bimmerdude;544662 said:the problem is that our bmw's air intake inlet is low compared to the japs'. so a relatively low flood would also be a problem, despite smaller cars being able to go thru.
furthermore, flash floods are unpredictable and unexpected. by the time it happens, its too late to back out. Best to not even go out if its raining very very heavily.
racheltoh;544886 said:i was told if driving thru flood...never hit the brakes.
Schwepps;544957 said:Best not to drive through a flood at all. And never when the water is moving, or you'll be swept away like the gung-ho but silly lad in the NZ video. Do a U or park the car and wait.
If there's absolutely no choice, put it in manual mode, keep it in 1st gear, and keep the revs high and exhaust blowing out hard as you motor through. That keeps your engine from stalling because of resistance in higher gear or water blocking the exhaust pipe. That's also why you shouldn't brake, because then you're taking your foot off the gas and you may stall. There's no hope then - just take off your shoes, and wade out![]()
E46Fanatic;545288 said:As long as the engine is running, a submerged exhaust pipe shouldn't stall the engine. Its like blowing through a straw. Exhaust gases will find their way out from the exhaust as exhaust bubbles whether the engine is at 1k rpm or 6k rpm
Again this is theory only la. Never tested in real world tho.
Schwepps;545303 said:The exhaust will be okay so long as you're moving and the revs are kept up. Actually it's more than theory. Off-roaders regularly ford streams and fit snorkels and extended pipes for that purpose. But Mini and 3-er designers would have thought: I'm designing a sporty car for fast drivers, not a 4X4 off-roader...or jet ski![]()
ALBundy;545309 said:Had the same mishap more than 12 years ago, when my brother and I was in a Satria then. He droved a little too fast trying into the flood area, its akin to hitting a wall, engine RPM dropped, water got sucked into the engine via the exhaust pipe --> extractor --> combustion chamber and rest is history.
