E46Fanatic
- Dec 7, 2004
- 2,893
Schwepps;432063 said:You miss your better half when she goes to the spa or saloon for a few hours too, right astro?
You're lucky you'll get your brake consumables changed under BSRI then. Mine is strange: 80k more for front and 49k more for rear. Coupled with only 1mm wear on my front tyres, I don't understand it. My odo is 24k already and I use the brakes like everyone else, although maybe slightly less. This is not a 911 which wears the rear brakes and tyres more due to the rear-mounted engine. Do you guys think I have a brakewear sensor fault?![]()
Yeah definitely something wrong with your front brake wear indicator. No way the rears will outlast the fronts in the first place
