Wlvrn;353445 said:ishhh....a bit far...from subang to ipoh....fuel, toll & expenses to go there, i would pay the rm750 of the cost. not worth to go....but thanx for the info :top:
Russie;353955 said:4 September 2008:
Bought the following items:-
1) A pair of new DEPO fog light (made in Taiwan) for my E36 at RM90 per piece (total RM180)
2) Hella H1 light bulb at RM18 per piece
megatniza;353963 said:good input , my fog light is now really foggged .. he he he .
one of it is like mini aquarium oredi ...1/4 filled with water .
Russie;353970 said:Mini aquarium?get it fixed. Take out the fog light, dismantle the metal parts, then wash the inside of the fog light with dish detergent with the help of a tooth brush, otherwise moss will develop in it real fast. Then let it dry under hot sun and fix it back...u will get a "newer" fog light then
goodluck
initialM;354071 said:Wow so cheap?? Is this the crystal type? Last time I bought RM350 per pair:stupid:
megatniza;353956 said:bro ,
had checked ..apparently , they have a branch in KL .
Call Aby at MAXIS-tiga dua satu 7702
good luck
goodluck
koryong;175 said:Thot this would a great way to start ...Hope it's in the right place, since I'm a NEWBIE .....
The following were done at a BMW specialist workshop, so parts costs would be higher than if you were to source yourself.
e36 318i 1996
1) ATF flush (15L oil) RM420
2) Rear diff oil change RM28
3) Crank shaft pulley (timing pulley) RM950
4) Timing oil seal RM48
5) ATE front brake pads RM180
6) Front brake sensor RM35
7) Power steering hose RM80
8) Power steering hose RM200
9) Fan belt RM170
10) Gear box mounting RM35 x 2
11) Prop. shaft coupling RM95
12) Bilstein Sport absorbers RM1,850
13) Front absorber damper RM48 x 2
14) Rear absorber damper RM25 x 2
15 Air con micro filter RM120
16) Air adjustment valve RM420
megatniza;354202 said:... guess I need to pay a visit to the chopshop next week !![]()
USCBimmerMann;355893 said:On the subject of chopshops, where are the well-stocked ones for E36ers in the Klang Valley?
