Daiichi, what car are you planning to install the angel eyes on? if its the e46 ci facelift like your avatar need to check again with Jarance because I heard the rings are of different dimension.
Dear aidilj,I was offline until now. Thanks for your feedback, actually my car is sedan type, the avatar is my dream buy but couldn't find a suitable car yet. I am also buying it as backup in case my current angel eyes goes kaput. It's CCFL type which has a tendency to melt once a certain time frame is reached. Cheers :top:
Just got a call from somebody who try to DIY himself. It was notice that the ring does not fit the headlamp diameter.
This is normal. it should not fit the headlamp diameter (both same) but should fit the front plastic profile.
From the picture below the high beam have a smaller diameter and so the smaller ring should be installed
on the high beam side. It should adjusted so that the ring appear full when the front plastic profile is fixed back
to the headlamp.
