E90 parts & maintenance
Just service my e90 2007 today. 25/02/2012
Mobil 1 0w-40 4+1L rm321 from bought petrol station. Spark plug 4pcs rm116 Oil pan rm385 Oil filter rm42 7L ZF lifeguard auto oil rm385 Led white ring marker rm350 Labour rm200
02/7/12
1 pair rear absorber bush Rm210 1 pair rear absorber (boge) Rm720 1 pair rear brake pad (textar) Rm275 1 pair brake sensor Rm70 Labour charge. Rm150. Total damage Rm1425
01/10/2012
valvetronic motor Rm1800
15/10/2012
Century battery Din 100L Rm460
27/2/2013
Mobil 1 0w-40 bought from tesco oil filter Rm42 1 pair bonnet absorber Rm170 5500k white colour fog light bulb Rm110 labour charges Rm60 total Rm382
02/03/2013
1 pair absorber front Rm960 1 pair absorber boot Rm110 1 pair absorber damper Rm170 1 pair absorber mounting Rm290 labour charges Rm150 alignment Rm35 adjust camber Rm40 total Rm1755
3/5/2013
upper arm bush 1 pair Rm300 to pump bush Rm30 labour Rm60 total Rm390
25/5/2013
water hose Rm145 head cover valve Rm235 vent hose Rm168 breather screw 1 pair Rm32 engine flush Rm50 mobil 1 0w-30 engine oil 6 litres Rm322.50 oil filter Rm42 vanos o ring 2 pair Rm60 labour Rm260 total Rm 1314.50
19/7/2013
225/45/17 4pcs csc5 rft tyres Rm850 per pc with balancing and alignment
15/9/2013
gasket Rm750
oil filter rm40
5w-30 engine oil rm290
alternator pulley rm230
labour rm500 Total Rm1810
16/12/2013
coolant Rm50x2 Rm100
water hose and steel Rm185
coolant pipe Rm530
labour Rm80 Total Rm895
18/12/2013
Mounting Rm600
window lifter p rm490
power window-used rm250
labour and computer scanning rm110
14/2/2014
front brake pad(textar) Rm195
front brake sensor 1pc Rm50
wiper Rm130
Labour Rm15 total Rm390
2/5/2014
coolant Rm50
vent screw RM50
skim disc Rm70
labour Rm40 total Rm193
18/5/2014 (100k km)
air con compressor rm2100
air con dryer rm300
oil filter rm40
engine oil rm290
labour rm50 total rm2780
Hikaru said:
I just changed all four of my absorbers front and back. Now the car rides and takes bumps beautifully. I went to Bilstein B4s.
The breakdown is as follows: -
B4 Fr: 350 x 2 = 750
Fr Bellows: 15 x 2 = 30
Fr Damper: 20 x 2 = 40
B4 Rr: 280 x 2 = 560
Rr Damper: 20 x 2 = 40
Rr Dust Cover: 15 x 2 = 30
Rr mounting bush outer: 35 x 2 = 70
Rr mounting bush inner: 35 x 2 = 70
Discount 20 from Munich Auto, Jalan Ipoh
Labour 300 Total 1820.00 Haven't do alignment yet cause front upper arm (270 per piece) is loose so need to change that and front disc and brake pads needs to be changed too. Will do it tomorrow.
2nd Round of Repairs including:-
1) engine oil change,
Oil Filter - RM47.00
Motul Engine 5-40W Full Syn - RM220.00
2) leaking engine
Heat Exchange gasket - RM20.00
Oil Filter gasket - RM13.00
Sump gasket - RM55.00
Valve Cover gasket - RM300.00
3) ATF oil filter change and ATF oil change,
Pan W Filter - RM260.00
Auto Trans Fluids - RM400.00
4) Engine Mounting - RM167 x 2 = RM334.00
5) front upper arm
Upper Arm RM270 x 2 = 540.00
6) front & rear pad and front disc
Front Brake Pad - RM120.00
Sensor - RM35.00 x 2 = 70.00
Rear Brake Pad - RM160.00
Front brake disc - RM150.00 x 2= RM300.00
Brake Fluid - RM60.00 x 2 = 120.00
Labour for items 5 & 6 only RM430.00 (Power Booster & Air-con Service, Kuchai Entrepreneur Park)
7) Front Bonnet Absorbers RM70 x 2= 140.00 (D.I.Y)
8) Alternator - RM1,100.00
9) Tensioner Roller - RM70.00
10) Front Link Rod - RM180.00
11) Wheel Alignment & Adjust Chamber (rear) - RM90.00 (KLH Car Tyre & Services, Jalan Ipoh)
Labour for items 1,2,3,4,8,9 & 10 is RM550.00 (Exotic Specialist. No name)
This is considered major service. Almost all of the front suspension has been changed. I hope there won't be anymore but its likely that more will come in terms of suspension. Atleast the engine compartment is clean and leak free and the coolant is water tight.
Model: 2010 E90 320d
17/08/2013:
--Milleage: 38,000km
Engine oil service (RM372)
- Ravenol VMO 5W-40 (5L) = RM232
- Oil filter (PN# 11427807177) = RM90
- Labour charges = RM50
06/09/2013:
BMW iPod/iPhone USB + AUX Adapter (PN# 6112 0440 812) = RM45
19/12/2013:
--Milleage: 45,000km
Normal service (FREE under BSRI)
- Castrol Edge Professional 5W-30
- Micro filter
- Fuel filter
- Wipers
15/02/2014:
--Milleage: 49,525km
ATF & brake fluid replacement (RM403)
- ZF Lifeguard6 (RM50/L) x 6 = RM300
- BMW DOT4 Brake Fluid (1L) = RM53
2007 E90 N46B20
08/09/2008
4L Torco SR-1 5W-30 @ $55/L: $275
07/12/2009
Repair windscreen (star break): $120
13/03/2010
2 pcs Yokohama S-Drive 225/45R17: $900
Alignment: $120
30/04/2010
2 pcs Michelin PS3 225/45R17: $1,040
31/07/2010 (40k km ATF service)
7L ZF LifeGuard 6 transmission fluid @ $55: $385
07/04/2011
Oil filter: $30
4L Castrol SLX Powerflow 0W-30 $195
1L Torco SR-1 5W-30: $55 (to top up the balance of 4.25L)
Total: $280
14/04/2011
Respray front bumper: $300
25/06/2011
Coolant (S1229407454 OE) 1.5L: $32
02/07/2011
Brake fluid (83130443028L): $48.17
Labor: $90+$30
Total with tax: $175.35
01/08/2011
Alternator 1 way bearing: $267
Fan belt tensioner bearing: $106
Labor: $45
Total with tax: $420.70
15/10/2011 (60k km oil service)
Oil filter: $33
4L Castrol Edge 0W-40 $145 (bought from Tesco.. )
Total: $178
14/10/2011 (standing by for next change, estimated in 2 months time, will time it before sensor hancur.. )
TRW brake pads, front and back: $300
http://www.bmwclubmalaysia.com/forum...l=1#post681082
18/10/11
Cover plate / engine back cover: RM38
Coolant: $30
Total: $68
http://www.bmwclubmalaysia.com/forum...l=1#post681374
08/01/12
2 pcs Nexen N8000 225/45R17: $758
4 wheel alignment (4x$7.50) + camber for LR ($60): $90
Total: $848
04/02/2012
Replaced front brake lining/pad with TRW pads.
Pad: Bought on 14/10/11 above
Sensor: Bought front and rear @ $35 x 2 = $70, but only front was used. Rear still not changed.
http://upgr8s.blogspot.com/2012/02/b...ad-change.html
03/03/2012
Microfilter: $83
http://upgr8s.blogspot.com/2012/03/b...in-filter.html
03/04/2012 (69k km)
Valeo AC Blower (64 11 9 144 201): $600
Regulator (64119222072): $350 (bought for spare, keeping in store now for trouble shooting when necessary)
Labor: $50
01/09/2012 (80k km)
Vanos solenoid o-rings: 4pcs x $3 = $12
Labor: $0 (DIY)
http://www.bmwclubmalaysia.com/forum...l=1#post767914
08/09/2012 (80k km)
2L ZF LifeGuard 6 transmission fluid @ $49: $98
Labor: $0 (DIY) 4L were used, balance came from the stock I bought in 31/7/2010 above.
http://upgr8s.blogspot.com/2012/09/b...nsmission.html
22/10/12
4L Castrol Edge 0W-40 $129 (bought from Tesco.. )
Oil-filter element 11 42 7 508 969: $30
Labor: $0 (DIY)
Total: $159
13/01/13
Heat Exchanger Gasket: 11 42 7 508 970 @ $15
Oil filter Housing Profile-gasket: 11 42 7 508 971 @ $23
Labor: $0 (DIY)
Total: $38
http://upgr8s.blogspot.com/2013/01/b...g-gaskets.html
08/06/2013 (91k km, 3rd brake fluid change, every 30k km) @ Wearnes Segambut
Brake fluid (83130443028L): $83.62
Labor: $72+$36
Total with tax: $198.10
30/06/2013
Valve cover profile gasket (Original): $180
Spark plug tube O-rings: $12
Labor: $0 (DIY)
Total: $192.00
http://upgr8s.blogspot.com/2013/06/b...er-gasket.html
07/08/2013
Window lifter rear left, 51 35 7 140 589 (Taiwan): $165
Labor: $0 (DIY)
24/08/2013
Radiator 17 11 7 559 273 (KW brand): $600
Top Coolant hose 17 12 7 531 768: $230
Labor: $150 (Include rear window reset)
Total: $980
01/09/2013
Repair kit valve seal ring 11 34 0 029 751: $60/set
VVT Servomotor gasket 11 37 7 501 015: $18
Labor: $500
Total: $578
05/10/2013
GP Atlas DIN100 battery: $650 (Labor included with ECU registration)
28/11/2013
Valve cover gasket, 1120035738: $170
Essentric shaft sensor gasket flange, 11377502022: $30
21/01/2014 (99k km)
2 PCs Michelin PS3 225/45R17: $1,040
24/02/2014 (100k km)
AC Evaporator a.k.a. cooling coil part no: 64119179803
Expansion valve Part no: 64119226078
Parts + Plus labor: $2,300
02/03/14 (100k km)
Mobil 1 0w-40: $139 (Tesco)
Labor: $0 (DIY)
05/04/2014
Alternator pulley part no: 12 31 7 560 483: $175
Labor: $60
23/06/2014: Mileage 104k km
Window lifter rear right: 51 35 7 140 590: $160
Labor: 0 (DIY)
30/06/2014 (104k km)
2 PCs Michelin PS3 225/45R17: $1,030
27/07/14 (105k km)
Tensioner pulley: 1128 1435 594: $48
Labor: 0 (DIY)
09/08/14 (105k km)
Deflection pulley: 11 28 1 440 378: $60
Labor: 0 (DIY)
11/10/14
Water pump: 11 517 511 221: $190
Thermostat: 11 537 510 959: $140
Thermostat Housing: 11 517 572 859: $65
Water Hose: 11 537 572 159: $105
Connector: 11 517 542 128: $50
1.5L Coolant: 81 229 407 454: $23 x 2
6L Spritzer Distill water
Labor: 0 (DIY)
Total: $596
29/11/14 (109k km)
Door lock with actuator L/H: 51 217 202 145: $380
Labor: 0 (DIY)
06/08/15 (115k km)
Vacuum pump: $480
Labor: $150
Total: $667.80 (GST inclusive)
29/08/15 (116k)
Textar brake pad: $160
Front brake wear sensor: $40
GST: $12
Labor: DIY
Total: $212
07/09/15 (116k)
Water pump: $180
Water pump connector: $45
1.5L Coolant: $34x2
GST: $17.58
Labor: DIY
Total: $310.58
29/10/15
Door lock with actuator R/H: 51 217 202 144: $380
Labor: 0 (DIY)
20/06/16 (121k)
SACH front absorber L+R
Lamforder strut mount L+R
Front strut damper L+R
ZF Lifeguard6 (1L) x 6 @$50 = $300
Transmission sump with strainer = $300
Labor: $400 + GST (RM24)
23/07/16
Windshield washer pump: 67 12 7 302 589: $15.09
Labor: DIY
30/07/16
Coolant flange connector: 11 53 7 560 130: $80
Hose between engine inlet and additional water pump: 64 21 6 928 590 $160
BMW Coolant: $40
GST: $16.80
Labor: DIY
06/08/16
Set of wiper blades: 61 61 0 427 668: $47.65
Labor: DIY
10/06/17 (127k)
VVT Servo Motor Actuator: 11 37 7 548 387: $500 + GST
Valve cover gasket: $150 + GST
Spark plug tube O-ring: $12 + GST
Hella Spark Plugs: $forgot
Labor: $240
10/06/17 (127k)
Labor: $240
21/10/17
Shock absorber rear (Bilstein): 33 52 6 771 725: $220 x 2
Shock absorber rubber mounting rear FEBI: 33 52 6 768 544: $75 x 2
Guide support, upper FEBI: 33 52 6 771 737: $30 x 2
Guide support, lower FEBI: 33 52 6 771 738: $30 x 2
Damper: 33 52 6 767 334:: $45 x 2
Total: $800 + $48 GST
Labor: DIY
21/10/17
Oil filter: $50
GST: $3
17/11/17
Battery DIN 100: $580
GST: $34.80
Total: $614.80
14/12/17
Starter motor: $580
Eccentric sensor: $750
Crank shaft sensor: $250
Labor: $280
GST: $111.60
Total: $1,971.60
29/09/18
Transmission overhaul: $8000 (labor & part)
17/11/18
Bosch front brake disc: 34 11 6 854 997: $150x2
Delphi front brake pad: 34 11 6 769 951: $140
Total: $440
18/11/18
Flywheel oil seal: $500 (labor & part)
29/2/20
Ignition coil: 12 13 8 616 153: $78 (Delphi)
21/5/20
Top hose: 17 12 7 531 768: $67.60 (Shopee)
27/06/20
Brake fluid renew: $120
29/6/20
Hot-film air mass meter: 13 62 7 566 989: $135.32 (Lazada)
01/07/20
Ignition coil: 12 13 8 616 153: $78 x 3 (Delphi)
Total: $234
29/07/20 (161k km)
Radiator: $550
Coolant: $35x2
Distill water: $7
Oil cooling hose: 17 11 7 524 710: $115
Total: $742
25/04/2021
Varta DIN100: RM480
18/09/2021:
VVT Actuator (Motor):11 37 7 548 387: $490 (VDO)
Valve cover gasket:11 12 8 655 413: $120 (Victor Reinz)
Valve cover Gasket-flange: 11 37 7 502 022: $15
Plug pipe o-ring: 11 37 7 514 007 x 2, 11 37 7 514 008 x 2: $2+$2+$2+$2
Total: $633
13/12/2023:
Rear shock mount repair kit, FEBI: 33 52 2 406 280DE: $58 x 2
Total: $116
Labor: DIY
14/12/2023 (186k km)
Michelin PS5 x 4@RM549 each
Total: RM2,196
04/05/2024 (189k km)
Ignition coil x 1: $200
Spark plugs x 4: $140
Labor: $120
Total: $460
Ouch on the cooling coil.
However, your tyres are pretty decent for that price. Mind sharing where you go them?
I went with Goodyear AS F1 at around 600+ per corner. Was thinking of going back to Michelins......
Just to share...
Felt the N52 engine juddering only at speeds above 120kmph (occasionally). As suspected, misfiring :(
Took it to Super Excel Car Service at Transfer Road, Penang to get diagnosed.
Changed one ignition coil (Bosch 0 221 504 470) as cylinder 5 was misfiring. Also changed all 6 spark plugs (Bosch FR 7 NPP332). Parts and labor costed RM350.00 and 2.5 hours.
As a result, the engine was performing much smooth at speeds below 40kmph. Before the change, the engine was slightly rough even at zero throttle.
Hi, anyone can recommend me the battery for 320d, model and price.....workshop in Puchong ?
Many Thanks.
You may call him for delivery.Century DIN100L Rm410 with free installation and trade in battery.
Delivery Service Hotline:
017-384 1229 (Vincent)
Hey guys, I m still new with my BMW 325i, here to share details of my maintenance:
Service at M1 Kayu Ara - Milleage 99,000
10.01.2014
Oil Filter : RM70.00
Spark Plug x 6: RM276.00
Auto Oil Pan Assy: RM785.00
Seal Sleeve: RM 86.60
Front Brake Pad: RM390.00
Front Brake Disc: RM932.00
Rear Brake Pad: RM293.00
Rear Brake Disc: RM840.00
Front Brake Sensor: RM65.00
Rear BraKE Sensor: RM65.00
Wiper Blade: RM160.00
Themomostat: RM450.00
Air Filter: RM99.00
Rear Air Cond Cover: RM360.00
Auto Trans Fluid 1L: RM 82.00
Shell Helix Ultra 6L: RM399.50
Labour: RM 530.00
Total: RM 6,457.10
Baidu Jalan Gasing
10.02.2014
Air Cond Cooling Coil: RM 2,050
Compressor & Condenser RM3,080
Inclusive of Labour Cost
Total: RM5,130
Lim Tayar @ TTDI
26.02.2014
AlIingment & Balancing : RM205.00
Ah Lai @ Kuchai Lama
16.03.2014
Autoatil Oil Cooler: RM650.00
Engine Solenoid Valve 2pcs: RM970.00
Overhaul Gearbox: RM8,500.00
Total: RM10,120.00
As at todate, my total maintenance cost are: RM21,912.10
*Which this is out of my expectation at all, which all the bills can be jump so high up, which there is more to come which few others issue i yet to rectify.
Thank you.
Double Wah... mileage 99k already need to overhaul gearbox? What was the problem to begin with?
No power during pick up, not smooth changing gear, stuck at 3rd & 4th gear while acceleration - only will change when u leave your feet from the acceleration pedal. High fuel consumption (16.5-17 litres/ 100km). Is that serious enough?
@kelvin1706:
Just a heads up. Most of parts you replaced at M1 costs twice or thrice as much as the market price:
- Spark plug is only about RM20 ea
- ATF pan assy is about RM260
- ATF (Original ZF Lifeguard6) is only RM50 per litre
- Brake sensors are only RM45 ea
While for alignment & balancing, a good job at MPS Sunway only costs about RM170 for on-wheel balancing + alignment.
If you know your stuffs, you will end up paying much less than what you paid there.
Thanks for sharing the symptoms so that we all know what to look out for whether there is a gearbox problem.
If the air con compressor and coil is original, then it is the price but otherwise it is expensive...
Sent from my GT-N7000 using Tapatalk 2
Changing 7L Lifeguard transmission oil at UAG Auto Section 7 Shah Alam : RM 770, changing spark plugs 6 pcs: RM 240, Prices inclusive labour and parts.
Planning to change my ATF oil soon. Any recomendation on the best oil to use? Mine is 320d LCI 184hp version. From my readings LCI model dont use ZF oil rite?
Guys, my front brake sensors have lit up... about time to change pads... already hit 55k km on the odo.
What's a good brand of brake pads to get, where and roughly how much? I would prefer original BMW or OEM. I am located in KL area...
If OEM just go to Bavarian Auto (Google the name and find the closest branch nearest to you). Don't forget to let them include in the brake sensors as well. Price wise is around rm350 for the fronts if I am not mistaken, or it could be rm450
