Been a while since I've last updated. Last service was done in May. Anyway, to continue on the list...
1. Fuel filter - SGD 22
2. Cabin air filter - SGD 16
3. Front disc brakes - RM 210 a pair
4. Front disc brake pads - RM 105 a pair
5. Goodyear RevSpec RS 02, 225/45/17 2 pcs - RM 900
6. Used starter motor - RM 450
7. Power steering o ring - RM 8
8. Reverse switch - RM 36
9. Air con service (dryer, fan belt, air con belt, o ring, gas, compressor oil) - RM 494
10. Rim refurbish plus alignment and steel valve change - RM 600
11. Vanos seal (Beisan) - RM 90
12. Valve cover gasket + rubber seal - RM 120
13. Belt tensioner - RM 120
14. Vent pipe - RM 110
15. Used air con compressor - RM 540
16. Goodyear RevSpec RS 02, 225/45/17 2 pcs - RM 1030
17. Clutch Sleeve Pump - RM 145
18. O2 sensors, Hella - SGD 160 (for 1 piece)
19. Radiator - RM 595
20. Return pipe (11531433059) - RM 134
21. Hose (13541703945) - RM 38
22. Hose (13541703865) - RM 55
23. Fan clutch motor - RM 280
24. Vacuum hose - RM 5
25. Aux fan (aka condenser fan) PN# 64508364093 - RM 560 (Vemo, not Behr. Was quoted Behr - RM 1k. Vemo part #V20-01-1065)
http://www.vierol24.de/upload/kataloge/99-9753.pdf
26. Rear door lock actuator - RM 155
27. Beru Spark plugs x 6 - SGD 6/ea
28. Fan shroud - RM 16529. Bypass hose - RM 4030. PCV - RM 278 (P/N: 11151703484)31. Door rubber RR - RM 220
New items
32. Wheel arch lining - RM 220 x 2
33. 2nd hand B-pillar plastics - RM 300 a pair
34. 2nd hand washer bottle with level sensor - RM100
