e36 parts & maintenance
just to share my recent bills...
20/11/11
Clutch Pad Kit Rm 600
Fly wheel oil seal 85
Clutch shaft oil seal 70
Rev switch 45
Gear oil 22
Oxygen sensor 400
Door clip rm4 x30 120 (got choped!)
labour charge 350
tax 17.50
total rm 1709.50
15/01/2012
Fuel regulator rm 230
labour 80
total rm 310
21/03/2012
rear axle gear box bush rm 60
gear oil 2 litre 56
gasket 30
pump bush 20
labour 380
tax 6% 22.80
total 568.80
23/03/2012
2x engine mounting Rm 310 (155 each)
1x long shaft coupling 140
labour 120
tax 7.20
total 587.20
others
Headlamp switch rm 150
speedometer 300
starter relay 80
tyre 350 x4 1400
total rm 1930
p/s - but everytime when i pay i make sure there's some discount especially on the labour..
total for ownership 3years RM 5105.20 (i think im consider lucky..fingers cross anyway)
Bro,
Your door clips very very expensive. it sound be around rm 1 to 1.5 max.
Long shaft coupling also kena marked up already. it should range around rm 80 or 90 at bomin, 98 at bavaria auto, suan huat rm 105.
this was yesterday price i went there myself :p
cheers.
20/11/11
Rev switch 45
Gear oil 22
Oxygen sensor 400
labour charge 350
tax 17.50
total rm 1709.50
15/01/2012
labour 80
total rm 310
21/03/2012
gear oil 2 litre 56
gasket 30
pump bush 20
labour 380
tax 6% 22.80
total 568.80
23/03/2012
labour 120
tax 7.20
total 587.20
others
speedometer 300
starter relay 80
tyre 350 x4 1400
total rm 1930
Thanks slyder, true bro i knew bout the door clips..but too bad that time i asked my fren to collect the car..
Ohh i see ,damn kena again..coupling aso they markup..others okay uh?
Others cant remember need to go back check my stack of resits :p btw mine is 328 so some parts might be different. see that you are in penang. perhaps transportation cost to penang so slightly more?? i know last time when me and my dad was fixing our accord ca4 some of our parts we went straight to singapore to get as in kuching its way way more hiked up coz transportation cost.
thats exactly what my mechanic told me..others for me quiet okay bcos before this i got nailed even more by 1 more shop around here..:(
unstopables_7 - Headlamp switch, the entire assembly (include the air cond piece) or just the round switch?
M50 engine
Radiator plastic housing = RM380
Steel thermostat = RM 250 + o-ring = RM8x2=16
Labour = RM50
First time going to this shop.. is that reasonable?
Radiator plastic housing is the one on the left & right side of radiator right?
I changed mine last time, left side for RM60(housing price only) at jln genting klang aircond workshop.
As I remember, it is the entire housing.. well, at least thats what they told me..
I'm new and not sure if this is the right place to ask.
Please recommend good BMW workshop (I don't want to go AB or the authorised ones which cost a bomb) to do repair and servicing work.
Currently, my E36 has problem with the auto-lock, alarm and P, ABS, Airbag lights are always on.
Thanks. :)
Forgive me, I found the appropriate post regarding workshops.
May I know which workshop is this?
Hi Ezzo,
my e36 325 is due for a radiator replacement.
1) Can u share with me which workshop this the below for you?
2) How many times have you engaged their service and how do you rate them?
Regards,
Joe
ezzo369;676959 said:
e36 318i
It's all started when my radiator leaked and at the same time only knew my condenser also leak so i send for parts replacement as below:
25/05/2011
coolant (2unit) rm80
tube rm80
radiator BEHR rm750
aircond resistor rm230
condenser rm235
aircond gas + oil rm80
waterhose rm80
labour rm110
total rm1645
then, the disease moved to head gasket as it leaked
3/6/2011
head gasket rm165
timing gasket rm88
thermostat housing rm58
timing rubber rm48
timing oil seal rm45
hose rm18
hose manifold rm24
workmanship rm280
Total rm726
then i was gatal to change rear bearing
9/6/2011
bearing rm145
labour rm70
Total rm215
to prevent my belt from snapping in long journey, i changed it
23/6/2011
fanbelt tensioner rm195
aircond belt rm50
labour rm40
Total rm285
to improve my ride quality, changed these:
21/7/2011
lower arm bush rm195
rear brake pad rm120
rear brake sensor rm45
press bush rm45
aircond pulley rm80
labour rm65
Total rm550
the cancer moved to the water pump causing it to leak
water pump rm185
labour rm35
Total rm220
today my fuel pump and starter has ended its life
3/10/2011
fuel pump rm550
starter rm350
labour rm30
Total rm930
Hi John_Smith,
My e36 325 is due for a radiator replacement.
1) Could you share where did you get your Behr Radiator for RM 595?
2) Which workshop did you had these fixed?
Regards,
Joe
Hi Loafer,
Could you recommend a workshop for a radiator change?
My e36 325 is due for that and I have no clue which is a reliable workshop for this.. :)
Thanks in advance..
JC_BMW;765085 said:
Hi John_Smith,
Regards,
Joe
I tthink it best to PM Ezzo..he might not be reading yr post here...just my 2sens
guys,
my 325 change below things:
1. one long belt - RM90 ?
2. oil pressure short Hose connect from vanos - RM170 (but i checked Bavarian only Rm80-100)
3. timing/crank shaft oil seal - RM90 (but i checked Bavarian only
Hi jc, i maintained my ride at the specialists workshop that i trust in melaka n jb. But i believe each of us has their own garage that they prefer
speedevil7615;765236 said:
I was like huh, what. He said ur engine is m-sport version, parts is more expensive. Huh??
Which workshop was this?
