Lee36328;642994 said:Bought a pair of GY Eagle F1 (front set was still ok, rotated to the back, new set goes to the front.)
blackcategory;643006 said:ouchhh.... i think strut bar doesnt help on this...
2wenty6;643086 said:Aren't new tires supposed to be on the driven wheels?
Lee36328;643096 said:I like to have soft fresh tires in front, where I can feel them in the steering wheels.
Also, the thinking was, the rear will wear faster, so swapping the slightly worn front tires to the back will refresh the tires at a faster rate.
Usually, this is not an issue because I would change all four at once. But with the Eagle F1, the front were still in good tread condition.
2wenty6;643127 said:Just highlighting that it could potentially alter the balance of the vehicle and give it a dangerous tendency to oversteer if worn tires are mounted on the rear wheels, and having grippy new tires up front.
Obviously you know what you're doing :top:
I'm just throwing this out there because I realized a few tire shops just go by the new-tire-up-front rule of thumb and are sometimes ignorant of the driven wheels - probably more a technician fault than the shop in general..
Lee36328;642992 said:For the front, the e36 can use the reinforcement plate from the Z3 M and the e36 M3 (same part).
It looks like this, and goes underneath the front shock tower.
Here's the part number: 31312489795
I have ordered a pair.
NewBeemw;643178 said:Hi there, how much did it cost you for the part? Planning to get it for my car. Thank you.
Lee36328;643169 said:That's a good point to bear in mind, thanks for pointing it out.
The front does not wear the tires down as much as the rear. So, toward the end, the rear has worn out a lot while the front was still quite fresh.
Now, with a new pair installed at the front, and the front recycled to the rear, we have the same configuration again, with the front having slightly more tread than the rear.
So, I don't expect much change in the behaviour of the car.
I am now getting annoyed with a persistent vibration from the front. Checked the wheel bearing and ball joints, they were ok. Ah Ming did a thorough on-wheel balancing (although he did not rotate my tires on the rim like I asked and instead put two dozen weights on the rim, the obdurate git!) and guess what? Still vibrates. Going to go back to do the alignment to see if that helps. If not, I suspect possibly shock absorber mounts.
Mr Lee, i'm sorry i did not reply sooner bcoz my car had been involved in an accident on the 11th May that is one day after i last posted here. My car was rear-ended, due to the impact my car swerved from the originally middle lane (in MRRR2 near Pandan Jaya) to the left curb, hit the curb, airborned and then hit the soundproofing wall 10 feet high and then bounced back crashing down to the left lane. Sadly to say that my beloved is total loss (well that's what all the mechanic said, coz the insurance adjust has not seen the car yet). But IMHO it's a total loss and i don't want to repair it takut nanti sudah siap tapi jalan macam ketam kan.Lee36328;636407 said:I would appreciate that, thanks.
5150;643542 said:Mr Lee, i'm sorry i did not reply sooner bcoz my car had been involved in an accident on the 11th May that is one day after i last posted here. My car was rear-ended, due to the impact my car swerved from the originally middle lane (in MRRR2 near Pandan Jaya) to the left curb, hit the curb, airborned and then hit the soundproofing wall 10 feet high and then bounced back crashing down to the left lane. Sadly to say that my beloved is total loss (well that's what all the mechanic said, coz the insurance adjust has not seen the car yet). But IMHO it's a total loss and i don't want to repair it takut nanti sudah siap tapi jalan macam ketam kan.
Admitted to Tawakal for 1 week, no injury at all except a compression fracture in my T12 at my spine. Can walk and drive and do normal activities but with some pain. now still on mc.
Anyway congratulations Mr Lee for you have performed the rear shock tower mount reinforcement job! welding is the way to go bcoz in bimmerforums there are guys who did not weld but just bolted the plates to the absorber and after a while the tower cracked again.
God willing i wanna get myself another manual 6 pot E36 again with the insurance compensation and i hope you can help me bring my car to the workshop that did the superb job on the rear tower mounts. Well that is, when i do have the car hehe....
