Lee36328
- Dec 8, 2004
- 2,610
damnu;481860 said:Hey all,
Am currently looking at a 328 which has already been converted into a manual. However the gearbox is from a 318. I remember reading somewhere from this forum that the gearbox from the 318 and 328 have different torque ratings. Do they both share similar gear ratios? Will this be an issue later down the road (in terms of parts durability)? The origins of the flywheel are also unclear. I've driven the car and the shifts and all seem pretty smooth.
damnu,
Thanks for your post. Regarding the manual gearbox, I'm no expert, but it is clear that the torque from the 328 engine is much higher than the 318, so the torque rating may be a relevant point.
As for the ratio differences between e36 318 and 328, here's what I found.
318i/is/ic, 323i/is/ic, 325i/is/ic- getrag s5d 200/250 g
1st 4.23, 2nd 2.52, 3rd 1.66, 4th 1.22, 5th 1.00
328i/is/ic, M3- zf s5d320/s5d320 z
1st 4.20, 2nd 2.49, 3rd 1.66, 1.24, 5th 1.00
damnu;481860 said:Btw, do both gearboxes share the same clutch plate? I'm currently driving a 318 manual but the transition to 328 wasn't quite what i expected. I was sort of expecting a "squish you in your seat till you cant move" kind of acceleration but instead it's a bit more wafty, a smooth progressive kind of pace. Is this how it's supposed to be? This is my first drive in a 328 hence I have no basis for comparison.
I have not done the conversion to manual yet, so can't really answer from experience. However, the 318 manual is lively, because of the manual gearbox. The 328 auto has loads of torque. The 328 manual should be even better. I think what you'll find is that the 328 manual should get to a higher top speed, and get there faster.
damnu;481860 said:There's also a faint clicking noise from the engine and was told that this was due to the tappets wearing out. How crucial is it to replace this? Or is it just an annoyance like the worn hydraulic tappets in an M40 ie not critical, change it only if you can't stand the noise anymore.
Appreciate your thoughts.
Cheers
Hard to diagnose noises via the written medium. But I'd get that noise looked at.
Will check w my mechanic and let you know what's the comment about tappets.
Cheers.
Meanwhile, update on my ride.
Changed a bunch of pulleys when the engine got whiny during cold starts. Couple of new pulleys and new belts later, she's purring again and pulling like a much younger car. Less vibration too.
Amazing the improvements you can still get with some minor maintenance on a car this age.
