Schwepps, I thought I asked u to send your brand new 18" RM1.8k RFT to the celup tyre place to grind 20% off to make it even with your other tyre?!
No worries beemerx! We seldom agree with each other anyway, but end of the day, you are the best judge as to which ruler suites u.. we are all matured adults who has all just past our 21st birthday recently.. :wink: and understand that basic concept of peaceful coexistence, to agree to disagree..
Back to your questions.. its all about understanding of what u are doing and the potential risk that comes with your decision.
Left/Right tyres ideally must be the same size, tread pattern, tread thickness, same manufacturing year, from the same factory. Reason being if they are not equal, there's a risk of traction/grip variance/gap between the 2 sides of the car and can potential put the car in a spin when all the elements for disaster tallies.. wet slippery road surface, high speed driving. If the max speed u ever travel is no more than 60kph in the dry, or 40kph in the wet.. I think any tyre combination will survive. The faster u drive, the more emphasis on these equation to be in check. Same goes with the next point..
To patch or not to patch an RFT.. this has been discussed many times. Ideally, one should never patch a tyre (not only RFT) because once a tyre is patched.. the "tear" which despite patched, is still a "tear" and is the weakest spot on the tyre... big tear, more weak lor.. small tear, less weak lor... but still weaker compare to a perfect surface. Common sense.
Patching also got 2 types. Interval patch or external rubber sticks.. I prefer the former which cost around RM25 compare to the RM5 sticks... The RM5 sticks is actually forcing the tear..
Put 2 tyres in stress test, one is never patched while another is patched, which one do u think will blow or disintegrate first. I'll put my money on the patched tyre.. sure habis one!
Know what u are doing, know your equipment's limit is very important when driving fast. I speed a lot in my MPV.. despite botak tyres.. all 4 tyres never patched before, and I only speed on dry surface. Wet surface, I never exceed 120kph. I know my limit, I know my equipment's limit.
When was the last time u check your tyres for hair line cracks? Ask yourself..
