E90 parts & maintenance
Mine is 320i 2008 M Sport. I've changed some of the items that you changed and they are much cheaper.
For example,
Battery was about RM600
Microfilter RM180
Rear shocks 2 pcs about RM1000 (BOGE)
koktsin said:
Hi all,
I was wondering if you know any good workshops in Penang or KL areas.
I sent a 320i E90 2008 (done 35k) to a routine service at an authorised workshop. i was told that the car has oil leaking probem and battery was week so they recommended me to change the following items on top of the routine service (total was ard 5.5k i was also charged for diagnosis) and I did all of them.
Description Qty Unit Price(RM) Amount(RM)
Profile gasket 1 312.99 312.99
Removing and installing sealing cylinder hear cove] 225 225
Vacuum pump 1 1786.75 1786.75
Replace vaccum pump 1 150 150
Cover plate 1 41.81 41.81
Battery 1 1225.28 1225.28
Replace battery with register 1 105 105
TOTAL 3,848.33
then when i went to collect the car, there were some warning indicators displayed on the dashboard (dont remember exactly) as it was almost 5 months ago.
2 days later they sent me another quotations with a lot more items to be replaced!
Mechanical belt tensioner 1 492.67 492.67
Deflection pulley 1 172.05 172.05
Ribbed- v belt 1 227.41 227.41
Replace alternator drive belt 3 15.00 45.00
Replace tensioner 5 15.00 75.00
Front brake disc 2 521.99 1043.98
Rear brake disc 2 469.78 939.56
Replace front and rear brake disc 18 15.00 270.00
Shock absorber rear 2 906.76 1813.52
Replace both shock absorbers 19 15.00 285.00
Hex nut with flange 2 4.08 8.16
Additional damper rear 2 69.58 139.16
Guide support lower 2 45.94 91.88
Guide support upper 2 57.44 114.88
Sealing grommet 2 4.74 9.48
Tension strut with hydr. mount. left 1 664.02 664.02
Tension strut with hydr. mount. right 1 664.02 664.02
Replace both tension struts 11 15.00 165.00
Combination nut 4 7.56 30.24
Wishbone left 1 664.02 664.02
Wishbone right 1 664.02 664.02
Wiper blade 1 222.82 222.82
Replace both control arm 10 15.00 150.00
Microfilter 1 286.80 286.80
Microfilter service 1 15.00 15.00
Control element light 1 531.22 531.22
Flap, towing eye, primed 1 47.20 47.20
i changed almost everything except for the disc brake.. around 8k..
after a while the car was sent back again for another few k.. (i dont have the detailed records with me now on items changed, i will try to find the records when i go back home). In total, i spent more than 20k and guess what the car has been classifed as not safe to drive (jerking, funny noises, warning indicators still there) and permenantly parked at home.
i am thinking to send this car to a good workshop and get it fixed once and for all. Also, to find out what exactly happened to the car and then decide what i want to do with the sc!
any recommendations would be greatly appreciated! Anyone has similar experiences?
Thanks!
jakpo
Sent from Tapatalk V3.1.0
Pardon me guys, this is a parts price register to help out other owners with parts info and price reference. Not a suitable place for chit chats, opinions or discussions.
koktsin, most of the parts you changed are more than double the price we bought from part shop and most are listed in this thread. Please do your own searching.
When vacuum pump leaks, change the O-ring, not the whole pump. Unless your brake is failing because vacuum pump is to create vacuum for brake booster to work. Anyway, please open other thread for discussion. Thanks.
koktsin, please go to authorised service center to get it sorted out. For the price you paid currently, your workshop charged you SC price but can't even get the job done. At SC, you at least enjoy some complimentary coffee and cheese cake. Most parts and labor has 2 years warranty, Yes, labor too!
Hi Astroboy,
The car was serviced and repaired at an authorised service centre at northern region. This is the only SC in this area. I am thinking to bring the car to an outside service centre for fixing the problems.
Cheers
Merry Xmas to all
I have recently come accros a friend who is intending to sell off his 320D e90 2011 M sport spec at RM130K, do you think it is a good deal?
I was told that BMW suspension (shocks) is expensive to change, any one care to share a bit with me? Was thinking should i buy the car with montly income of about RM5K only...
kob3bryant said:
Merry Xmas to all
[SIZE=11.8181819915771px]E90 320d Msport is an excellent & fun car to drive due to its high torque plus fuel consumption is just marvelous. [/SIZE]
[SIZE=11.8181819915771px]I think RM 130k would be a good buy for a 2011 car. Expensive is quite subjective as it depend on one's earning power and some owners has even upgraded/mod their rides to a tune of multiple thousands ($$$). Looking at your income of RM5k per month, I personally don't think owning a e90 320d is a wise decision as you may have other [/SIZE][SIZE=11.8181819915771px]commitments (car monthly repayment, house/room rent, income tax, etc).[/SIZE][SIZE=11.8181819915771px] [/SIZE]
Anyone changed their engine & suspension mounting before? Pls share on the cost and mileage when its done, thinking of changing mine..currently on 110k mileage..
kob3bryant said:
Merry Xmas to all
I had came across few current owners who got their 2011 320ds at around RM120-125k couple of months ago, reasonable milleage with good overall condition. You may use that as a benchmark.
Engine mounting RM145/pac ( e90 325i N52) using 2 pac
GearBox mounting RM 27/pac (e90 325i N52 GM gearbox) 2 pac
Brought from Bavarian Auto
dear sifus,
need yr help to recommend reliable spare parts for genuine/german oem supplier. except bavarian auto.
also need recommendation for which workshop to do the installation around pj/damansara pls.
thks in advance sifus.
try bomin n munich.... located in jln ipoh kl... google for detail contact
thks for feedback! now need reliable and reasonable/cheap workshop to install parts...thks to all sifus in advance
My e90 lci mileage around 125k, front brake worn balance left around 1200km, wonder need change front disc together? Or just skim the brake disc?
In my opinion, with a 125k mileage, you gotta change the front disc altogether
_________
hernzie 08
320i 2010 M Sport
My 323 with GM gearbox, mileage is approx 52k km, intending to service the transmission, below are the parts purchase from BA Subang....
Questions, they recommended the oem trans oil as per pic below with oem trans filter but with original gasket, are these combo ok?
Thanks guys
Planning to get these changed at maybe Bomin or Autobahn, what would the labour be like?
My first time making such arrangements
Thanks guys....
Follow up on this, decided to go Autobahn Sunway to have the above all changed... Below are the total cost, think the oil filter and the coolant (1.5 litre) is bit pricey, nevertheless is my first time there, friendly boss and decent place...
The boss days is good that I got the original gasket as it comes with the o rings... So far smoother, will check for any possible leak, have not changed my auto filter on my other jap cars for what.... 13 yrs, usually just changed the fluid every 20k km...
Cheers
bro's need to find out how much to change 2011 320i valvetronic actuator motor, is it normal for it to fail at 100K KM ?,
today changed items below
pentosin zf6 pentosin ATF 7L RM65 per litre = RM350
ATF pan with gasket RM350
sealing sleeve RM80
oil level sensor (OEM) RM280
BMW oil filter RM75
hi gear engine flush 2 bottles RM28 each = RM56
is it cheap?
