willy5;750459 said:Hi All,
Does anyone have a problem with wind noise? I am interested in the 320d but having tested 2 different units, I found them noisy even at 120 km/h.
Thanks
whynmy;750717 said:Got but acceptable to me..coming from an accord user
tIANcI;750768 said:Wind noise is subjective ... Best to have some form of metering.
My previous E90 definately has lower wind noise compare to Camry (currently own one) at high speed. If compare road noise, Camry better. That's probably due to RFT.willy5;750755 said:I am comparing with e34, e39 and Camry which are all much quieter as far wind noise is concerned.
willy5;750753 said:Hi Chee Huat, the test was for F30, both CBUs so quality shud be better right? Which leaves me wondering.
tIANcI;750777 said:Willy ... Best then if just stick a chopstick into your ears. Then semi deaf. After that buy hearing aid and can change volume level la :0)
Thanks tcyeow, is it just shhh..sound or rustling sound? What i heard was quite loud rustling at 100 and above which was annoying, if your doesn't have that means it is not inherent in the designtcyeow;750922 said:I do notice slight wind noise in my F30 320d but at 160+km/h ... heard from SA that there was a similar comment from another owner of same model
