azfarhisham;518527 said:oh really? thanx for the heads up. then might as well just wait until monday for the engine oil change. sorry if i seem a bit paranoid, my first udm. hahaha.
Longines;518710 said:hye guys,
i am having the same probs in topping up engine oil.im using petronas fully synthetic(3000).If i left the car engine(320 i) running without accelerate ,heavy white smoke present...any comment?
im looking for original spring,doesnt matter new or second hand for my 320I.....
year:2005
model :320 i
4 cylinder
pls help me out...anyone?
astroboy;518701 said:This engine oil level sensor I think not very reliable because I keep topping up after seeing quarter short, after about a liter poured in, lever still show quarter short..![]()
Schwepps;518735 said:That's supposed to be monitored directly by sensor! So how accurate do you think the RFI is, in terms of telling you when your tyres need topping up?![]()
So now I don't care, as long as no "+1L" pop up, just treat it as "Enough".
Even my rear brake use counter still show 17,000km to go but visual seen less than 4mm left..
Lesson learned is not all electronic counters can trust! Common sense still prevail!
By the way, I saw the X1 2.0d engine has dipstick!!Reverse technology?! Take a step back in tech advancement?!
is normal ....my E90 320i having the same problemMSport;333013 said:Guys,
For those with E90 325i, do you experience that your engine oil level drops to the minimum level? This happens after doing about 9,500+ to 10,500 kms. Then, you will need to top-up 1 liter.
From what SA service man said, this is normal for the 325i but does not happen on the 320i.
Anyone else experienced this?
etquah;520278 said:So far my e90 LCI no need to up engine oil so far
dickytan20000;520263 said:is normal ....my E90 320i having the same problem
