e36 parts & maintenance
loafer;725092 said:
Yes that's the right price. RM290 for B pillar per piece. I replaced mine last time and didn't want to be bothered with chopshop ones.
A pillar is around RM200 if I remember correctly. C pillar is close to RM400.
Sunvisor just get from Ebay it's cheaper.
Bro, can PM me the name and location of the shop? I was quoted Rm250 Each for A pillar and RM500 each for C pillar without wrapping. Can save up to Rm300 with your price..
Are you talking about brand new price or just to rewrap?
I'm talking about brand new item from bavarian auto.
If I remember correctly a pillar is around 200. Could be wrong though cause it's been quite some time since I last checked.
Hi. How much standard 318i spring will cost. Need to change the sport spring. Car too low. Please share.
jeffreyewe;715599 said:
Latest repairs
Front and rear Bilstein B6 - RM 2660
Absorber mounting front - rm85 x 2
Absorber mountings rear - rm 45 x 2
PU Absorber dampers - rm45 x 4
I am thinking of changing my absorbers, 5 yrs old 80k km.
How do you find the Bilstein B6 absorbers?
What were you using before.
Tq
Anxious
Tq
Anxious
Please check your Pm :)
Just service and changed rear disc and brake pad. Total rm606. Oil castrol magnatec and filter rm145. Textar Rear brake pad and rear new disc rm461. New tinted rm700. Puspakom/jpj tear the tint when changing ownership. Try the manual reset method with the mechanic, worked well. Jumper the pin 7 to 19 for 4 sec. I just start driving my e36 today. Hope sifus here guide me.
Thanks,
Joe (das)
Thanks,
Joe (das)
Joe_pkb, am also newbie... what for the manual reset.. itu shot2 kan pin 7 to pin 19 for 4 sec?
bro unos
it is to reset the service light at ur instrument panel...usually ur mech will do it for u evrytime after u do ur regular service
bro unos. its to reset ur meter panel indicator for oil change. only able to reset after 2 try. mech did the jumper i check the panel. once the indicator change color, switch off the key.
lol u can swap with ezzo since he is searching for sport spring and u are searching for standed spring let him top up a little bit of money haha
Model E36 325i
hi everybody, i am new in this forum and i just got the car with me 1 year ago.
here is the problem:
i met in a small accident last month and after i repair from shop.
1) i facing some big sound " grgrgrgrgrgrggr " when i need a sudden pick up ( fully step on throttle even the key ), doing turning got " tik tik sound, not often " 2 times within 10 turns.
2) the exhaust like louder n feel the gas not release fast enough from the exhaust, ( observed from the rev meter, it normally drop very fast), something block ?
3) in Neutral Mode, passenger seat shaking, slightly push on pedal also feel abit shaking.
4) can the door lock handle adjusted ? the door is not parallel enough when closed .can heard some sound from outside, if cant adjust, any way to make the door lock tighter ?
5) anyplace can do service on TEIN suspension ? i asked 1 shop, offered 1k for service..
i am around taman segambut/ kepong / mont kiara / , but i not familiar with places n shop here ... any recommended from you all, really thanks alot.
BMW E36 325i
Water Pump 1pc RM225
Fan Belt Tensioner With Bearing Rm250
Bonet Absorber New 2pc RM190
Service Vanos RM180
Bridgestone 225/45R17 MY - 01 New Tyre 4pc RM1800
Crome Valvle 4pc RM8
Steering coupling New 1pc RM980
Labour RM80
Radiator New RM780
Coolant 1.5L RM55
Axle Mounting 2pc RM335
Axle carrier bush 1pc RM155
Labour RM180
Luquimoly10w40 2pc RM216
Oil filter 1 Pc Rm25
Air cond resistor 3pc RM360
Will Update for more
Hi All,
Did any sparepart sell new underhood heat shield like below. Sometime, it called engine soundproof, i dont know what it exact name, but i need new one of this item.
