Top up engine oil advise!
wt29
Hi all E46 sifus, I got engine oil burning problem at the moment, so last service, I am using Mobil 1 5W-50 full syn oil, currently oil stick shown my E46 engine oil below minimum level, can top up with semi - syn engine oil with cheaper price? Please advise. TQ. :listen:
hi, i dont think changing to semi-syn is gonna solve ur problem... time for heart surgery!!
better get it checked wt ur mech...
thx
wt29;344940 said:
Hi all E46 sifus,
dun mix fully & semi-syn together, if you need to topup, make sure its the same grade, if both different brand but same viscosity & same fully-syn then its OK
Unless you run out or in emergency, or else stick with same oil. Preferably same brand, same grade.
If you are burning oil, and need to top up often, change to semi-sync. And top up with semi-sync.
