e36 parts & maintenance
found out price of radiator at stuttgart is $500
e36 325i
wondering where to send to get the radiator changed -pj area
not get potong and unprofessional job
tomspc,
Check the thread on the workshop. Normally, i will go to M1 in Kayu Ara.
i also got the original PDC for E36 for RM 400.
Rear top rubber moulding for RM 115 and botton for RM 60.
Also got the rear chrome pipe for RM 77.
Bought the front wiper grill for RM 75 for 2 piece and RM 4X8 for the clips.
REPLACED MY RADIATOR AT STUTTGART PJ - NOT VERY HAPPY LOR
hi bros,
finally i had it done.
At Stuttgart -- duh , cos its near my work place
damage $8++
yyyyyyy.
suppose to be $590 wor
$500 for radiator
$90 service
i left the car there
30 min - they call me and said need to change few other things - sakit sakit my heart
went there - showd me a broken thermostat housing , i drive there was ok wor
said got hairline crack ---- how leh , wat to do , have i been had - this is something
all car owners dont like , send to do one thing - somethings else have to change.
after the job done - i go to see my car ,,,, undecided yet
thing is fixed lor
but my covers etc - screw loose , threads worn , expansion bottle also look like not mounted properly --- i post pic next day , u see for urself lah
i dont comment now -- see how things goes for i month , keep my fingers crossed
the part said to have 1 month warranty , somehow they dont wan to write this down
on service sheet - only after i reminded many times then write it down.
so now i have a used e36 radiator for sale - some slight leak from the plastic side - should be repairable - who wan pls pm me
when you change the radiator, normally the thermostat housing, belts, water pump, hoses are also changed. It could be cracking already.
I never mess with anything to do with coolant in Bimmers.
Show pictures on how the stuff was installed. By what you have described, the workmanship sucks.
had a heart stopping moment this morning
puddle of water under the radiator
wattt - just done the radiator
quickly take to stuttgart -
luckily the mechanice check and found it is from the hose
not fitted properly
now keeping my fingers double crossed - dun wanna any more ......
how to attach pic here ?
So I finally decided to send my car for service and not use the workshop my dad goes to (F.O.C if I go there but I kinda suspect the mech is a lazy turd). Anyway, decided to try out BMWorld at Desa Pandan since it's near my place.
BMWorld Desa Pandan 28/04/08
1. Oil filter - MYR 35
2. Washer fluid - MYR 10
3. Air filter - MYR 70
4. Fuel filter - MYR 80
5. Fuel hose - MYR 30
6. Hose Clamp x 6 units - MYR 30
7. Coolant 1.5L x 2 units - MYR 70
8. Outer door rubber mouldings x 4 units - MYR 700
9. Door handle rubber seal - MYR 60
10. Fuel pump hose x 2 units - MYR 100
11. Labor charges - MYR 150
12. Petronas Syntium 5000 (6.5ltr) - MYR 364
Total damage - MYR 1699
The fuel pump hose is for the 2 fuel pumps located under the back seat. I decided to ask the guys at BMWorld to have a look at it and I was happy I did because they were brittle and could possibly give way anytime.
All in all the service was very satisfactory and the guys at BMWorld Desa Pandan is really great. I'll definitely be going back again.
E36 Suspension Upgrade (Quotations)
The quote I got from Bavarian Auto is as follows:-
M-TECH SUSPENSION
i)Mtech Anti Roll Bars & Links (F) & (R)
RM750 each (Front MTech ARB)
RM54 each (Front ARB Link)
RM62 each (Front ARB Rubber Bush)
RM690 each (Rear MTech ARB)
RM32 each (Rear ARB Link)
– RM19 each (Rear ARB Rubber Bush)
ii) Mtech Springs– RM2,100 (set of 4)
iii) MTECH Absorbers – RM4,000 (set of 4)
(some parts no stock,need to order)
AFTERMARKET
i) Eibach ARB– RM3,700 ( front & rear, with ARB links and PU Bushes)
ii) Eibach Pro Kit Spring RM1,960 (set of 4)
iii) Bilstein yellow B8RM1,930 (set of 4)
The quote I got from Eng Soon Singapore is as follows:-
M-TECH
3135 1 090 182 stay bar F. @ S$260.00 no stock
3135 1 090 268 stay bush F. @ S$18.00 x 2pcs
3135 1 137 986 stay bar RR. @ S$230.00 no stock
3355 1 138 104 stay bush RR. @ S$6.00 x 2pcs
3131 1 091 269 Absorber F.LH @ S$320.00 no stock
3131 1 091 270 Absorber F.RH @ S$320.00 no stock
3352 1 090 831 Absorber RR. @ S$220.00 x 2pcs no stock
3133 1 090 769 Spring F. @ S$180.00 x 2pcs no stock
3353 9 059 282 Spring RR. @ S$330.00 per set no stock
AFTERMARKET
(i) Eibach Pro Kit Springs @ S$340.00 @RM782
(ii) Bilstein Yellows Absorbers(B6 vs B8)
Front @ S$260.00 x 2pcs B8
Rear @ S$155.00 X 2pcs B8
@ RM1909 per set
(iii)Eibach Anti Roll Bar KIt @ S$1450.00
@RM3335
EIBACH SINGAPORE
Eibach ARB Kit $1020/set
@RM2346
(Eibach Spore informed me that I can upgrade my ARB w/o changing my suspension)
I hope that the above information is useful to fellow forumers who may be considering upgrading their stock suspension.
I have the same problem with my steering wheel which goes wobbling at certain times while driving. Anybody knows why and d place to fix things up?
Have you tried doing a search on the forum regarding that subject? I've seen it discussed many times before.
hi everybody,
i'm a new bimmer, just want to ask where can i get a bearing for getrag gearbox e36 manual. Mine is broken and need asap to replace it.
12/03/2008 - AUTO GEAR OIL & FILTER
Labour: RM320.00
- to renew rear brake pads
- to perform computer diagnostics
- to renew auto transmission fluid
- to renew auto transmission filter
- to renew auto transmission gasket
- to renew long shaft coupling
Parts:
- ATE rear brake pads RM100.00
- Long Shaft Coupling RM195.00
- Auto Transmission Fluid 6Litre's [Dextron III] RM108.00
- Auto Transnission Filter RM65.00
- Auto Transmission Gasket RM38.00
- Gear Selection Oil Seal RM18.00
- Exhaust Rubber Holder [center x2] RM48.00
- Computer Diagnostic Works RM80.00
- Air Cond Bearings RM88.00
TOTAL: RM1060.00
19/03/2008 - AIR-COND BELT & ACCELERATOR CABLE
- Air Cond Belt [Conti] RM65.00
- Accelerator Cable RM165.00
- Labour RM90.00
TOTAL: RM320.00
28/03/2008 - ACCELERATOR CABLE & PEDAL RUBBER GROMMET
- to renew rubber grommet + labour RM20.00
GRAND TOTAL: RM1400.00
"happy wesak day"....cheers:top:
M-TECH
AFTERMARKET
@ RM1909 per set
(iii)Eibach Anti Roll Bar KIt @ S$1450.00 @RM3335
EIBACH SINGAPORE
@RM2346
Bro anxious,
I think u better dun give the conversion rate cost as I found it not accurate. Its more than what u calculate. It will be more if the price quoted not inclusive 7% GST. This is 2nd time I think did this:smokin:
initialM;325601 said:
Bro anxious,
Sorry, I guess you can ignore the conversion. Anyway, for most parts its probably better to get it in Msia.
As for GST, i thought you can get refund. Of course you may be subject to Malaysian Customs Tax.
My E36 auto window arm was "bengkok" as i tried to force the window up. Brought to mechanic and said it need to replace to new one and cost RM 3++.00. can some sifu advise me how much is it and where is it cheaper to fix?
Rebuilt my gearbox : RM3000
Replace alternator belt : RM70
Labour : FOC(included)
Total damage: RM3070
Now gears not slipping n can engage reverse instantly..
