omg haha that picture is sure scary.. btw i done mine up d i just took the original wire to the angel eyes and connect it to the new ones..
the eyes are great~!
here is the 1 way of doing the wiring.
1. The angel eye will light up slowly when the door is open via remote and dimmed down when the door is locked.
2. It will also light up when the door is open.
3. It will stay ON when the engine is started.
just tested the wiring and based on jarance's diagram, i plan to modify a bit where the white wire will connect to the pilot lights so that it will turn on when u flip the LCM switch to position 1 instead of having it always on when u start the engine.
installed the remote trigger to car interior last nite. at the car wash just now a man thought I forgot to turn off the lights, told him "oh nanti padam sendiri". so cool!
I measured the current and it draws roughly about 500mA for 2 rings (one side). If connect the yellow wire to the dimmer lights, it will draw a total of 1A off that line. Not sure if the LCM's internal regulators are able to supply that high current and I need to measure the wire gauge of the dimmer lights.
what is the amp rating for the relay? 20 Amp or 30 amp? what im going to do is relay 85 is from the low light no 1..then 86 grounding...30 is direct battery and 87 is going to the LED...
This Sunday. All are welcome to join. Free for all.
Place: ToyzMech, Lot 79, Jalan SS25/32, Taman Mayang.
Date: 3rd Oct 2010 (Sun) and Time: 12:00 noon onwards
Map to ToyzMech. (next to Carlz Benz workshop)
1. From Federal Highway, turn to LDP toward Damansara)
2. Turn Left at Church and proceed to small roundabout.
3. Make a sharp U-turn after roundabout to Jalan SS25/32, Taman Mayang
