e36 parts & maintenance
can i know where to get ATE brake pads and how much for the front side ?
RM125 from 1st Division for ATE/Jurid, but that was about 4/5 months ago [/b]
It's still about the same price. Jurid bites better than ATE, but heaps more dust. I think these 2 are the only OEM pads available here.
crymson, if including the "used" valvebody, yes. The most important parts in gearbox overhaul is the valvebody and the clutch kit. Other wear and tear parts that can hike up the price is the valves.
ha ha i got jurid today from BA
jurid front cost rm110
sensor rm25
labour rm25
total rm160
ok ah the price.
sensor            rm25
labour              rm25
total                rm160
ok ah the price.
Thats good price. Where did u changed them?
Affan
Thanks bro. My kereta sudah masuk. My clutch plate/disc (something like that) and some springs yang dah bengkok. My valvebody still good :(
Hi guys!!! latest edition to the club.
Need assistance 2 find a reliable w/shop in the vicinity of Subang Jaya that can thoroughly diagnose d condition of my vehicle.:blush:
Any advise on what part of the vehicle would require immediate attention. BTW the vehicle's mileage is approx. 204km.
today my fuel guage meter out , show empty all the way eventho the tank is full scarary la. go to kayu ara fix it
labour rm25
no parts chaNGE . happy again hahaha
labour rm25
for e36 328,
pls tell what they did as mine have the jumping fuel gauge. read the thread on the wiring around the two senders, checked ok. may try to open the senders/pump this weekend, waiting for tank to deplete a bit to less than 1/4 full before i will try.
told that new senders and pump are expensive, any repair/ cleaning possible?
kayu ara "optimum".
any advise appreciated.
tks
sorry i dont really understand what you saying .
... what they did was open the back seat and the you will see the fuel pump then he told me just solder it back onli then done
hope this could help
ok, tks,
willl check the wiring again for loose termination, as the last time, looked ok only.
For e36 318i (94 model)
Change timing belt and service recently and below was how it cost me (would definitely cost more if I went to Auto Bavaria):
Timing belt - RM 130
Adjusting pulley - RM 144
Bearing - RM 66
Bearing - RM 65
Oil filter - RM 35
Coolant - RM 40
Fan belt - RM 30
Air cond belt - RM 35
Steering belt - RM 30
Bearing air-cond RM 120
Conoco Gold - RM 120
Labor - RM 200
Total RM 1,015
Bearing - RM 66
Bearing - RM 65
Oil filter - RM 35
Coolant - RM 40
Fan belt - RM 30
Labor - RM 200
Total RM 1,015
bro ...it's still slightly expensive for an M40 engine ...
timing belt ~ 70
adjusting pulley / bearing / bearing --- sometimes no need to change one.
oil filter ~ 25
the belts ~ slightly below 30
the rest ... never did before .
where did you perform this at ?? if ya don't mind sharing :D
Decided to overhaul the auto gearbox as was experiencing some 'slipping' of gears during acceleration. Breakdown of cost :cry:
F/L Strainer RM48
Spacer Ring RM102
Clutch Set RM822
Return pipe? RM322
p Pressure ring? RM63
Oil Seal RM68
Clutch Cover RM350
Clip RM85
Transmission Fluid RM250
Clutch plates RM175 (@RM35 each)
Pressure plate RM150
Workmanship to overhaul gearbox RM1300
Total RM3,735 :cry:
But feels waaaaay better than before the overhaul. Fuel Consumption also much better.
but the damn mechanic lost a set of my car keys and alarm control at the workshop.
I know who to find if my car goes missing one of these days :aggressive: :angry:
sure np crymson
it's a workshop in USJ.
Always sent my car there for servicing, so just decided to let them do the overhaul.
I suppose it depends on what needs changing during overhaul.
The slipping wasn't noticeable but just thought might as well before get headaches later
