Guys,
It has been 6 months since I got my "baby", and the pleasure of driving it is totally unbelievalbe.
However, the pain of owing one is unbearable though. Here's the damages which I wanna share with you all. Here it goes
Normal Servicing and Power Steering Rack Replacement
Air Cond Belt , Automatic Gear Oil , Battery, Mobil Engine Oil x 2 Cans, Oil Filter, Power Steering Hose, Power Steering Oil X 3 Cans, Power Steering Rack, Spark Plugs x 4 pieces, Wheel Alignment, Window Rubber Casing - Driver Side
Total Damage = RM2,740
Water Tank Motor = RM205
Engine Water Leak
Water Bypass Hose, Frong Bornet Absorber x 2 Pieces, Coolant
Total Damage = RM258
Replace New Alarm = RM880
Replace Power Steering Pump
Power Steering Pump, Power Steering Oil X 2 Can, Labour to change power steering pump
Total Damage = RM674
Replace Lower Arm Joints -Front
Lower Arm Ball Joint - Front 4 Pieces, Lower Arm Bush, Front Arm Rod - Front 2 Pieces, Labour to change lower arm
Total Damage= RM839
Top Overhaul
Engine Top Set Gasket, Radiator Cover, Timing Oil Seal, Thermostat, Air-Cond Bearing, Tensioner Bearing, Oil Filter, Alternator Bearing, Cyliner Oil, Spark Plugs x 4 pieces, Labour Charges
Total Damage = RM1,619
Change Brake Pads and Shock Absorber
Brake Disc - Front x 2 Pieces, Air Filter (BOSCH), Brake Sensor - Front
Brake Pad (JURID) - Front, Shock Absorber - Rear (BOGE) X 2 Pieces, Absorber Mounting X 2 Pieces, Labour
Total Damage = RM884
Change Manifold Vent and Hose = RM323
GRAND TOTAL DAMAGES TO MY WALLET = RM8,422 :beaten: The pain for sheer driving pleasure........
