50 Timing Oil Seal - $24
51 Vanos Oil Pipe - $95
52 Washer Tank Motor - $40
53 Wiper - $40
54 Wiper Panel x2 - $160
55 Service ICV $80
56 Computer Check $40
57 Labor Charge $1,200
Sub Total1 $6,987
Decoration:
58 Exhaust Pipe Tips $300
59 M-Power Emblem x2 $60
60 BMW Steering Wheel Emblem $20
61 Schnitzer Emblem $30
62 Paint Bumper (Front & Rear) $500
63 Continental Tires CSC3 $1,300
64 Balancing & Alignment $50
65 BMW Rims 17" (used) $1,000
66 Projector Head Lamps (Depo) $780
67 Rear Light (Crystal) $680
68 HID Kit $300
69 Tinted Solar Korona $680
70 Parking Sensor x4 $138
71 Car No & Plate (Crystal) $70
72 Sound Proof Rubber x4 doors $450
Sub Total2 $6,358
Total Amount RM13,345
