Russie;232221 said:I have to agree that this thread started by Lee was indeed a good one, especially for a newbie like me :wink: Honestly, the first time I read this thread was way before I got myself an UDM *in fact certain threads in here do scare away newbies and UDM-owners-wannabe* hehe. But after much "inputs" and advice by a fella friend-cum-mechanic, I was told that 4 potters should be quite economical to own, hence the ownership of my E36 318. Having re-read this thread, it makes me wanna explore fitting in some of those items mentioned here, like the volt stabiliser, ARB, X-brace, etc. So now the question is where to get them? and what's the budget like?
spikyone;232510 said:Thanks for the advice, hmm..u say maybe not steering rack ah?..well it shudders when i brake in a straight line,and when i corner medium to high speeds..feels like something is disconnected and wobbly at the front.
This can be a matter of injecting grease to the steering rack connection, located deep inside the engine bay. The sound/vibration travels up the rack into your hand.spikyone;232510 said:Although sometimes when i turn the steering wheel its squeaky.
spikyone;232510 said:By bushes Im guessing you mean ALL the bushes attached to the front & rear suspension cradles, steering arms etc? your RM2k for a recond steering rack is quite a gd price although I was offered a new rack at B$1.8k..can ah? O should i recond my own steering rack at my mechanic? I know mine has no free play in the steering..
alxy;247235 said:Err...sorry if I seem to be a busybody, but the term is Occam's Razor (after William of Occam, sometimes spelled as Ockham). Arkham is like Arkham Asylum as in Batman!
P/S I am a comic fan too![]()
Vincent Hor;255439 said:Found this thread very interesting. Just bought a late 1997 E36 328i(A). The last owner is a 66 years old retired professional. He has maintain and upkept the car very well.
http://usera.imagecave.com/Vinchor/
The car is equipped with original M3 kits. Mileage is 155K kms. It's a local AB car. Currently riding on 16" E46 rims with almost new Michelins. Road tax is paid up till Sept. 2008 (previous owner). I paid RM45K
Undercarriage and suspension system has been attended to by the previous owner. Not a squeek going over humps and minor portholes.
Engine sounds healthy and there are bills to show that the radiator, hoses, alternator, air cond compressor has been changed recently. Car has been completely sound proofed i.e. floor board, door panels and roof.
Minus points :
A little wet around the g/box oil pan (gasket), steering rod has signs of leak(repair kit?), fly wheel oil seal may need attention plus the power steering hose also need some attention.
G/Box is Auto GM - PRND432 Is this a 5 Speed or 4 speed with a lock up OD.
I noticed there is some vibration at the rear when doing speed of 100/120kph upwards. Will try to balance the tyres and see if problem persist. Is there other reasons for this to happen?
Torque is superb but moving on from stand still requires a good thrust on the padle ortherwise it feels slow until I hit the kick down switch. Is this normal?
Also at certain rev there seems to be a little "kick" in the gear change. It happens on accerelating and when you decide to lift off you foot from the gas padle. Is this a common issue? Or does this have anything relating to the rear diff?
Would be good to hear from the sifu's
Vincent Hor;255439 said:Undercarriage and suspension system has been attended to by the previous owner. Not a squeek going over humps and minor portholes.
Vincent Hor;255439 said:Minus points :
Vincent Hor;255439 said:G/Box is Auto GM - PRND432 Is this a 5 Speed or 4 speed with a lock up OD.
Vincent Hor;255439 said:I noticed there is some vibration at the rear when doing speed of 100/120kph upwards. Will try to balance the tyres and see if problem persist. Is there other reasons for this to happen?
Vincent Hor;255439 said:Torque is superb but moving on from stand still requires a good thrust on the padle ortherwise it feels slow until I hit the kick down switch. Is this normal?
Vincent Hor;255439 said:Also at certain rev there seems to be a little "kick" in the gear change. It happens on accerelating and when you decide to lift off you foot from the gas padle. Is this a common issue? Or does this have anything relating to the rear diff?
