- Feb 7, 2011
- 3,558
- 83
Where do u live bro? Perhaps some member can recommend a place thats nearer to u.Can advise which shop does the best a/c servicing?
Reasonable price. Should consider replacing gear box oil if you have not done so previously.520d 100k service-
As per my bill-
1) service standard scope - RM36
2)Engine oil service - RM54
3)Service fuel filter - RM90
4) Microfilter service - RM54
5) set oil-filt - RM118.05
6) Change of door handle labor charge -RM54
7) Fuel filter RM245.09
8) Hose clamp RM6.91
9) Filter set RM664.54
10) Filter elmnt RM337.88
11) BMW 5W30 engine oil RM327.60
12) door handle - RM376.30 (bought from Bavarian autos)
Engine sound seems heavier now. Any advice guys?
Going back to authorised SC would set u back approx. 30-40% more from outside workshop, dependent on what service required.how much is it to service back at bmw dealer compare to the workshop outside ?
if you are from Cyberjaya, try my usual workshop located at :I’m in cyberjaya. Any good shop (clean workshop) within Klang Valley will be good
520d 100k service-
As per my bill-
Guys,
Since the earlier F10s are coming out from BSRI n warranty, lets share the parts and service cost(s) related to the maintenance and upkeep of the ride.
Aircond was not blowing cool air. Initially thought the culprit was the cooling coil. Upon further checks, found the condenser has practically disintegrated. Since the car was a UK import, mech concluded the damage was caused by winter/snow salt.
The Condenser, leaking like an overused diaper....
See through.....damage from UK's winter salt
New Behr Condenser
Damage:
Condenser RM 1640
Labor RM 180
Hi Guys,
Need your
Hi guys,
Having a problem with my F10 (5 Series).
I been adviced by BMW that my all my absorbers need to be replaced and my turbo started to have problem.
It's hefty charges literally threw me off, can I get a recommendation where I can get it replaced with much more reasonable charges.
By the way I am from Ipoh, I wouldn't mind coming to KL to get it fixed
Whats the mileage u hv clocked bro?
Hi Guys,
Need your
Hi guys,
