e36 parts & maintenance
Now my turn.
(Parts bought from Spare parts shop)
1. Front Brake Pad (JURID) - RM110
2. Front Brake Disc Ventilated - RM145 x 2
3. Front Brake Sensor - RM30
4. Front Lower Arm Bush (M3) - RM65 x 2
5. Oil Filter - RM25
6. Castrol Magnetec Semi Syn - RM65 x 2
(From Mspeed)
7. Brake Oil - RM25
8. Front Caliper Kit - RM65
Labour - RM70
Total Bill - RM875....:(
An almost complete replacement of suspension wear and tear parts by Ah Meng at MSpeed, on Wed 02 Feb, 2005. This is the first time all the suspension parts are being replaced. I am trying to maintain close to stock comfort. The bilsteins feel hard now, didn't want to go with Sachs as I have been told they go soft within a year. The car has done 110,000km at the moment, but I thing the shocks started to 'ta pau' at about 90,000kming. Will let the shocks settle in for a couple of days before doing an alignment and balancing.
Bilstein Black (VNE4420) - 4 pieces..)
All mountings and dampers..............) RM1600
Labour.............................................)
2pcs inner ball joint bushes............)
2pcs outer ball joint bushes............)
2pcs lower arm m3 bushes..............) RM800
2pcs link rods..................................)
Pumping & Labour...........................)
Total Damage = RM2400.00
Please let me know if I missed anything
Got this done today;
Change Oil RM25 Labor
Conoco Super Gold 8L RM144
Bosch Oil Filter RM29.80
Bosch Wiper Blade RM108
Recon Starter Motor RM520
Labor to change Starter Motor RM100
Ouch!
:wacko:
Another bill :(
1. Front absorber damper RM35 x 2
2. Rear absorber damper RM35 x 2
3. Power Steering tank RM 70
Labour RM100
Total bill = RM410
Damn, damn, damn... my turn now... serviced at Naidu, where else!
1. Used air-con compressor - RM420
2. Modified tensioner - RM130
3. Vacuum, compressor oil, gas - RM40
4. Labour - RM65...
Damn, damn, damn... next on list - aircon belt, aircon valve... all this started when my blower blew a fuse. After that, the aircon was not as cold. Decided to send to Naidu for check-up. Now my wallet REALLY BIG LUBANG! :(
Fuel pump = RM630
Used to be in the RM500+ region but the hike in Euro rate pushed the price up. Although I was spared the heartache of needing to cough out that much money for the pump, I thought I'll just share here the price of that thing which was quoted to me.
I got my fuel pump for around RM400 plus about 2 years back. What to do lah....
Philips Silvervision - for the rear signal light - silver in colour but flashes orange - RM 58.
service @ Ah Yau, Jln ipoh
1) Stering Rack oil seal & o ring RM55.00
2) Crankshaft Sensor RM280.00
3) Steering Hose RM55.00
4) Coolant Level Sensor RM75.00
5) Fan Belt Tensioner (Top) RM230.00
Workmanship RM150.00
The seat belt on my E36 is very loose. Is there a part call seat belt tensioner? Anyone replaced it before? How much? Thanks.
OSF,
If it is caused by SBT it will trigger the airbag indicator(so is ur airbag indicator lights on?)... The SBT should cost you around between RM600-RM700..
p.s Have u seen my email?
ATE front brake disc RM 290 a pair
ATE front brake pads RM 135 per pair
Labour RM 45.
Originally posted by evangel@Dec 30 2004, 06:17 PM
Replace gear box RM15,000.00 for E36 1997, 328
( my friend did it. he is crying his heart out)
Is that price for a new gear or a secondhand unit. The last time i heard is about over 20K. :unsure:
Damage on last saturday:
Fuel pump (Bought BA) - RM438.00
Labour - FOC (DIY)
The pump mulfuction happened in the morning at home. Thks god for saving towing fee.
Bimmer suck petrol and it suck my blood too.. :nyehehe:
is there any tell tale sign b4 fuel pumps goes kaput? like a buzzing or high pitch sound etc
I remember 2 mths ago, I noticed that buzzing noise arised underneath the rear passager seat every time I start the car and Its gone in 15 ~ 20sec.
I knew that the noise was came from the fuel pump. Some clubmember has been put up this thread in the old club forum b4 and I also consulted specialist when this abnormality occured.
He suggested:
1) to change the pump now.
2) drive until not function.
I choose the 2nd option cos not willing to spend $$ so fast and I knew the procedure to replace the fuel pump as well in case of breakdown. So just took the risk and wait until it 'kong'.
Click to fuel pump replacement:
http://www.pelicanparts.com/bmw/techarticl...6-Fuel-Pump.htm
workshops quoted RM550 ~ RM600 to replace included labour.
Try on it (DIY) if u wish to save $$.
I took 30mins to complete. :D
today at M-Speed:
- replace left-side fuel pump. Why? Fuel pump neck already brittle.
- cost: RM240 inclusive of labor
Hoses cut by about 1/2 inch and reconnected.
- tires balanced and fix puncture - RM25. Tire shop near USJ (near Quicksave).
Next up: touch up/total re-paint. Paint shop recommended by Ameng (near his place, new shop). AM Action Motors. Uses Dupont Paint.
Just changed my fuel pump, second hand bought for RM300/=. DIY - free labour
Originally posted by affan66@Mar 12 2005, 10:26 AM
today at M-Speed:
Affan, how come so cheap? Earlier when I wanted to replace my fuel pump as well, I was quoted in the region of RM600.
dvng mentioned his second hand one costs him RM300 already.
Now I am confused as to why there is such a huge discrepancy in terms of the pricing. :unsure:
